nRF52832 with SDK v11.0.0 -- System Randomly Freeze and Doesn't Recover via WDog
Currently, we are working on a product which leverages the following:
NRF52832 (64KB RAM and 512 KB Flash)
SDK v11.0.0
Soft Device 132
It has been reported out in the field that our product is randomly "freezing". After weeks of FW debugging/testing/analysis, our team has yet to root cause the issue.
Why is the watchdog (WDog) not overriding the system to reset it? If the CPU has a hard-fault, shouldn't the WDog priority be higher than a CPU hard-fault? Our hard-fault handlers have been updated to reset the system, however, the system remains stuck. The only way that we're able to recover the system is if we pull the battery out and plug it back in. Essentially, we need to make sure that the WDog is not being blocked by any other executing instructions of higher priority. Please advise on what to do. Is this a known issue? Are there other ways that we can recover the system from an indeterminant state besides a WDog reset or hard-fault handler?
Please note, our product does not have a hardware reset pin.
  • Hi Sami,
    the location of the bits that flip may vary from chip to chip, but the location seems to be fixed for every chip that do fail. Only a few bits (e.g. 1-5) spread across RAM.
    The way we test the issue is that we initialize the RAM blocks not used by the stack to all 0's and then enter System ON Idle and wake up from a timer. We then examine the RAM blocks after wake-up and check if any bits have been flipped.
    Best regards
    Bjørn
  • I created an external array:
    uint32_t errata108Arr[10] = {0};
    so that it lives in the .bss section (i.e., not the stack). Then, I put the system into System OFF mode, waited a few seconds, and then woke the system back up (System ON mode). The array still preserved its contents. Do I need to check all memory blocks outside of the stack in accordance with what you said: "the location of the bits that flip may vary from chip to chip."
  • Hi Sami,
    Yes, you should create an array that covers as much of RAM as possible.
    I have attached the code we have been using internally to check if devices are affected.
     errata_108_test_code.zip
    Best regards
    Bjørn
  • Thank you. If the bug, i.e., errata 108, does occur, could it lead to a "screen freeze"/"blank screen" that does not recover via WDog timeout reset? Also, are interrupts also frozen?
  • HI Sami Balbaky,
    if a RAM corruption occurs due to Errata 108 issue,  then this can cause a HardFault if the CPU fetches a corrupt instruction that points to a memory location outside the nRF52832s memory area. and the HardFault exception will trigger HardFault_Handler in the application. The HardFault exception is always enabled and has a fixed priority, -1 (higher than other interrupts and exceptions), so while the CPU is in the Hardfault handler it will prevent other interrupts with lower priority from being serviced.
    I took a closer look at default HardFault handler implementation in the system_nrf52.c file and this will just loop indefinitely. The HardFault_Handler in the system_nrf52.c file is a weak implementation
      .weak   HardFault_Handler
    HardFault_Handler:
      b     .
    Which basically is equivalent to
    HardFault_Handler:
      b HardFault_Handler
    So if you want the Hardfault exception to trigger a reset then you need to override the weak implementation and issue a SoftReset,i.e. NVIC_SystemReset().
    However, the WDT will reset the device if it is running when the HardFault occurs. As discussed previously the WDT is independent of the CPU, it will trigger a reset regardless of the CPU state. When the HardFault occurs the CPU is basically just looping the HardFault handler.
    Best regards
    Bjørn
