nrf6310 device firmware update is not working
We are using nRF51822 evaluation kit. Actually we are trying to know how the device firmware upgrade is working. As mentioned in the nrf51 sdk manual, we did flashing the device firmware update application for nrf6310 to the pca10001, since we don't have sample code for pca10001.
Then following the readme file in the C:\Keil\ARM\Device\Nordic\nrf51822_v4.4.0.30888_Backup_1\Board\nrf6310\device_firmware_updates\experimental\ble_dfu_send_hex\readme.txt we installed,
a. IronPython v2.7.4 (2.7.3 in document) b. .Net Framework 4.5
c. Master Control Panel and Master Emulator API
Then connected the dongle and in the command window we entered the command as mentioned,
C:\Users\Public>ipy main.py -f ble_app_hrs.hex -n Embdes_HRM -a C52B0F4DF8E9 File main.py does not exist.
Then we gave the path of the main.py as follows,
[b]C:\Users\Public>ipy "C:\Program Files\IronPython 2.7\Lib\lib2to3\main.py" -f b e_app_hrs.hex -n Embdes_HRM -a C52B0F4DF8E9 Traceback (most recent call last): File "C:\Program Files\IronPython 2.7\Lib\lib2to3\main.py", line 14, in ValueError: Attempted relative import in non-package[/b]
so please tell how to overcome this, we need to know how the device firmware upgrade application is working on ble.
Regards, Balaji
  • Hi Hung Bui,
    Thanks for your reply, now i can successfully update the firmware over the air. Now i need some information regarding ble stack event, which event updates the device name when we update it from the master control panel? whether the changed device name passed over air or it is changed in master control panel itself?
  • Hi Balaji,
    You will have BLE_GATTS_EVT_WRITE event from the stack that you can catch in the on_ble_evt() function in main.c. You can refer to ble_bas.c to know how to handle the event.
    For a better devzone knownlead base, I would suggest you to accept an answer if it fixes the issue at the first message and then create a new question if you have other questions. This way it's much easier for other customer to find the issue and the solution cope with that.
