nRF5340 - UART programming option
I'm in the process of developing the HW board for a nRF5340-based product.
I need the customer could update the firmware using a serial port (USB or Bluetooth is not acceptable).
Is it possible to do that ? Where to found documentation on this ?
Gabriele
  • Hi Gabriele,
    I'm sorry that it's been a long time and you still having issue with FOTA on nRF53.
    We now have better documentation for nRF53 including FOTA instruction.
    Please have a look here:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/ug_nrf5340.html#fota-upgrades
    The instruction is for FOTA using BLE. And I think you should test first using this transport. Just to make sure smpsvr is working fine. After that you can change CONFIG_MCUMGR_SMP_BT to CONFIG_MCUMGR_SMP_UART to support UART (and add CONFIG_SERIAL=y)
  • Thank you for your reply.
    I think the problem was due to flashing non signed binary for smp_srv.
    Now I'm able to
    a) Build and flash mcuboot in bootloadr_partition (using JLink)
    b) Build and flash smp_svr in slot0_partition (using JLink)
    c) Build and flash MyApp in slot1_partition (using DFU)
    This is the resulting mcumgr image list
    Images:
     image=0 slot=0
        version: 0.0.0
        bootable: true
        flags: active confirmed
        hash: 6645ebafd4a33787a52b5f76c18f9b66038a25b3413238e22d2432e6bba47677
     image=0 slot=1
        version: 1.3.0
        bootable: true
        flags:
        hash: 17563829483019977c328c7c89114dcb2f872c65b9b5c8d663011e617b9915ad
    Split status: N/A (0)
    Now I see a problem.
    On system restart I get out of UART
     *** Booting Zephyr OS build v2.3.0-rc1-ncs1  ***
     [00:00:00.003,051] <inf> mcuboot: Starting bootloader
     [00:00:00.009,246] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
     [00:00:00.019,348] <inf> mcuboot: Boot source: none
     [00:00:00.024,810] <inf> mcuboot: Swap type: none
     [00:00:00.138,214] <inf> mcuboot: Bootloader chainload address offset: 0x10000
     [00:00:00.146,026] <inf> mcuboot: Jumping to the first image slot
     [00:00:00.004,425] <inf> smp_sample: build time: Sep 11 2020 13:29:22
    The smp_srv is running, not MyApp !
    How to switch from smp_srv to MyApp, and viceversa ?
    Thank you
    After you have flashed the smp_svr you can use the mcumgr to DFU your image .
    After you have your image list with 2 images, you need to either test or confirm the image and trigger a reset for your app to run.
    Call `Image test <image sha>` or `image confirm <image sha>` and then do a reset. Your application should run after that.
    The swap mechanism went well!
    After a "image confirm" the new image (My App) is the active one, persistently.
    But what ? I cannot upload a brand new image.
    How to restore the DFU functionality ?
  • Hi Gabriele,
    You would need to integrate smpsvr into your application.
    It's pretty simple. You can just follow the instruction here.
    The instruction is for BLE , to do UART DFU you use CONFIG_MCUMGR_SMP_UART = y instead of CONFIG_MCUMGR_SMP_BT.
    In your main.c you need to call
    os_mgmt_register_group();
    img_mgmt_register_group();
    In the example, I have prepared the .bin files that you can use to update. Note that after you do :
    mcumgr -t 20 --conntype serial --connstring=COM37 image upload app_update_new.bin
    You still need to confirm the image "image confirm <img_sha>" and then do a reset. I haven't looked into how you can confirm the image and reset automatically yet.
    peripheral_lbs_dfu_uart.zip
