The achievable shortest CPU blocking time and longest interval while being detectable by other BLE devices
Assuming the system is composed of one device using nRF51822 and iPhone/PC, If we want nRF51822 detectable by iPhone/PC so that iPhone/PC can connect nRF51822 when they want, how short CPU blocking time and how long interval between two blocking time can we achieve?
Thanks!
  • Hi Ole, I have one more question:) I saw "Table 14 Radio Notification timing ranges" in <S110_SoftDevice_Specification v1.1.pdf>. t_evnt is: 550 to 1300us Advertiser - 0 to 31 bytes payload, 3 channels). P is: <=150 us. According to this, for an advertising event, the blocking time can be P+t_event: 700us ~1450us. The minimum 700us is less than 2ms. Does your 2ms count a scan response in? or I have some misunderstanding here? Thanks.
  • Please take a look at the screenshots I added to my answer here. 550 µs is the time for one channel, my 2 ms is total time over all channels, excluding the time you get to run in between.
    If you need specific data on this, I'd recommend you to do a similar test to the one I did, just making a GPIO toggle in main and capture the pin with a logic analyzer.
    The sequence will always be 37, 38, 39.
  • Thank you for your quick reply, Ole.
    Now I understand it better: In advertising event: P -> CPU_available1-> Ch37 -> CPU_available2 -> Ch38 -> CPU_available3 -> Ch39. The P(preparation), Ch37, Ch38 and Ch39 are durations those CPU is blocked.
    • According to <S110_SoftDevice_Specification v1.1.pdf>, P<= 150us, Ch37/38/39 is 550~1300us for each channel (affected by the payload, and whether there is a scan request).
    • According to the experiment shown here, the CPU_available1/2/3 are about 1.5ms/0.2ms/0.2ms. (as I understand, CPU_available1 is affected by t_ndist shown in <S110_SoftDevice_Specification v1.1.pdf> and not assured. CPU_available2/3 are always there and the duration requires experiment to know but kind of consistent.)
    In connection event: P -> CPU_available -> data_transferring.
    • According to <S110_SoftDevice_Specification v1.1.pdf>, P<= 150us, data_transferring is 900~5800 us (affected by the number of packets, the payload, whether encrypted or not and the accuracy of low frequency crystal on both Central and Peripheral).
    • According to the experiment shown here, the CPU_available is about 1.4 ms. (as I understand, CPU_available1 is affected by t_ndist shown in <S110_SoftDevice_Specification v1.1.pdf> and not assured.)
    With this understanding in mechanism, I can make relatively good estimation for the worst case about CPU available time and interrupt latency, and get specific data by doing similar test as the one you do.
