Segger Embedded Studio doesn't work
OS: Mac
I installed nrf v1.2.0 and Segger Embedded Studio v4.42a. I can't open project and it causes error.
Loading solution at_client.emProject
Executing load commands
/usr/local/bin/cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=/Users/fukuharayuusuke/nRF9160/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/opt/gnuarmemb -B/Users/fukuharayuusuke/nRF9160/ncs/nrf/samples/nrf9160/at_client/build_nrf9160_pca10090ns -H/Users/fukuharayuusuke/nRF9160/ncs/nrf/samples/nrf9160/at_client -DPYTHON_EXECUTABLE=/Users/fukuharayuusuke/.pyenv/shims/python -DCMAKE_MAKE_PROGRAM=/usr/local/bin/ninja -DDTC=/usr/local/bin/dtc -D WEST=/Users/fukuharayuusuke/.pyenv/shims/west -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=/Applications/arm_segger_embedded_studio_v442a_macos_x64_nordic/html/configure_nordic_project_menuconfig.py
-- Zephyr version: 2.1.99
-- Selected BOARD nrf9160_pca10090ns
-- Found west: /Users/fukuharayuusuke/.pyenv/shims/west (found suitable version "0.6.3", minimum required is "0.6.0")
-- Loading /Users/fukuharayuusuke/nRF9160/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
nrf9160_pca10090ns.dts.pre.tmp:89.42-101.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
nrf9160_pca10090ns.dts.pre.tmp:338.19-344.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
Devicetree configuration written to /Users/fukuharayuusuke/nRF9160/ncs/nrf/samples/nrf9160/at_client/build_nrf9160_pca10090ns/zephyr/include/generated/devicetree.conf
Parsing /Users/fukuharayuusuke/nRF9160/ncs/zephyr/Kconfig
/Users/fukuharayuusuke/nRF9160/ncs/nrf/lib/fprotect/Kconfig:20: WARNING: dt_int_val is deprecated.
/Users/fukuharayuusuke/nRF9160/ncs/bootloader/mcuboot/zephyr/Kconfig:37: WARNING: dt_int_val is deprecated.
Loaded configuration '/Users/fukuharayuusuke/nRF9160/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns_defconfig'
Merged configuration '/Users/fukuharayuusuke/nRF9160/ncs/nrf/samples/nrf9160/at_client/prj.conf'
Configuration saved to '/Users/fukuharayuusuke/nRF9160/ncs/nrf/samples/nrf9160/at_client/build_nrf9160_pca10090ns/zephyr/.config'
-- The C compiler identification is GNU 8.3.1
-- The CXX compiler identification is GNU 8.3.1
-- Found assembler: /opt/gnuarmemb/bin/arm-none-eabi-gcc
-- Cache files will be written to: /Users/fukuharayuusuke/Library/Caches/zephyr
=== child image spm begin ===
Changed board to secure nrf9160_pca10090 (NOT NS)
CMake Error at /usr/local/Cellar/cmake/3.15.5/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
  Could NOT find PythonInterp: Found unsuitable version "2.7.16", but
  required is at least "3.6" (found /usr/bin/python)
  /usr/local/Cellar/cmake/3.15.5/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:376 (_FPHSA_FAILURE_MESSAGE)
  /Users/fukuharayuusuke/nRF9160/ncs/zephyr/cmake/backports/FindPythonInterp.cmake:174 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
  /Users/fukuharayuusuke/nRF9160/ncs/zephyr/cmake/python.cmake:22 (include)
  /Users/fukuharayuusuke/nRF9160/ncs/zephyr/cmake/app/boilerplate.cmake:101 (include)
  CMakeLists.txt:9 (include)
CMake Error at ../../../cmake/multi_image.cmake:176 (message):
  CMake generation for spm failed, aborting.  Command: 1
  ../../../cmake/multi_image.cmake:76 (add_child_image_from_source)
  ../../CMakeLists.txt:8 (add_child_image)
See also "/Users/fukuharayuusuke/nRF9160/ncs/nrf/samples/nrf9160/at_client/build_nrf9160_pca10090ns/CMakeFiles/CMakeOutput.log".
See also "/Users/fukuharayuusuke/nRF9160/ncs/nrf/samples/nrf9160/at_client/build_nrf9160_pca10090ns/CMakeFiles/CMakeError.log".
Project load failed
Reported error: solution load command failed (1)
I can open projects with this config on SES v4.42a and nrf v1.1.0.
Any help?
    I have tested with Catalina, and cannot get it to wrongly identify python to python2.7 at my end, unfortunately.
    Which version of macos are you running?
    Håkon
  • I upgraded Mac OS to Catalina. I also deleted pyenv and am using python3.7 installed by homebrew. Now I get this error.
    /usr/local/bin/cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=/Users/fukuharayuusuke/nRF9160/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/opt/gnuarmemb -B/Users/fukuharayuusuke/nRF9160/ncs/nrf/samples/nrf9160/at_client/build_nrf9160_pca10090ns -H/Users/fukuharayuusuke/nRF9160/ncs/nrf/samples/nrf9160/at_client -DPYTHON_EXECUTABLE=/usr/local/bin/python3 -DCMAKE_MAKE_PROGRAM=/usr/local/bin/ninja -DDTC=/usr/local/bin/dtc -D WEST=/usr/local/bin/west -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=/Applications/arm_segger_embedded_studio_v430c_macos_x64_nordic/html/configure_nordic_project_menuconfig.py
    -- Found west: /usr/local/bin/west (found suitable version "0.6.3", minimum required is "0.6.0")
    -- Found PythonInterp: /usr/bin/python3 (found suitable version "3.7.3", minimum required is "3.6")
    -- Loading /Users/fukuharayuusuke/nRF9160/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
    -- Overlaying /Users/fukuharayuusuke/nRF9160/ncs/nrf/samples/nrf9160/spm/nrf9160_pca10090.overlay
      File "/Users/fukuharayuusuke/nRF9160/ncs/zephyr/scripts/dts/gen_defines.py", line 26, in <module>
        import edtlib
      File "/Users/fukuharayuusuke/nRF9160/ncs/zephyr/scripts/dts/edtlib.py", line 73, in <module>
        import yaml
    ModuleNotFoundError: No module named 'yaml'
    CMake Error at /Users/fukuharayuusuke/nRF9160/ncs/zephyr/cmake/dts.cmake:210 (message):
      new extractor failed with return code: 1
      /Users/fukuharayuusuke/nRF9160/ncs/zephyr/cmake/app/boilerplate.cmake:460 (include)
    Status
    nrf v0.4.0 => can open projects
    nrf v1.0.0 => can open projects
    nrf v1.1.0 => can open projects
    nrf v1.2.0 => fail in opening projects
    I run "pip3 install pyyaml" but nothing changed.
    $ pip3 install pyyaml
    Requirement already satisfied: pyyaml in /usr/local/lib/python3.7/site-packages (5.3)
    Any help?
  • were you able to resolve this issue? I have the same issue and nothing seems to be working.
  • No I can't solve this issue. I gave it up. I'm using Windows10 now
  • That is what I have had to do also. I come back and retry the Mac install every month or so.
