nRF9160 Using MQTT with TLS
Hi everyone,
I am looking at using MQTT v3.1.1 with TLS 1.2, to send data to Azure IoT Hub.
I tested the MQTT Simple sample and it worked perfeclty. So I am modifying this project to enable TLS. To do so I followed those threads:
https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/enabling-and-testing-tls-in-mqtt_5f00_simple
https://github.com/joakimtoe/fw-nrfconnect-nrf/commit/36532a8ca60bf7139a988b5cbb4e6cb47948a9fa#diff-607096fd76f1fd14e4c9453aa1dc8fd3
https://devzone.nordicsemi.com/f/nordic-q-a/44921/nrf9160-tls-and-mqtt
https://devzone.nordicsemi.com/f/nordic-q-a/49339/implementing-tls-with-mqtt-in-nrf9160
Right now I am able to create the TLS socket but I am stucked at the next step which is the connection step.
When defining  tls_config->peer_verify = 2; I got back ERROR: mqtt_connect -45.
And when I define it to 0 or 1 there is no response, as if the nRF9160 is stucked somewhere.
My log is the following for peer_verify=2. It is the same for 0/1, but without the error code.
00> ***** Booting Zephyr OS build v2.0.99-ncs1 *****
00>
00> The MQTT simple sample started
00>
00> Deleting certs sec_tag: 2
00>
00> nrf_inbuilt_key_delete(2, 0) => result=0
00>
00>
00> nrf_inbuilt_key_delete(2, 1) => result=0
00>
00>
00> nrf_inbuilt_key_delete(2, 2) => result=0
00>
00>
00> nrf_inbuilt_key_delete(2, 3) => result=2
00>
00>
00> nrf_inbuilt_key_delete(2, 4) => result=2
00>
00> Write ca certs sec_tag: 2
00>
00> Write private cert sec_tag: 2
00>
00> Write public cert sec_tag: 2
00>
00> err_provision = 0
00>
00> LTE Link Connecting ...
00>
00> LTE Link Connected!
00>
00> IPv4 Address found 13.95.15.251
00>
00> ERROR: mqtt_connect -45
It has to be noted that the certificates I used are working in an application on my computer. They are placed here in certificates.h and are using the right formatting.
In my project folder, my prof.conf file is the following:
# Copyright (c) 2019 Nordic Semiconductor ASA
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
# General config
CONFIG_PRINTK=y
CONFIG_CONSOLE=y
CONFIG_LOG=y
CONFIG_SERIAL=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_UART_CONSOLE=n
CONFIG_RTT_CONSOLE=y
CONFIG_HAS_SEGGER_RTT=y
CONFIG_USE_SEGGER_RTT=y
# Random Generator
CONFIG_TEST_RANDOM_GENERATOR=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
# nRF Cloud
CONFIG_NRF_CLOUD_PROVISION_CERTIFICATES=y
#CONFIG_NRF_CLOUD=y
# Modem info
#CONFIG_MODEM_INFO=y
#TLS
CONFIG_SEC_TAG=2
CONFIG_PEER_VERIFY=2
# LTE link control
#CONFIG_POWER_OPTIMIZATION_ENABLE=n
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
# BSD library
CONFIG_BSD_LIBRARY=y
# AT Host
CONFIG_AT_HOST_LIBRARY=y
# MQTT
CONFIG_MQTT_LIB=y
#CONFIG_MQTT_SOCKET_LIB=y
CONFIG_MQTT_LIB_TLS=y
#CONFIG_MQTT_MAX_PACKET_LENGTH=2048
# Application
#CONFIG_MQTT_PUB_TOPIC="/my/publish/topic"
#CONFIG_MQTT_SUB_TOPIC="/my/subscribe/topic"
CONFIG_MQTT_CLIENT_ID="mqtt_test"
CONFIG_MQTT_BROKER_HOSTNAME="test-aptus.azure-devices.net"
CONFIG_MQTT_BROKER_PORT=8883
CONFIG_PROVISION_CERTIFICATES=y
CONFIG_CERTIFICATES_FILE="certificates.h"
# Main thread
CONFIG_MAIN_THREAD_PRIORITY=7
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=2048
The Kconfig file there is the following:
# Copyright (c) 2018 Nordic Semiconductor ASA
menu "MQTT simple sample"
config PROVISION_CERTIFICATES
	bool "Provision of certificate"
	help
		Enable run-time provisioning of certificates from the
		certificates header file selected by using CERTIFICATES_FILE
config CERTIFICATES_FILE
	string "Certificates to use"
	depends on PROVISION_CERTIFICATES
	default "certificates.h"
config SEC_TAG
	int "Security tag to use for the connection"
	default 1
config PEER_VERIFY
    int "Peer verify parameter for mqtt_client"
    default 1
    help
        Set to 0 for VERIFY_NONE, 1 for VERIFY_OPTIONAL, and 2 for VERIFY_REQUIRED.
config MQTT_PUB_TOPIC
	string "MQTT publish topic"
	default "my/publish/topic"
config MQTT_SUB_TOPIC
	string "MQTT subscribe topic"
	default "my/subscribe/topic"
config MQTT_CLIENT_ID
	string "MQTT Client ID"
	default "my-client-id"
config MQTT_BROKER_HOSTNAME
	string "MQTT broker hostname"
	default "mqtt.eclipse.org"
config MQTT_BROKER_PORT
	int "MQTT broker port"
	default 1883
config MQTT_MESSAGE_BUFFER_SIZE
	int "MQTT message buffer size"
	default 128
config MQTT_PAYLOAD_BUFFER_SIZE
	int "MQTT payload buffer size"
	default 128
endmenu
menu "Zephyr Kernel"
source "$ZEPHYR_BASE/Kconfig.zephyr"
endmenu
And the main.c is :
 * Copyright (c) 2018 Nordic Semiconductor ASA
 * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr.h>
#include <stdio.h>
#include <uart.h>
#include <string.h>
#include <net/mqtt.h>
#include <net/socket.h>
#include <lte_lc.h>
#include <certificates.h>
#if defined(CONFIG_BSD_LIBRARY)
#include "nrf_inbuilt_key.h"
#include CONFIG_CERTIFICATES_FILE
#if defined(CONFIG_LWM2M_CARRIER)
#include <lwm2m_carrier.h>
//#define CONFIG_NRF_CLOUD_SEC_TAG 1
#define NRF_CLOUD_HOSTNAME CONFIG_MQTT_BROKER_HOSTNAME
//#define NRF_CLOUD_SEC_TAG  CONFIG_NRF_CLOUD_SEC_TAG
static sec_tag_t sec_tag_list[] = {CONFIG_SEC_TAG};
/* Buffers for MQTT client. */
static u8_t rx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static u8_t tx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static u8_t payload_buf[CONFIG_MQTT_PAYLOAD_BUFFER_SIZE];
/* The mqtt client struct */
static struct mqtt_client client;
/* MQTT Broker details. */
static struct sockaddr_storage broker;
/* Connected flag */
static bool connected;
/* File descriptor */
static struct pollfd fds;
/**@brief Recoverable BSD library error. */
void bsd_recoverable_error_handler(uint32_t err)
	printk("bsdlib recoverable error: %u\n", (unsigned int)err);
/**@brief Irrecoverable BSD library error. */
void bsd_irrecoverable_error_handler(uint32_t err)
	printk("bsdlib irrecoverable error: %u\n", err);
	__ASSERT_NO_MSG(false);
#endif /* defined(CONFIG_BSD_LIBRARY) */
/**@brief Function to print strings without null-termination
static void data_print(u8_t *prefix, u8_t *data, size_t len)
	char buf[len + 1];
	memcpy(buf, data, len);
	buf[len] = 0;
	printk("%s%s\n", prefix, buf);
/**@brief Function to publish data on the configured topic
static int data_publish(struct mqtt_client *c, enum mqtt_qos qos,
	struct mqtt_publish_param param;
	param.message.topic.qos = qos;
	param.message.topic.topic.utf8 = CONFIG_MQTT_PUB_TOPIC;
	param.message.topic.topic.size = strlen(CONFIG_MQTT_PUB_TOPIC);
	param.message.payload.data = data;
	param.message.payload.len = len;
	param.message_id = sys_rand32_get();
	param.dup_flag = 0;
	param.retain_flag = 0;
	data_print("Publishing: ", data, len);
	printk("to topic: %s len: %u\n",
		CONFIG_MQTT_PUB_TOPIC,
		(unsigned int)strlen(CONFIG_MQTT_PUB_TOPIC));
	return mqtt_publish(c, &param);
/**@brief Function to subscribe to the configured topic
static int subscribe(void)
	struct mqtt_topic subscribe_topic = {
		.topic = {
			.utf8 = CONFIG_MQTT_SUB_TOPIC,
			.size = strlen(CONFIG_MQTT_SUB_TOPIC)
		.qos = MQTT_QOS_1_AT_LEAST_ONCE
	const struct mqtt_subscription_list subscription_list = {
		.list = &subscribe_topic,
		.list_count = 1,
		.message_id = 1234
	printk("Subscribing to: %s len %u\n", CONFIG_MQTT_SUB_TOPIC,
		(unsigned int)strlen(CONFIG_MQTT_SUB_TOPIC));
	return mqtt_subscribe(&client, &subscription_list);
/**@brief Function to read the published payload.
static int publish_get_payload(struct mqtt_client *c, size_t length)
	u8_t *buf = payload_buf;
	u8_t *end = buf + length;
	if (length > sizeof(payload_buf)) {
		return -EMSGSIZE;
	while (buf < end) {
		int ret = mqtt_read_publish_payload(c, buf, end - buf);
		if (ret < 0) {
			int err;
			if (ret != -EAGAIN) {
				return ret;
			printk("mqtt_read_publish_payload: EAGAIN\n");
			err = poll(&fds, 1, K_SECONDS(CONFIG_MQTT_KEEPALIVE));
			if (err > 0 && (fds.revents & POLLIN) == POLLIN) {
				continue;
			} else {
				return -EIO;
		if (ret == 0) {
			return -EIO;
		buf += ret;
	return 0;
/**@brief MQTT client event handler
void mqtt_evt_handler(struct mqtt_client *const c,
		      const struct mqtt_evt *evt)
	int err;
	switch (evt->type) {
	case MQTT_EVT_CONNACK:
		if (evt->result != 0) {
			printk("MQTT connect failed %d\n", evt->result);
		connected = true;
		printk("[%s:%d] MQTT client connected!\n", __func__, __LINE__);
		subscribe();
	case MQTT_EVT_DISCONNECT:
		printk("[%s:%d] MQTT client disconnected %d\n", __func__,
		       __LINE__, evt->result);
		connected = false;
	case MQTT_EVT_PUBLISH: {
		const struct mqtt_publish_param *p = &evt->param.publish;
		printk("[%s:%d] MQTT PUBLISH result=%d len=%d\n", __func__,
		       __LINE__, evt->result, p->message.payload.len);
		err = publish_get_payload(c, p->message.payload.len);
		if (err >= 0) {
			data_print("Received: ", payload_buf,
			/* Echo back received data */
			data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE,
				payload_buf, p->message.payload.len);
		} else {
			printk("mqtt_read_publish_payload: Failed! %d\n", err);
			printk("Disconnecting MQTT client...\n");
			err = mqtt_disconnect(c);
			if (err) {
				printk("Could not disconnect: %d\n", err);
	} break;
	case MQTT_EVT_PUBACK:
			printk("MQTT PUBACK error %d\n", evt->result);
		printk("[%s:%d] PUBACK packet id: %u\n", __func__, __LINE__,
				evt->param.puback.message_id);
	case MQTT_EVT_SUBACK:
			printk("MQTT SUBACK error %d\n", evt->result);
		printk("[%s:%d] SUBACK packet id: %u\n", __func__, __LINE__,
				evt->param.suback.message_id);
		printk("[%s:%d] default: %d\n", __func__, __LINE__,
				evt->type);
/**@brief Resolves the configured hostname and
 * initializes the MQTT broker structure
static void broker_init(void)
	int err;
	struct addrinfo *result;
	struct addrinfo *addr;
	struct addrinfo hints = {
		.ai_family = AF_INET,
		.ai_socktype = SOCK_STREAM
	err = getaddrinfo(CONFIG_MQTT_BROKER_HOSTNAME, NULL, &hints, &result);
	if (err) {
		printk("ERROR: getaddrinfo failed %d\n", err);
		return;
	addr = result;
	err = -ENOENT;
	/* Look for address of the broker. */
	while (addr != NULL) {
		/* IPv4 Address. */
		if (addr->ai_addrlen == sizeof(struct sockaddr_in)) {
			struct sockaddr_in *broker4 =
				((struct sockaddr_in *)&broker);
			char ipv4_addr[NET_IPV4_ADDR_LEN];
			broker4->sin_addr.s_addr =
				((struct sockaddr_in *)addr->ai_addr)
				->sin_addr.s_addr;
			broker4->sin_family = AF_INET;
			broker4->sin_port = htons(CONFIG_MQTT_BROKER_PORT);
			inet_ntop(AF_INET, &broker4->sin_addr.s_addr,
				  ipv4_addr, sizeof(ipv4_addr));
			printk("IPv4 Address found %s\n", ipv4_addr);
		} else {
			printk("ai_addrlen = %u should be %u or %u\n",
				(unsigned int)addr->ai_addrlen,
				(unsigned int)sizeof(struct sockaddr_in),
				(unsigned int)sizeof(struct sockaddr_in6));
		addr = addr->ai_next;
	/* Free the address. */
	freeaddrinfo(result);
/**@brief Initialize the MQTT client structure
static void client_init(struct mqtt_client *client)
	mqtt_client_init(client);
	broker_init();
	/* MQTT client configuration */
	client->broker = &broker;
	client->evt_cb = mqtt_evt_handler;
	client->client_id.utf8 = (u8_t *)CONFIG_MQTT_CLIENT_ID;
	client->client_id.size = strlen(CONFIG_MQTT_CLIENT_ID);
        printk("clientId %s \n", CONFIG_MQTT_CLIENT_ID);
	client->password = NULL;
	client->user_name = NULL;
	client->protocol_version = MQTT_VERSION_3_1_1;
	/* MQTT buffers configuration */
	client->rx_buf = rx_buffer;
	client->rx_buf_size = sizeof(rx_buffer);
	client->tx_buf = tx_buffer;
	client->tx_buf_size = sizeof(tx_buffer);
	/* MQTT transport configuration */
        #if defined(CONFIG_MQTT_LIB_TLS)
          struct mqtt_sec_config *tls_config = &client->transport.tls.config;
          client->transport.type = MQTT_TRANSPORT_SECURE;
          tls_config->cipher_count = 0;
          tls_config->cipher_list = NULL;
          tls_config->sec_tag_count = ARRAY_SIZE(sec_tag_list);
          tls_config->sec_tag_list = sec_tag_list;
          tls_config->hostname = CONFIG_MQTT_BROKER_HOSTNAME;
          #else /* MQTT transport configuration */
          client->transport.type = MQTT_TRANSPORT_NON_SECURE;
          #endif /* defined(CONFIG_MQTT_LIB_TLS) */
/**@brief Initialize the file descriptor structure used by poll.
static int fds_init(struct mqtt_client *c)
	if (c->transport.type == MQTT_TRANSPORT_NON_SECURE) {
		fds.fd = c->transport.tcp.sock;
	} else {
		fds.fd = c->transport.tls.sock;
#else
		return -ENOTSUP;
	fds.events = POLLIN;
	return 0;
/**@brief Configures modem to provide LTE link. Blocks until link is
 * successfully established.
static void modem_configure(void)
#if defined(CONFIG_LTE_LINK_CONTROL)
	if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT)) {
		/* Do nothing, modem is already turned on
		 * and connected.
	} else {
		/* Wait for the LWM2M_CARRIER to configure the modem and
		 * start the connection.
		printk("Waitng for carrier registration...\n");
		k_sem_take(&carrier_registered, K_FOREVER);
		printk("Registered!\n");
#else /* defined(CONFIG_LWM2M_CARRIER) */
		int err;
		printk("LTE Link Connecting ...\n");
		err = lte_lc_init_and_connect();
		__ASSERT(err == 0, "LTE link could not be established.");
		printk("LTE Link Connected!\n");
#endif /* defined(CONFIG_LWM2M_CARRIER) */
#endif /* defined(CONFIG_LTE_LINK_CONTROL) */
/* Provisions root CA certificate using nrf_inbuilt_key API */
static int provision_certificate(void)
#if defined(CONFIG_PROVISION_CERTIFICATES)
		int err;
		/* Delete certificates */
		nrf_sec_tag_t sec_tag = (nrf_sec_tag_t) sec_tag_list[0];
		for (nrf_key_mgnt_cred_type_t type = 0; type < 5; type++) {
			printk("Deleting certs sec_tag: %d\n", sec_tag);
			err = nrf_inbuilt_key_delete(sec_tag, type);
			printk("nrf_inbuilt_key_delete(%u, %d) => result=%d\n",
				sec_tag, type, err);
#if defined(CA_CERTIFICATE)
		/* Provision CA Certificate. */
		printk("Write ca certs sec_tag: %d\n", sec_tag);
		err = nrf_inbuilt_key_write(sec_tag,
			NRF_KEY_MGMT_CRED_TYPE_CA_CHAIN,
			CA_CERTIFICATE,
			strlen(CA_CERTIFICATE));
		if (err) {
			printk("CA_CERTIFICATE err: %d\n", err);
			return err;
#if defined (CLIENT_PRIVATE_KEY)
		/* Provision Private Certificate. */
		printk("Write private cert sec_tag: %d\n", sec_tag);
			sec_tag,
			NRF_KEY_MGMT_CRED_TYPE_PRIVATE_CERT,
			CLIENT_PRIVATE_KEY,
			strlen(CLIENT_PRIVATE_KEY));
		if (err) {
			printk("CLIENT_PRIVATE_KEY err: %d\n", err);
			return err;
#if defined(CLIENT_PUBLIC_CERTIFICATE)
		/* Provision Public Certificate. */
		printk("Write public cert sec_tag: %d\n", sec_tag);
			sec_tag,
			NRF_KEY_MGMT_CRED_TYPE_PUBLIC_CERT,
			CLIENT_PUBLIC_CERTIFICATE,
			strlen(CLIENT_PUBLIC_CERTIFICATE));
		if (err) {
			printk("CLIENT_PUBLIC_CERTIFICATE err: %d\n",err);
			return err;
#else
		int err;
		err = tls_credential_add(CONFIG_SEC_TAG,
			TLS_CREDENTIAL_CA_CERTIFICATE,
			NRF_CLOUD_CA_CERTIFICATE,
			sizeof(NRF_CLOUD_CA_CERTIFICATE));
		if (err < 0) {
			printk("Failed to register ca certificate: %d\n",err);
			return err;
			TLS_CREDENTIAL_PRIVATE_KEY,
			NRF_CLOUD_CLIENT_PRIVATE_KEY,
			sizeof(NRF_CLOUD_CLIENT_PRIVATE_KEY));
		if (err < 0) {
			printk("Failed to register private key: %d\n",err);
			return err;
			TLS_CREDENTIAL_SERVER_CERTIFICATE,
			NRF_CLOUD_CLIENT_PUBLIC_CERTIFICATE,
			sizeof(NRF_CLOUD_CLIENT_PUBLIC_CERTIFICATE));
		if (err < 0) {
			printk("Failed to register public certificate: %d\n",err);
			return err;
#endif /* defined(CONFIG_PROVISION_CERTIFICATES) */
	return 0;
void main(void)
	int err;
	printk("The MQTT simple sample started\n");
        int err_provision = provision_certificate();
        if (err_provision != 0) {
          printk("ERROR: nct_provision failure %d\n", err_provision);
          return;
        printk("err_provision = %d\n", err_provision);
	modem_configure();
	client_init(&client);
	err = mqtt_connect(&client);
	if (err != 0) {
		printk("ERROR: mqtt_connect %d\n", err);
		return;
        printk("\n CONNECTED\n");
	err = fds_init(&client);
	if (err != 0) {
		printk("ERROR: fds_init %d\n", err);
		return;
        printk("FDS init done \n");
	while (1) {
		if (err < 0) {
			printk("ERROR: poll %d\n", errno);
		err = mqtt_live(&client);
		if (err != 0) {
			printk("ERROR: mqtt_live %d\n", err);
		if ((fds.revents & POLLIN) == POLLIN) {
			err = mqtt_input(&client);
			if (err != 0) {
				printk("ERROR: mqtt_input %d\n", err);
		if ((fds.revents & POLLERR) == POLLERR) {
			printk("POLLERR\n");
		if ((fds.revents & POLLNVAL) == POLLNVAL) {
			printk("POLLNVAL\n");
	err = mqtt_disconnect(&client);
	if (err) {
		printk("Could not disconnect MQTT client. Error: %d\n", err);
Looking at errno.h, I understand the error -45 as "Operation not supported on socket".
But which operation is not supported ?
How can I fix this ? And why is it hanging out when I use peer-verify=0 or 1 ?
Thank you in advance
  • Hi Håkon,,
    I have totally removed and reinstalled the ncs/nrf repo.
    With your code and with my code with TLS (no certificates) and with hostname : test.mosquitto.org, I got the same log as you, with the mqtt_event_handler working.
    Now with my certificates for Azure IoT Hub :
    - If peer_verify=2 : I got ERROR: mqtt_connect -45 when I try to connect (both with J-Link RTT Viewer and the debug terminal)
    - If peer_verify= 1 : In my J-Link RTT Viewer, I have nothing after the "IPv4 Address found 13.95.15.251" statement. But when I use the debug terminal from Segger Embedded Studio, I got :
    After Poll
    mqtt event handler called
    MQTT connect failed 3
    After Poll
    MQTT connect failed -61
    ERROR: mqtt_input -57
    Could not disconnect MQTT client. Error: -57
    The only differences between my Azure Mqtt code and the test on mosquitto is that in prj.conf I added :
    And in my main.c, I changed the configuration to :
              tls_config->peer_verify = 2; // or 1
              tls_config->sec_tag_count = ARRAY_SIZE(sec_tag_list); //0;
              tls_config->sec_tag_list = sec_tag_list; //NULL;
     This makes sense if you do not have a root CA to verify the hostname against.
    -57 -> errno.h::ENOTCONN
    -61 -> errno.h::ECONNREFUSED.
    Have you tried to connect using your generated certificates on a PC, using mosquitto_sub / mosquitto_pub, to see if you connect successfully ?
    There's a guide on using certificates here and on stack overflow:
    http://www.steves-internet-guide.com/mosquitto_pub-sub-clients/
    https://stackoverflow.com/questions/34491799/secured-ssl-connection-with-mosquitto-broker
    HĂĄkon
  • Hi Håkon,
    I have followed what you said, and I have been able to connect to Azure IoT Hub both with my computer and the nRF9160.
    First I look at using paho_mqtt to connect to Azure IoT Hub. I found out that I had to use a username looking like this : hostname/deviceId/API_version. I also found out that as my certificates were self-signed I could not use the certificates verification, so I had to remove it (for the nRF9160 it means peer_verify=0)
    Here is my python code:
    from paho.mqtt import client as mqtt
    import ssl
    import os
    import time
    path_to_root_cert = "test2_cert.pem"
    cert_file = "mqttTest_cert.pem"
    key_file = "mqttTest_key.pem"
    device_id = "mqtt_test"
    iot_hub_name = "test-aptus"
    def on_connect(client, userdata, flags, rc):
        print("Device connected with result code: " + str(rc))
    def on_disconnect(client, userdata, rc):
        print("Device disconnected with result code: " + str(rc))
    def on_publish(client, userdata, mid):
        print("Device sent message")
    client = mqtt.Client(client_id=device_id, protocol=mqtt.MQTTv311)
    client.on_connect = on_connect
    client.on_disconnect = on_disconnect
    client.on_publish = on_publish
    # Set the username but not the password on your client
    client.username_pw_set(username=iot_hub_name+".azure-devices.net/" +
                           device_id + "/?api-version=2018-06-30", password=None)
    # Set the certificate and key paths on your client
    client.tls_set(ca_certs=path_to_root_cert, certfile=cert_file, keyfile=key_file,
                   cert_reqs=ssl.CERT_NONE, tls_version=ssl.PROTOCOL_TLSv1_2, ciphers=None)
    # Connect as before
    client.connect(iot_hub_name+".azure-devices.net", port=8883)
    client.loop_start()
    client.publish("devices/" + device_id + "/messages/events/", "{id=123}", qos=1)
    time.sleep(10) # wait
    client.loop_stop() #stop the loop
    I then added those changes to my nRF9160 project, and I added a publish call to sent a message to Azure.
    Here is my main :
    #include <zephyr.h>
    #include <stdio.h>
    #include <uart.h>
    #include <string.h>
    #include <lte_lc.h>
    //#include CONFIG_CERTIFICATES_FILE
    #define MQTT_USERNAME "test-aptus.azure-devices.net/mqtt_test/?api-version=2018-06-30"
    struct mqtt_utf8 name;
    	char buf[len + 1];
    	buf[len] = 0;
    	param.dup_flag = 0;
    		.topic = {
    		.list_count = 1,
    		.message_id = 1234
    		return -EMSGSIZE;
    	while (buf < end) {
    		if (ret < 0) {
    			int err;
    				return ret;
    				continue;
    			} else {
    				return -EIO;
    		if (ret == 0) {
    			return -EIO;
    		buf += ret;
    	return 0;
    	int err;
    	printk("mqtt event handler called \n");
    		connected = true;
    		subscribe();
    		connected = false;
    		if (err >= 0) {
    		} else {
    			if (err) {
    	} break;
    				evt->type);
    	int err;
    	if (err) {
    		return;
    	addr = result;
    	err = -ENOENT;
    		/* IPv4 Address. */
    				->sin_addr.s_addr;
    		} else {
    	broker_init();
            //printk("clientId %s \n", CONFIG_MQTT_CLIENT_ID);
            name.size = strlen(MQTT_USERNAME);
            name.utf8 = (u8_t *)MQTT_USERNAME;
    	client->user_name= &name;
              tls_config->peer_verify = 0;
              tls_config->sec_tag_count = ARRAY_SIZE(sec_tag_list); //0;//
              tls_config->sec_tag_list = sec_tag_list; //NULL;//
    	} else {
    #else
    		return -ENOTSUP;
    	return 0;
    		 * and connected.
    	} else {
    		int err;
    		int err;
    			CA_CERTIFICATE,
    		if (err) {
    			return err;
    			sec_tag,
    			CLIENT_PRIVATE_KEY,
    		if (err) {
    			return err;
    			sec_tag,
    		if (err) {
    			return err;
    #else
    		int err;
    		if (err < 0) {
    			return err;
    		if (err < 0) {
    			return err;
    		if (err < 0) {
    			return err;
    	return 0;
    void main(void)
    	int err;
            uint8_t pub[4] = {0x01, 0x02, 0x03, 0x04};
              return;
    	modem_configure();
    	if (err != 0) {
    		return;
    	if (err != 0) {
    		return;
    	while (1) {
                    data_publish(&client,1,pub,4);
    		err = poll(&fds, 1, K_SECONDS(10));
    		if (err < 0) {
                    printk("After Poll\n");
    		if (err != 0) {
    			if (err != 0) {
    	if (err) {
    Here is my log :
    err_provision = 0
    LTE Link Connected!
    Publishing:
    to topic: devices/mqtt_test/messages/events/ len: 34
    After Poll
    [mqtt_evt_handler:187] MQTT client connected!
    Subscribing to: /my/subscribe/topic len 19
    Publishing:
    After Poll
    [mqtt_evt_handler:237] SUBACK packet id: 1234
    Publishing:
    After Poll
    [mqtt_evt_handler:227] PUBACK packet id: 16457
    Publishing:
    After Poll
    [mqtt_evt_handler:227] PUBACK packet id: 18574
    Publishing:
    After Poll
    [mqtt_evt_handler:227] PUBACK packet id: 22424
    Publishing:
    After Poll
    [mqtt_evt_handler:227] PUBACK packet id: 24013
    Publishing:
    After Poll
    [mqtt_evt_handler:227] PUBACK packet id: 27520
    Publishing:
    After Poll
    [mqtt_evt_handler:227] PUBACK packet id: 30390
    Publishing:
    It is not perfect yet as it sent a lot of message before disconnect but I have at least communication working.
    Thank you very much for you help
    EDIT :
    To decrease the number of message I sent I have added a IF statement on the polling, within which I call the publish function.
    while (1) {
    		if (err < 0) {
                    if (err==0){
    err_provision = 0
    LTE Link Connected!
    After Poll
    After Poll
    Publishing:
    After Poll
    After Poll
    [mqtt_evt_handler:227] PUBACK packet id: 55663
    Publishing:
    After Poll
    After Poll
    [mqtt_evt_handler:227] PUBACK packet id: 6776
    Publishing:
    After Poll
    After Poll
    [mqtt_evt_handler:227] PUBACK packet id: 30147
    Publishing:
    After Poll
    After Poll
    [mqtt_evt_handler:227] PUBACK packet id: 55055
