nRF Connect desktop Error: "failed to get descriptor"
I am trying to use nRF Connect for desktop with a dongle or nrf52 DK to connect with another board. When I want to get the value from the connected board, it would always display this error: "failed to get descriptor", no matter whether using "notify". I cannot read or write anything
Could you please tell me how to solve this problem?
Thank you in advance!
Best,
Taoyi
  •  Here's the log when I tried to read the descriptor
  • Hi
    Then there must be something in your simplified HRM service/function that is causing this error. Please try comparing these to try and find out what the critical changes are. Error 133 (0x85) is just a general GATT error, so it's hard to say what exactly is the reason.
    Simon
  • Take a look at Hung Bui's answer to this question.  If you are not using the peer manager, you must handle the BLE_GATTS_EVT_SYS_ATTR_MISSING event in your BLE event handler function.  The blinky example includes this case in the function ble_evt_handler() in main.c:
    It appears that without this response nRF Connect for desktop will hang until it hits a GATT timeout, and will show the error "Failed to get descriptors, a gatt operation already in progress" or simply "Received a Gatt timeout".  Another indication is when you hover the mouse over the arrow to toggle notifications (to the right of the characteristic), you see the message "CCCD not discovered".
