cmake error in nrf9160 with nrfconnect sdk sample compile
Hi.
    we  setup a project according  nfrconnect --getting started assistand,but it fail in seggerstudio,
    we use sdk1.2.0(cd ncs/nrf
• git checkout master
• git pull
• git checkout v1.2.0
• west update)
the log is:
Loading solution at_client.emProject
Executing load commands
cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=J:/fw prj/NBIOT_NRF/NBIOTSDK/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb/8 2019-q3-update -BJ:/fw prj/NBIOT_NRF/NBIOTSDK/ncs/nrf/samples/nrf9160/at_client/build_nrf9160_pca10090ns -HJ:/fw prj/NBIOT_NRF/NBIOTSDK/ncs/nrf/samples/nrf9160/at_client -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=G:/Project Data/nrf9160 NBIOT/download tool/EmbeddedStudio_ARM_Nordic_v442a_win_x64/arm_segger_embedded_studio_v442a_win_x64_nordic/html/configure_nordic_project_menuconfig.py
Failed to create ConsoleBuf!
setActiveInputCodepage failed!
-- Using application from 'J:/fw prj/NBIOT_NRF/NBIOTSDK/ncs/nrf/samples/nrf9160/at_client'
Zephyr version: 1.14.99
-- Selected BOARD nrf9160_pca10090ns
-- Found west: C:/Python38/Scripts/west.exe (found suitable version "0.6.3", minimum required is "0.5.6")
-- Cache files will be written to: C:\Users\Administrator\AppData\Local/.cache/zephyr
CMake Error at J:/fw prj/NBIOT_NRF/NBIOTSDK/ncs/zephyr/cmake/generic_toolchain.cmake:52 (if):
  if given arguments:
    "(" "STREQUAL" "posix" ")" "OR" "(" "STREQUAL" "x86_64" ")"
  Unknown arguments specified
  J:/fw prj/NBIOT_NRF/NBIOTSDK/ncs/zephyr/cmake/app/boilerplate.cmake:452 (include)
  CMakeLists.txt:9 (include)
Project load failed
Reported error: solution load command failed (1)
    Does the compilation succeed, even with these "Failed to create ConsoleBuf!" etc. messages? Or do you get a compile error further down the log?
    I think this might be a local permission issue, but I am very uncertain, as I haven't seen that specific issue before.
    Håkon
         Today,I try again,I just rebulid solution,not do anyotherthing, now it seems buildok although it have the log with 'Failed to create ConsoleBuf!'
    Rebuilding ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-mkdir’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-mkdir’
    1> Failed to create ConsoleBuf!
    1> setActiveInputCodepage failed!
    Rebuilding ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-download’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-download’
    Rebuilding ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-update’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-update’
    Rebuilding ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-patch’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-patch’
    Rebuilding ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-configure’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-configure’
    Rebuilding ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-build’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-build’
    1> [1/152] Generating misc/generated/syscalls.json
    1> [2/146] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    1> [3/146] Generating include/generated/offsets.h
    1> [4/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    1> [5/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mempool.c.obj
    1> [6/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    1> [7/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    1> [8/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    1> [9/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    1> [10/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    1> [11/146] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/work_q.c.obj
    1> [12/146] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    1> [13/146] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
    1> [14/146] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    1> [15/146] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/power.c.obj
    1> [16/146] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/policy/policy_residency.c.obj
    1> [17/146] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/console/uart_console.c.obj
    1> [18/146] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/clock_control/nrf_power_clock.c.obj
    1> [19/146] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
    1> [20/146] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
    1> [21/146] Building C object zephyr/CMakeFiles/zephyr.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/nrf/subsys/spm/spm.c.obj
    1> [22/146] Building C object zephyr/CMakeFiles/zephyr.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/nrf/subsys/spm/secure_services.c.obj
    1> [23/146] Building C object zephyr/CMakeFiles/zephyr.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc310_platform_abort_zephyr.c.obj
    1> [24/146] Building C object zephyr/CMakeFiles/zephyr.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc310_platform_mutex_zephyr.c.obj
    1> [25/146] Generating linker.cmd
    1> [26/146] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/exc_exit.S.obj
    1> [27/146] Linking C static library zephyr\libzephyr.a
    1> [28/146] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    1> [29/146] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/isr_tables.c.obj
    1> [30/146] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    1> [31/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/pkcs5.c.obj
    1> [32/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/pkparse.c.obj
    1> [33/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/pkwrite.c.obj
    1> [34/146] Linking C static library zephyr\arch\common\libarch__common.a
    1> [35/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/platform.c.obj
    1> [36/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/platform_util.c.obj
    1> [37/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/ripemd160.c.obj
    1> [38/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/rsa_internal.c.obj
    1> [39/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/sha512.c.obj
    1> [40/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/timing.c.obj
    1> [41/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/version.c.obj
    1> [42/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/version_features.c.obj
    1> [43/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/xtea.c.obj
    1> [44/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/replacements/pem.c.obj
    1> [45/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/__/backend/cc310/replacements/entropy.c.obj
    1> [46/146] Building C object modules/nordic/CMakeFiles/..__modules__hal__nordic.dir/nrfx_glue.c.obj
    1> [47/146] Building C object modules/nordic/CMakeFiles/..__modules__hal__nordic.dir/nrfx/drivers/src/nrfx_nvmc.c.obj
    1> [48/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    1> [49/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    1> [50/146] Linking C static library modules\nordic\lib..__modules__hal__nordic.a
    1> [51/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    1> [52/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    1> [53/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    1> [54/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    1> [55/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    1> [56/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    1> [57/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    1> [58/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    1> [59/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    1> [60/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    1> [61/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    1> [62/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    1> [63/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    1> [64/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    1> [65/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    1> [66/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread_abort.c.obj
    1> [67/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work_q.c.obj
    1> [68/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/smp.c.obj
    1> [69/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    1> [70/146] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    1> [71/146] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    1> [72/146] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    1> [73/146] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    1> [74/146] Linking C static library zephyr\kernel\libkernel.a
    1> [75/146] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    1> [76/146] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    1> [77/146] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    1> [78/146] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    1> [79/146] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    1> [80/146] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    1> [81/146] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    1> [82/146] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    1> [83/146] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    1> [84/146] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    1> [85/146] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/CMakeFiles/arch__arm__core__aarch32__cortex_m__mpu.dir/arm_core_mpu.c.obj
    1> [86/146] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/CMakeFiles/arch__arm__core__aarch32__cortex_m__mpu.dir/arm_mpu.c.obj
    1> [87/146] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    1> [88/146] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    1> [89/146] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\mpu\libarch__arm__core__aarch32__cortex_m__mpu.a
    1> [90/146] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
    1> [91/146] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/CMakeFiles/arch__arm__core__aarch32__cortex_m__tz.dir/arm_core_tz.c.obj
    1> [92/146] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    1> [93/146] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    1> [94/146] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    1> [95/146] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\tz\libarch__arm__core__aarch32__cortex_m__tz.a
    1> [96/146] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
    1> [97/146] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    1> [98/146] Linking C static library zephyr\lib\posix\liblib__posix.a
    1> [99/146] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    1> [100/146] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    1> [101/146] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    1> [102/146] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    1> [103/146] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
    1> [104/146] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    1> [105/146] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    1> [106/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/aesni.c.obj
    1> [107/146] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
    1> [108/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/arc4.c.obj
    1> [109/146] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
    1> [110/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/aria.c.obj
    1> [111/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/asn1parse.c.obj
    1> [112/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/asn1write.c.obj
    1> [113/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/base64.c.obj
    1> [114/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/bignum.c.obj
    1> [115/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/blowfish.c.obj
    1> [116/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/camellia.c.obj
    1> [117/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/cipher.c.obj
    1> [118/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/cipher_wrap.c.obj
    1> [119/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/ctr_drbg.c.obj
    1> [120/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/des.c.obj
    1> [121/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/dhm.c.obj
    1> [122/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/ecjpake.c.obj
    1> [123/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/entropy_poll.c.obj
    1> [124/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/error.c.obj
    1> [125/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/gcm.c.obj
    1> [126/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/havege.c.obj
    1> [127/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/hkdf.c.obj
    1> [128/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/hmac_drbg.c.obj
    1> [129/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/md.c.obj
    1> [130/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/md_wrap.c.obj
    1> [131/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/md2.c.obj
    1> [132/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/md4.c.obj
    1> [133/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/md5.c.obj
    1> [134/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/memory_buffer_alloc.c.obj
    1> [135/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/nist_kw.c.obj
    1> [136/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/oid.c.obj
    1> [137/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/padlock.c.obj
    1> [138/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/pk.c.obj
    1> [139/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/pk_wrap.c.obj
    1> [140/146] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/J_/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/mbedtls/library/pkcs12.c.obj
    1> [141/146] Linking C static library modules\nrfxlib\nrf_security\src\mbedtls\libmbedtls_base_vanilla.a
    1> [142/146] Linking C executable zephyr\zephyr_prebuilt.elf
    1> Memory region         Used Size  Region Size  %age Used
    1>            FLASH:         32 KB        48 KB     66.67%
    1>             SRAM:        5420 B        64 KB      8.27%
    1>         IDT_LIST:          40 B         2 KB      1.95%
    1> [143/146] Generating linker_pass_final.cmd
    1> [144/146] Generating isr_tables.c
    1> [145/146] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    1> [146/146] Linking C executable zephyr\zephyr.elf
    Rebuilding ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-install’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-install’
    Rebuilding ‘modules/nrf/samples/CMakeFiles/spm_subimage-complete’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘modules/nrf/samples/CMakeFiles/spm_subimage-complete’
    Rebuilding ‘modules/nrf/samples/CMakeFiles/spm_subimage’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/samples/spm_subimage-prefix/src/spm_subimage-stamp/spm_subimage-done’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘spm/zephyr/zephyr.hex’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘spm/zephyr/zephyr.elf’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘spm/libspmsecureentries.a’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/samples/spm_subimage’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘zephyr/include/generated/driver-validation.h’
    Rebuilding ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘zephyr/include/generated/kobj-types-enum.h’
    Rebuilding ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘J:/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘J:/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘zephyr/misc/generated/syscalls.json’
    Rebuilding ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘zephyr/include/generated/syscall_list.h’
    Rebuilding ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
    1> Compiling ‘offsets.c’
    Rebuilding ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘zephyr/include/generated/offsets.h’
    Rebuilding ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/zephyr_generated_headers’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_app’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’
    1> Compiling ‘main.c’
    1> Archiving ‘libapp.a’
    Rebuilding ‘J:/fw_prj/NBIOT_NRF/NBIOTSDK/ncs/zephyr/misc/empty_file.c’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_..__modules__hal__nordic’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_..__nrf__lib__at_cmd’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_..__nrf__lib__at_host’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_..__nrf__lib__at_notif’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_..__nrf__lib__bsdlib’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_..__nrf__lib__fatal_error’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_..__nrf__subsys__fw_info’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_arch__arm__core__aarch32’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m__cmse’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_arch__arm__core__aarch32__cortex_m__mpu’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_arch__common’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_drivers__entropy’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_drivers__gpio’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_drivers__serial’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_kernel’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_lib__libc__minimal’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_lib__posix’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_soc__arm__common__cortex_m’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_subsys__net’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_subsys__net__ip’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_subsys__random’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_zephyr’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/linker.cmd’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘zephyr/linker.cmd’
    Rebuilding ‘zephyr/CMakeFiles/linker_script_target’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/linker_script_target’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘cmake_object_order_depends_target_zephyr_prebuilt’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/libzephyr.a’ from solution ‘build’ in configuration ‘Common’
    1> Compiling ‘crc16_sw.c’
    2> Compiling ‘crc32_sw.c’
    1> Compiling ‘crc8_sw.c’
    2> Compiling ‘crc7_sw.c’
    1> Compiling ‘dec.c’
    2> Compiling ‘fdtable.c’
    1> Compiling ‘hex.c’
    2> Compiling ‘mempool.c’
    1> Compiling ‘printk.c’
    2> Compiling ‘onoff.c’
    1> Compiling ‘rb.c’
    2> Compiling ‘sem.c’
    1> Compiling ‘thread_entry.c’
    2> Compiling ‘timeutil.c’
    1> Compiling ‘work_q.c’
    2> Compiling ‘assert.c’
    1> Compiling ‘configs.c’
    2> Compiling ‘soc.c’
    1> Compiling ‘power.c’
    2> Compiling ‘validate_base_addresses.c’
    1> Compiling ‘addr_utils.c’
    2> Compiling ‘socket_offload.c’
    2> Compiling ‘policy_residency.c’
    1> Compiling ‘uart_console.c’
    2> Compiling ‘nrf_power_clock.c’
    1> Compiling ‘sys_clock_init.c’
    2> Compiling ‘nrf_rtc_timer.c’
    1> Compiling ‘secure_services_ns.c’
    Rebuilding ‘zephyr/arch/common/libarch__common.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libzephyr.a’
    2> Compiling ‘isr_tables.c’
    1> Compiling ‘sw_isr_common.c’
    Rebuilding ‘zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libarch__common.a’
    2> Assembling ‘exc_exit.S’
    1> Assembling ‘swap_helper.S’
    2> Assembling ‘cpu_idle.S’
    1> Assembling ‘fault_s.S’
    2> Assembling ‘nmi_on_reset.S’
    1> Assembling ‘isr_wrapper.S’
    2> Compiling ‘swap.c’
    1> Compiling ‘irq_manage.c’
    2> Compiling ‘thread.c’
    1> Compiling ‘fatal.c’
    2> Compiling ‘nmi.c’
    1> Compiling ‘prep_c.c’
    Rebuilding ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libarch__arm__core__aarch32.a’
    2> Assembling ‘vector_table.S’
    1> Assembling ‘reset.S’
    2> Compiling ‘fault.c’
    1> Compiling ‘scb.c’
    2> Compiling ‘irq_init.c’
    1> Compiling ‘thread_abort.c’
    Rebuilding ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/libarch__arm__core__aarch32__cortex_m__mpu.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libarch__arm__core__aarch32__cortex_m.a’
    2> Compiling ‘arm_core_mpu.c’
    1> Compiling ‘arm_mpu.c’
    Rebuilding ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libarch__arm__core__aarch32__cortex_m__mpu.a’
    2> Compiling ‘arm_core_cmse.c’
    Rebuilding ‘zephyr/lib/libc/minimal/liblib__libc__minimal.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libarch__arm__core__aarch32__cortex_m__cmse.a’
    2> Compiling ‘atoi.c’
    1> Compiling ‘strtol.c’
    2> Compiling ‘strtoul.c’
    1> Compiling ‘malloc.c’
    2> Compiling ‘bsearch.c’
    1> Compiling ‘exit.c’
    2> Compiling ‘strncasecmp.c’
    1> Compiling ‘strstr.c’
    2> Compiling ‘string.c’
    1> Compiling ‘strspn.c’
    2> Compiling ‘prf.c’
    1> Compiling ‘stdout_console.c’
    2> Compiling ‘sprintf.c’
    1> Compiling ‘fprintf.c’
    2> Compiling ‘gmtime.c’
    Rebuilding ‘zephyr/lib/posix/liblib__posix.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘liblib__libc__minimal.a’
    2> Compiling ‘pthread_common.c’
    Rebuilding ‘zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘liblib__posix.a’
    2> Compiling ‘arm_mpu_regions.c’
    Rebuilding ‘zephyr/subsys/net/libsubsys__net.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libsoc__arm__common__cortex_m.a’
    2> Compiling ‘buf.c’
    Rebuilding ‘zephyr/subsys/net/ip/libsubsys__net__ip.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libsubsys__net.a’
    2> Compiling ‘net_core.c’
    1> Compiling ‘net_if.c’
    2> Compiling ‘utils.c’
    Rebuilding ‘zephyr/subsys/random/libsubsys__random.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libsubsys__net__ip.a’
    2> Compiling ‘rand32_entropy_device.c’
    Rebuilding ‘zephyr/drivers/gpio/libdrivers__gpio.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libsubsys__random.a’
    2> Compiling ‘gpio_nrfx.c’
    Rebuilding ‘zephyr/drivers/serial/libdrivers__serial.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libdrivers__gpio.a’
    2> Compiling ‘uart_nrfx_uarte.c’
    Rebuilding ‘zephyr/drivers/entropy/libdrivers__entropy.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libdrivers__serial.a’
    2> Compiling ‘entropy_cc310.c’
    Rebuilding ‘modules/nrf/lib/bsdlib/lib..__nrf__lib__bsdlib.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘libdrivers__entropy.a’
    2> Compiling ‘bsdlib.c’
    1> Compiling ‘bsd_os.c’
    2> Compiling ‘nrf91_sockets.c’
    Rebuilding ‘modules/nrf/lib/at_cmd/lib..__nrf__lib__at_cmd.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘lib..__nrf__lib__bsdlib.a’
    2> Compiling ‘at_cmd.c’
    Rebuilding ‘modules/nrf/lib/at_notif/lib..__nrf__lib__at_notif.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘lib..__nrf__lib__at_cmd.a’
    2> Compiling ‘at_notif.c’
    Rebuilding ‘modules/nrf/lib/at_host/lib..__nrf__lib__at_host.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘lib..__nrf__lib__at_notif.a’
    2> Compiling ‘at_host.c’
    Rebuilding ‘modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘lib..__nrf__lib__at_host.a’
    2> Compiling ‘fatal_error.c’
    Rebuilding ‘modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘lib..__nrf__lib__fatal_error.a’
    2> Compiling ‘fw_info.c’
    Rebuilding ‘modules/nordic/lib..__modules__hal__nordic.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘lib..__nrf__subsys__fw_info.a’
    2> Compiling ‘system_nrf9160.c’
    1> Compiling ‘nrfx_glue.c’
    2> Compiling ‘nrfx_nvmc.c’
    Rebuilding ‘zephyr/kernel/libkernel.a’ from solution ‘build’ in configuration ‘Common’
    1> Archiving ‘lib..__modules__hal__nordic.a’
    2> Compiling ‘device.c’
    1> Compiling ‘errno.c’
    2> Compiling ‘fatal.c’
    1> Compiling ‘idle.c’
    2> Compiling ‘init.c’
    1> Compiling ‘mailbox.c’
    2> Compiling ‘mem_slab.c’
    1> Compiling ‘mempool.c’
    2> Compiling ‘msg_q.c’
    1> Compiling ‘mutex.c’
    2> Compiling ‘pipes.c’
    1> Compiling ‘queue.c’
    2> Compiling ‘sched.c’
    1> Compiling ‘sem.c’
    2> Compiling ‘stack.c’
    1> Compiling ‘system_work_q.c’
    2> Compiling ‘version.c’
    2> Compiling ‘smp.c’
    1> Compiling ‘timeout.c’
    2> Compiling ‘timer.c’
    1> Compiling ‘poll.c’
    1> Archiving ‘libkernel.a’
    Rebuilding ‘zephyr/zephyr_prebuilt.elf’ from solution ‘build’ in configuration ‘Common’
    1> Compiling ‘empty_file.c’
    1> Linking ‘zephyr_prebuilt.elf’
    1>            FLASH:       73960 B       976 KB      7.40%
    1>             SRAM:       37948 B       128 KB     28.95%
    1>         IDT_LIST:         120 B         2 KB      5.86%
    Rebuilding ‘zephyr/linker_pass_final.cmd’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘zephyr/linker_pass_final.cmd’
    Rebuilding ‘zephyr/CMakeFiles/linker_pass_final_script_target’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/linker_pass_final_script_target’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/isr_tables.c’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘zephyr/isr_tables.c’
    Rebuilding ‘cmake_object_order_depends_target_zephyr_final’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/zephyr.elf’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/zephyr.hex’ from solution ‘build’ in configuration ‘Common’
    1> Linking ‘zephyr.elf’
    1> Post-link command
    Rebuilding ‘zephyr/merged.hex’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘zephyr/merged.hex’
    Rebuilding ‘CMakeFiles/merged_hex’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘merged_hex’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/arch/common/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/arch/arch/arm/core/aarch32/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/arch/arch/arm/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/arch/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/lib/libc/minimal/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/lib/libc/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/lib/posix/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/lib/gui/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/lib/os/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/lib/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/soc/arm/common/cortex_m/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/soc/arm/nordic_nrf/nrf91/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/soc/arm/nordic_nrf/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/soc/arm/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/boards/boards/arm/nrf9160_pca10090ns/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/boards/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/ext/lib/crypto/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/ext/lib/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/ext/hal/cmsis/Core/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/ext/hal/cmsis/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/ext/hal/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/ext/debug/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/ext/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/debug/tracing/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/debug/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/logging/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/fs/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/net/l2/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/net/ip/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/net/lib/utils/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/net/lib/sockets/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/net/lib/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/net/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/random/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/storage/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/fb/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/power/policy/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/power/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/stats/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/testsuite/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/canbus/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/subsys/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/drivers/console/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/drivers/interrupt_controller/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/drivers/clock_control/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/drivers/gpio/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/drivers/serial/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/drivers/net/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/drivers/entropy/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/drivers/timer/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/drivers/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/ext/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/lib/bin/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/lib/bsdlib/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/lib/at_cmd/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/lib/at_notif/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/lib/at_host/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/lib/flash_patch/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/lib/fatal_error/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/lib/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/samples/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/subsys/net/lib/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/subsys/net/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/subsys/nonsecure/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/subsys/fw_info/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/subsys/debug/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/subsys/partition_manager/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/subsys/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/drivers/net/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/drivers/hw_cc310/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/drivers/entropy/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/drivers/gps/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/drivers/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/tests/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/segger/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/mbedtls/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/mcuboot/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/mcumgr/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/tinycbor/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrfxlib/bsdlib/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrfxlib/crypto/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrfxlib/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/civetweb/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/fatfs/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nordic/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/st/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/libmetal/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/loramac-node/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/lvgl/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/nrf_hw_models/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/open-amp/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/openthread/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/littlefs/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/mipi-sys-t/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘modules/canopennode/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/kernel/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/cmake/flash/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/cmake/usage/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/cmake/reports/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘all’ from solution ‘build’ in configuration ‘Common’
    Rebuilding ‘zephyr/merged.hex’ from solution ‘at_client’ in configuration ‘Common’
    Build complete
