Update BLE Characteristic from ENUM
Hi
I would like to use an ENUM and STUCT within my application to maintain device state (IDLE, RUNNING etc). This state needs to update a BLE Characteristic. I have the BLE Service and Characteristic running but am struggling to send the ENUM as a single byte (uint8_t).
The ENUM & STRUCT is as follows:
typedef enum
    IDLE    = 0x00,    //0
    RUNNING = 0x01,    //1
    FAULT   = 0x09     //9
} m_srm_state_evt_type_t;
typedef struct
    m_srm_state_evt_type_t evt_type;
} m_srm_state_type_t;
static m_srm_state_type_t m_srm_state;
And the BLE update char is as follows:
case BLE_SRVC_OPT_EVT_CONNECTED:
            uint8_t value[1]            = {m_srm_state.value};
            err_code = ble_srvc_opt_custom_value_update(&m_cus, value);
I know it's my lack of programming skills, but really stuck on this one. Thanks in advance.
  • Hi
    I have looked at my code and carried out a few modifications and have a better understand how the SoftDevice works.
    The following is working, on the following event, it calls handle_ble_char:
            t_value = SET;
            handle_ble_char(p_cus_service, &p_cus_service->status_char_handles , &t_value);
    The structure of handle_ble_char is as follows:
    static void handle_ble_char (ble_srvc_opt_t *p_service, ble_gatts_char_handles_t *p_char_handle, m_setget *p_type) {
        uint32_t err_code;
        ble_gatts_value_t	t_value;
        //Get & Set for ble_src_opt - Char - Status
        if (p_char_handle->value_handle == m_cus.status_char_handles.value_handle) {
            t_value.p_value = &m_srm_state.evt_type;
    	    t_value.len      = 1;
    	    t_value.offset   = 0;
            switch (*p_type)
            case SET:
                err_code = sd_ble_gatts_value_set(p_service->conn_handle, p_char_handle->value_handle, &t_value);
            case GET:
                err_code = sd_ble_gatts_value_get(p_service->conn_handle, p_char_handle->value_handle, &t_value);
    This is a universal bit of code which allows me to tell it which service and characteristic to set or get.
    It is working as planned now...thanks for the help on this one.
