Sending Data Over BLE 5 Modules in Long Range with ble_app_uart
I wanted to send data over Bluetooth 5.0 modules and to see on a terminal. So I used nRF52840 DK as central device ( ble_app_uart_c) and Fanstel modules ( ble_app_uart) as peripheral. I programmed them successfully and observed that nRF52840 DK paired with advertising Fanstel module (LED 1 is ON) . I see printed data on the terminal. Everything is fine so far. I've couple of questions.
1. I know that long range advertisement is done by coded PHY (with nrf52840). Is it possible that I can send data in long range by using ble_app_uart ? Fanstel module I use supports BLE data rates: 2Mbps, 1Mbps, 500kbps,125kbps and I want to increase the range as possible as I can.
2. Can more than one advertising peripheral pair with the central device ?
3. In ble_app_uart, name of the advertising device is specified :
#define DEVICE_NAME                     "Nordic_UART"
I can't find related code line in ble_app_uart_c. How can I change the name of device central tries to connect to ?
4. I used RTT Viewer to see data because Putty didn't work I don't know why. Are there any other programs you could suggest for this operation ?
5. Is it enough to use NRF_LOG_INFO to print data ? I mean should I use a function ?. Also, I would like to know  the maximum data length I can send  with ble_app_uart example.
I will be very glad if you help me.
Thank you in advance.
Best Regards.
  • Okay, I understand now.  Sorry for the late answer :)
    Before I verify your answer, I would like to clear somethings up:
    - When should we use ble_nus_string_send instead of printf() function to monitor received data ?
    - ble_nus_c_string_send() is in  ble UART Central example. But I want to send data from peripheral to central. So I think  I should use ble_nus_data_send function in ble UART periphreal example, shouldn't I ? Let's say I write this in main() in ble_app_uart example :
    static uint8_t data_array[BLE_NUS_MAX_DATA_LEN] = "Hello World";
            uint16_t length = 11;
            ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle);
    After that, what should I do to see data on the central side ?
     Use ble_nus_string_send()  when you want to send data to a connected peer device and printf when you want to print something out on the UART interface.
     Yes, you can use the function to send data. Check the return value to see if the data is being sent or not.
    uint32_t err_code = ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle);
    NRF_LOG_INFO ("ble_nus_data_send returned 0x%x", err_code) // return value 0 is the same as NRF_SUCCESS
