AF_LTE socket and nrfxlib
After many hours of successful LTE connections and using the AF_LTE socket just fine (many creates, many send/receive, many closes), my application now hangs on a call to socket(AF_LTE,0,NPROTO_AT). Hung, as in the call to socket() does not return. I have no idea where to look to resolve this. Is the nrfxlib code available for review? I'll sign an NDA if I can get my eyes on it. I've spent way too much time trying to code around strange behavior in nrfxlib/nrf/zephyr.
This is running on nrf9160 DK, modem fw v1.1.1 and NCS v1.2.0
Mike
  • Your explanation for tracing is a little over my head as I don't have a great understanding of the board. It was much easier for me to chop out the pieces of my application that demonstrate the problem. I have included the code that illustrates the issue, and it does it consistently in under 5 minutes. The code creates a thread that listens for status notifications from the modem, while the main thread repeatedly turns modem on and off with some sleeps in between. In my application the sleeps are much longer, but I sped them up to demonstrate the problem in a reasonable amount of time.
    The output shows the application hanging at the end:
    *** Booting Zephyr OS build v2.1.99-ncs1  ***
    [00:00:00.188] opened socket, fd 1
    [00:00:00.191] send[1]: AT+CMEE=1
    [00:00:00.194] read[1]: OK
    [00:00:00.197] send[1]: AT+CFUN?
    [00:00:00.200] read[1]: +CFUN: 0
    [00:00:00.203] read[1]: OK
    [00:00:00.206] send[1]: AT%XSYSTEMMODE?
    [00:00:00.216] read[1]: %XSYSTEMMODE: 1,0,0,0
    [00:00:00.220] read[1]: OK
    [00:00:00.222] send[1]: AT+CGMI
    [00:00:00.231] read[1]: Nordic Semiconductor ASA
    [00:00:00.236] read[1]: OK
    [00:00:00.238] send[1]: AT+CGMM
    [00:00:00.248] read[1]: nRF9160-SICA
    [00:00:00.251] read[1]: OK
    [00:00:00.253] send[1]: AT+CGMR
    [00:00:00.263] read[1]: mfw_nrf9160_1.1.1
    [00:00:00.266] read[1]: OK
    [00:00:00.269] send[1]: AT+CGSN
    [00:00:00.278] read[1]: 352656100038754
    [00:00:00.282] read[1]: OK
    [00:00:00.284] send[1]: AT+CIMI
    [00:00:00.293] read[1]: +CME ERROR: 0
    [00:00:00.297] send[1]: AT+CEREG=5
    [00:00:00.306] read[1]: OK
    [00:00:00.309] send[1]: AT%CESQ=1
    [00:00:00.318] read[1]: OK
    [00:00:00.321] send[1]: AT+CGEREP=1
    [00:00:00.330] read[1]: OK
    [00:00:00.333] send[1]: AT+CNEC=24
    [00:00:00.342] read[1]: OK
    [00:00:00.345] send[1]: AT+CIND=1,1,1
    [00:00:00.355] read[1]: OK
    [00:00:00.357] send[1]: AT%XSIM=1
    [00:00:00.366] read[1]: OK
    [00:00:01.188] poweron modem
    [00:00:01.197] opened socket, fd 2
    [00:00:01.200] send[2]: AT+CMEE=1
    [00:00:01.209] read[2]: OK
    [00:00:01.212] send[2]: AT+CEMODE=2
    [00:00:01.221] read[2]: OK
    [00:00:01.224] send[2]: AT+CFUN=1
    [00:00:01.264] read[2]: OK
    [00:00:01.267] wait for 15 seconds
    [00:00:05.135] read[1]: %XSIM: 1
    [00:00:05.855] read[1]: %CESQ: 46,2,0,0
    [00:00:05.859] read[1]: +CEREG: 2,"121F","0115760F",7,0,0,"11100000","11100000"
    [00:00:08.199] read[1]: +CGEV: ME PDN ACT 0,0
    [00:00:08.204] read[1]: +CIND: "service",1
    [00:00:08.208] read[1]: +CIND: "roam",1
    [00:00:16.270] poweroff modem
    [00:00:16.279] opened socket, fd 2
    [00:00:16.282] send[2]: AT+CMEE=1
    [00:00:16.292] read[2]: OK
    [00:00:16.294] send[2]: AT+CFUN=4
    [00:00:18.988] read[2]: OK
    [00:00:18.997] wait for 15 seconds
    [00:00:34.000] poweron modem
    [00:00:34.009] opened socket, fd 2
    [00:00:34.012] send[2]: AT+CMEE=1
    [00:00:34.022] read[2]: OK
    [00:00:34.024] send[2]: AT+CEMODE=2
    [00:00:34.034] read[2]: OK
    [00:00:34.036] send[2]: AT+CFUN=1
    [00:00:34.077] read[2]: OK
    [00:00:34.079] wait for 15 seconds
    [00:00:49.083] poweroff modem
    [00:00:49.092] opened socket, fd 2
    [00:00:49.095] send[2]: AT+CMEE=1
    [00:00:50.104] recv[2] timeout after 1000ms
    [00:00:50.108] send[2]: AT+CFUN=4
    [00:01:00.117] recv[2] timeout after 10000ms
    [00:01:10.042] recv[1] timeout after 30000ms
    [00:01:10.046] re-opening the modem, fd 1
    broken.zip
  • Thanks for the code.
    One problem with your code is that you (eventually) try to connect to the network 30 times in 30 minutes. That will trigger a network protection feature that will keep you from being able to connect to the network.
    That is not the problem seen in your log though.
    However, I am not able to reproduce the error in your log.
    What SIM card are you using?
    If you are not using the iBasis SIM card that came with the DK, could you try that (assuming you are able to connect to your local network with it)?
  • Understood about the 30 connects. Normal operation has delays in the range of hours and the shortened times are to illustrate the problem in less time.
    I am in US and using a SIM from Deutsche Telekom, but have seen the same issue with the iBasis SIM, though less often (based on a very non-scientific observation). The main difference I have seen between the two SIMs is that DT will always use AT&T while iBasis goes between AT&T and Verizon.
    I have updated the program to hopefully create the deadlock more frequently. I have had mixed results, so maybe it will happen quicker or maybe not. It can take up to 30 minutes for it to occur so be patient.
    broken2.zip
  • I let your updated sample run for close to 7 hours, but I am not able to see any hangs. Though maybe I just don't know what to look for. The log is attached.
    I also modified your application to enable modem tracing. Could you try to run it, and see if you are able to capture a trace of the hangup?
    socket_maybe_stuck.txtbroken_w_trace.zip
  • I am now not able to create the hang even with my own code, so I have updated the code and attached it again as 'broken3.zip'. In short, I took out the AT+CFUN=1 and spawn several threads to abuse the modem with AT commands. During the handful of times I have run it, it sometimes lasts for a full minute before hanging. It starts getting timeouts then all the output eventually just stops.
    The other problem I see is that it sometimes just does a board reset and starts over with the "booting zephyr..." message, with no accompanying information, panic, etc.
    It is not performing a real-world scenario, but is able to consistently produce a hang on the socket(AF_LTE) call.
    broken3.zip
