Not possible to disable the shell as a log backend in Zephyr (for nRF9160)
We are using nRF Connect SDK 1.1 for nRF9160.
It is not possible to turn off the shell as a log backend in Zephyr. Is this a bug or a feature? Is there any way I can disable it?
How to reproduce:
1) I set the symbol CONFIG_SHELL_LOG_BACKEND=n in a .conf-file
2) When building I get the warning:
warning: SHELL_LOG_BACKEND (defined at subsys/shell/Kconfig:151) was assigned the value 'n' but got
the value 'y'. This symbol has no prompt, meaning assignments in configuration files have no effect
on it. It can only be set indirectly, via Kconfig defaults (e.g. in a Kconfig.defconfig file) or
through being 'select'ed or 'imply'd (note: try to avoid Kconfig 'select's except for trivial
promptless "helper" symbols without dependencies, as it ignores dependencies and forces symbols on).
You can check symbol information (including dependencies) in the 'menuconfig' interface (see the
Application Development Primer section of the manual), or in the Kconfig reference at
docs.zephyrproject.org/.../CONFIG_SHELL_LOG_BACKEND.html (which is
updated regularly from the master branch). See the 'Setting configuration values' section of the
Board Porting Guide as well. It covers Kconfig.defconfig files.
3) I read about the the config at https://docs.zephyrproject.org/2.1.0/reference/kconfig/CONFIG_SHELL_LOG_BACKEND.html. It confirms that the config cannot be set directly since it has no prompt.
BR / Björn
