NRF_LOG_INFO: Only the last log statement is printed out
I inherited a Nordic project that is running on the 52832 board with the 15.3 version of the SDK.  The project uses CLI, TWI, and logging.  The developer has to jump through hoops to get all 3 functioning at the same time.  I am now expanding the project.  The issue.  NRF_LOG_INFO works fine if I provide a constant string (e.q. NRF_LOG_INFO("Hello world");)
However, the minute I create a generic logging utility which uses non-stack memory (using data segment memory - statically declared array), only the last logged data is printed several times.
so something like
XXX_LOG_PRINTF(LOG_INFO, "sensor initialization start.");
.... some more code here.....
XXX_LOG_PRINTF(LOG_INFO, "sensor initialization complete.");
My logging utility can take variable length arguments, etc.  So the "constant strings" you see in the calls above gets copied to a statically declared string which gets passed to the Nordic logging utility.
I only see the last line printed twice.  I have turned off deferred, so I am at a loss.
I have read the chapter on logging and think I understand the buffering concept on the front and back end.   I have tried messing with the sdk_config.h to no avail.   Here are what I think are relevant:
All my CLI commands and output work great.
#define NRF_LOG_DEFERRED 0
#define NRF_LOG_CLI_CMDS 1
#define NRF_LOG_FILTERS_ENABLED 0
The ways I have tried to log the info:
NRF_LOG_INFO("%s\n", NRF_LOG_PUSH((char *)pLogMsg));
or
NRF_LOG_RAW_INFO
I am running on Ubuntu linux, using minicom (which works great for constant strings and cli).  Segger, RTT or any other IDE is not an option.  This must be done via UART<
Please let me know if you need additional info to assist in this.
Jim
  • I just tested the unmodified CLI example from the SDK, and it seems to work there as well, only adding two lines to the main() function:
        NRF_LOG_RAW_INFO("Command Line Interface example started.\n");
        NRF_LOG_RAW_INFO("Please press the Tab key to see all available commands.\n");
        test_log("helloWorld");
        test_log("goodbyeWorld");
    with the same test_log() function as before. It works both with NRF_LOG_DEFERRED set to 0 and 1.
    Can you please test with the unmodified CLI example and these addons?
    Can you show me how you print your logging in your case when it only prints the last logged message? Is it possible to share the project so that I can reproduce it?
    Edvin
  • Do you see the difference in my design and your perturbation of it? Why did you stray from my example?  You are not copying the string into a local buffer.  Please follow my example.  I am not sure if I am having trouble communicating the issue, but it seems that you always adjust the example to simplify it.  That is the problem, you are simplifying the situation.  Can you see in my example where I copy over the string?  In actuality, there is a lot more formatting going on in my logging routine which requires this.  Please follow my example above without modification.  Otherwise, resolving this issue will take weeks.  There is talk moving away from Nordic so this may be a moot point.
  • >>Can you show me how you print your logging in your case when it only prints the last logged message? >>Is it possible to share the project so that I can reproduce it?
        I did if you followed the example above but you chose to modify it....Please you the code below as shown.....
    static char message[256];
    void logMsg(const char *pMessage)
        int cnt = 0;
        memset(message, 0, 256);
        cnt = snprintf(message, 255, pMessage);
        message[cnt-1] = '\0';
        NRF_LOG_RAW_INFO("%s\n", message);
        return;
  • you are passing two different pointers in your example.  whereas my example is using the same pointer.  If deferred is set to 0, this should not be a problem.  Even if deferred is on, and my understanding of your logging is correct, this should also not be a problem as long as I don't exceed any queue or buffer size.  I am guessing your logging mechanism is not properly copying the incoming data.
  • I created an example where you can see the difference in your method and mine.  I've also included the output.  You can see my original logger just duplicates the string, where yours will work.  However, passing const strings is not the purpose of my logging.
     * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdio.h>
    #include <stdbool.h>
    #include <stddef.h>
    #include "nrf.h"
    #include "nrf_drv_clock.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "app_timer.h"
    #include "fds.h"
    #include "app_error.h"
    #include "app_util.h"
    #include "nrf_cli.h"
    #include "nrf_cli_rtt.h"
    #include "nrf_cli_types.h"
    #include "boards.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_log_backend_flash.h"
    #include "nrf_fstorage_nvmc.h"
    #include "nrf_mpu_lib.h"
    #include "nrf_stack_guard.h"
    #if defined(APP_USBD_ENABLED) && APP_USBD_ENABLED
    #define CLI_OVER_USB_CDC_ACM 1
    #else
    #define CLI_OVER_USB_CDC_ACM 0
    #if CLI_OVER_USB_CDC_ACM
    #include "nrf_cli_cdc_acm.h"
    #include "nrf_drv_usbd.h"
    #include "app_usbd_core.h"
    #include "app_usbd.h"
    #include "app_usbd_string_desc.h"
    #include "app_usbd_cdc_acm.h"
    #endif //CLI_OVER_USB_CDC_ACM
    #if defined(TX_PIN_NUMBER) && defined(RX_PIN_NUMBER)
    #define CLI_OVER_UART 1
    #else
    #define CLI_OVER_UART 0
    #if CLI_OVER_UART
    #include "nrf_cli_uart.h"
    /* If enabled then CYCCNT (high resolution) timestamp is used for the logger. */
    #define USE_CYCCNT_TIMESTAMP_FOR_LOG 0
    /**@file
     * @defgroup CLI_example main.c
    #if NRF_LOG_BACKEND_FLASHLOG_ENABLED
    NRF_LOG_BACKEND_FLASHLOG_DEF(m_flash_log_backend);
    #if NRF_LOG_BACKEND_CRASHLOG_ENABLED
    NRF_LOG_BACKEND_CRASHLOG_DEF(m_crash_log_backend);
    /* Counter timer. */
    APP_TIMER_DEF(m_timer_0);
    /* Declared in demo_cli.c */
    extern uint32_t m_counter;
    extern bool m_counter_active;
     * @brief Enable power USB detection
     * Configure if example supports USB port connection
    #ifndef USBD_POWER_DETECTION
    #define USBD_POWER_DETECTION true
    static void usbd_user_ev_handler(app_usbd_event_type_t event)
        switch (event)
            case APP_USBD_EVT_STOPPED:
                app_usbd_disable();
            case APP_USBD_EVT_POWER_DETECTED:
                if (!nrf_drv_usbd_is_enabled())
                    app_usbd_enable();
            case APP_USBD_EVT_POWER_REMOVED:
                app_usbd_stop();
            case APP_USBD_EVT_POWER_READY:
                app_usbd_start();
     * @brief Command line interface instance
    #define CLI_EXAMPLE_LOG_QUEUE_SIZE  (10)
    NRF_CLI_CDC_ACM_DEF(m_cli_cdc_acm_transport);
    NRF_CLI_DEF(m_cli_cdc_acm,
                "usb_cli:~$ ",
                &m_cli_cdc_acm_transport.transport,
                '\r',
                CLI_EXAMPLE_LOG_QUEUE_SIZE);
    #if CLI_OVER_UART
    NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16);
    NRF_CLI_DEF(m_cli_uart,
                "uart_cli:~$ ",
                &m_cli_uart_transport.transport,
                '\r',
    NRF_CLI_RTT_DEF(m_cli_rtt_transport);
    NRF_CLI_DEF(m_cli_rtt,
                "rtt_cli:~$ ",
                &m_cli_rtt_transport.transport,
                '\n',
    static void timer_handle(void * p_context)
        UNUSED_PARAMETER(p_context);
        if (m_counter_active)
            m_counter++;
            NRF_LOG_RAW_INFO("counter = %d\n", m_counter);
    static void cli_start(void)
        ret_code_t ret;
        ret = nrf_cli_start(&m_cli_cdc_acm);
        APP_ERROR_CHECK(ret);
    #if CLI_OVER_UART
        ret = nrf_cli_start(&m_cli_uart);
        ret = nrf_cli_start(&m_cli_rtt);
    static void cli_init(void)
        ret_code_t ret;
        ret = nrf_cli_init(&m_cli_cdc_acm, NULL, true, true, NRF_LOG_SEVERITY_INFO);
    #if CLI_OVER_UART
        nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
        uart_config.pseltxd = TX_PIN_NUMBER;
        uart_config.pselrxd = RX_PIN_NUMBER;
        uart_config.hwfc    = NRF_UART_HWFC_DISABLED;
        ret = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
        ret = nrf_cli_init(&m_cli_rtt, NULL, true, true, NRF_LOG_SEVERITY_INFO);
    static void usbd_init(void)
        ret_code_t ret;
        static const app_usbd_config_t usbd_config = {
            .ev_handler = app_usbd_event_execute,
            .ev_state_proc = usbd_user_ev_handler
        ret = app_usbd_init(&usbd_config);
        app_usbd_class_inst_t const * class_cdc_acm =
                app_usbd_cdc_acm_class_inst_get(&nrf_cli_cdc_acm);
        ret = app_usbd_class_append(class_cdc_acm);
        if (USBD_POWER_DETECTION)
            ret = app_usbd_power_events_enable();
            NRF_LOG_INFO("No USB power detection enabled\nStarting USB now");
            app_usbd_enable();
            app_usbd_start();
        /* Give some time for the host to enumerate and connect to the USB CDC port */
        nrf_delay_ms(1000);
    static void cli_process(void)
        nrf_cli_process(&m_cli_cdc_acm);
    #if CLI_OVER_UART
        nrf_cli_process(&m_cli_uart);
        nrf_cli_process(&m_cli_rtt);
    static void flashlog_init(void)
        ret_code_t ret;
        int32_t backend_id;
        ret = nrf_log_backend_flash_init(&nrf_fstorage_nvmc);
        backend_id = nrf_log_backend_add(&m_flash_log_backend, NRF_LOG_SEVERITY_WARNING);
        APP_ERROR_CHECK_BOOL(backend_id >= 0);
        nrf_log_backend_enable(&m_flash_log_backend);
        backend_id = nrf_log_backend_add(&m_crash_log_backend, NRF_LOG_SEVERITY_INFO);
        nrf_log_backend_enable(&m_crash_log_backend);
    static inline void stack_guard_init(void)
        APP_ERROR_CHECK(nrf_mpu_lib_init());
        APP_ERROR_CHECK(nrf_stack_guard_init());
    uint32_t cyccnt_get(void)
        return DWT->CYCCNT;
        int cnt = 0;
        NRF_LOG_INFO("%s\n", NRF_LOG_PUSH(message));
        return;
    void logMsg2(const char *pMessage)
        NRF_LOG_RAW_INFO("%s\n", pMessage);
        return;
        ret_code_t ret;
        char buff[1024];
        if (USE_CYCCNT_TIMESTAMP_FOR_LOG)
            CoreDebug->DEMCR |= CoreDebug_DEMCR_TRCENA_Msk;
            DWT->CTRL |= DWT_CTRL_CYCCNTENA_Msk;
            DWT->CYCCNT = 0;
            APP_ERROR_CHECK(NRF_LOG_INIT(cyccnt_get, 64000000));
            APP_ERROR_CHECK(NRF_LOG_INIT(app_timer_cnt_get));
        ret = nrf_drv_clock_init();
        ret = app_timer_init();
        ret = app_timer_create(&m_timer_0, APP_TIMER_MODE_REPEATED, timer_handle);
        ret = app_timer_start(m_timer_0, APP_TIMER_TICKS(1000), NULL);
        cli_init();
        usbd_init();
        ret = fds_init();
        UNUSED_RETURN_VALUE(nrf_log_config_load());
        cli_start();
        flashlog_init();
        stack_guard_init();
        snprintf(buff, 1023, "NRF_LOG_DEFERRED=%d\n",NRF_LOG_DEFERRED);
        logMsg(buff);
        logMsg("Please press the Tab key to see all available commands.\n");
        logMsg2("Test Print #1 - data seg pointer\n");
        logMsg2("Test Print #2 - data seg pointer\n");
        while (true)
            UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    #if CLI_OVER_USB_CDC_ACM && APP_USBD_CONFIG_EVENT_QUEUE_ENABLE
            while (app_usbd_event_queue_process())
                /* Nothing to do */
            cli_process();
    [00:00:00.000,000] <info> stack_guard: Stack Guard (128 bytes): 0x2000E000-0x2000E07F (total stack size: 8192 bytes, usable stack area: 8064 bytes)
    [00:00:00.000,122] <info> app: Please press the Tab key to see all available commands.
    [00:00:00.000,244] <info> app: Please press the Tab key to see all available commands.
    uart_cli:~$
