Reading SD card on nRF9160dk
I want to read two files from SD card using nRF9160dk. I tried this code ncs/zephyr/samples/subsys/fs/fat_fs.
The Code:
 * Copyright (c) 2019 Tavish Naruka <[email protected]>
/* Sample which uses the filesystem API and SDHC driver */
#include <zephyr.h>
#include <device.h>
#include <disk/disk_access.h>
#include <logging/log.h>
#include <fs/fs.h>
#include <ff.h>
LOG_MODULE_REGISTER(main);
static int lsdir(const char *path);
static FATFS fat_fs;
/* mounting info */
static struct fs_mount_t mp = {
	.type = FS_FATFS,
	.fs_data = &fat_fs,
*  Note the fatfs library is able to mount only strings inside _VOLUME_STRS
*  in ffconf.h
static const char *disk_mount_pt = "/SD:";
void main(void)
	/* raw disk i/o */
	do {
		static const char *disk_pdrv = "SD";
		u64_t memory_size_mb;
		u32_t block_count;
		u32_t block_size;
		if (disk_access_init(disk_pdrv) != 0) {
			LOG_ERR("Storage init ERROR!");
		if (disk_access_ioctl(disk_pdrv,
				DISK_IOCTL_GET_SECTOR_COUNT, &block_count)) {
			LOG_ERR("Unable to get sector count");
		LOG_INF("Block count %u", block_count);
				DISK_IOCTL_GET_SECTOR_SIZE, &block_size)) {
			LOG_ERR("Unable to get sector size");
		printk("Sector size %u\n", block_size);
		memory_size_mb = (u64_t)block_count * block_size;
		printk("Memory Size(MB) %u\n", (u32_t)memory_size_mb>>20);
	} while (0);
	mp.mnt_point = disk_mount_pt;
	int res = fs_mount(&mp);
	if (res == FR_OK) {
		printk("Disk mounted.\n");
		lsdir(disk_mount_pt);
	} else {
		printk("Error mounting disk.\n");
	while (1) {
		k_sleep(1000);
	int res;
	struct fs_dir_t dirp;
	static struct fs_dirent entry;
	/* Verify fs_opendir() */
	res = fs_opendir(&dirp, path);
	if (res) {
		printk("Error opening dir %s [%d]\n", path, res);
		return res;
	printk("\nListing dir %s ...\n", path);
	for (;;) {
		/* Verify fs_readdir() */
		res = fs_readdir(&dirp, &entry);
		/* entry.name[0] == 0 means end-of-dir */
		if (res || entry.name[0] == 0) {
		if (entry.type == FS_DIR_ENTRY_DIR) {
			printk("[DIR ] %s\n", entry.name);
		} else {
			printk("[FILE] %s (size = %zu)\n",
				entry.name, entry.size);
	/* Verify fs_closedir() */
	fs_closedir(&dirp);
	return res;
I am getting the following error:
***** Booting Zephyr OS build v1.14.99-ncs3-snapshot2-2647-gd6e67554cfeb *****
[00:00:00.024,078] <inf> spi_nrfx_spim: CS control inhibited (no GPIO device)
[00:00:05.039,306] <err> main: Storage init ERROR!
[00:00:10.054,565] <err> fs: fs mount error (-5)
nrf9160_pca10090ns.overlay:
&spi3 {
        status = "okay";
        cs-gpios = <&gpio0 16 0>;
        sdhc0: sdhc@0 {
                compatible = "zephyr,mmc-spi-slot";
                reg = <0>;
                status = "okay";
                label = "SDHC0";
                spi-max-frequency = <24000000>;
&spi3 {
        status = "okay";
        sck-pin = <19>;
        mosi-pin = <18>;
        miso-pin = <17>;
I checked the voltage levels at SPI_3 pins. Pin 16, 17, 18 shows 3V but 19 which is SCK is at 0V. I am not understanding why it is at 0V.
Why there is error? What else I need to do?
  • Commands
    cd ncs/nrf
    git fetch origin
    git checkout v1.2.0
    west update
    Output from CMD
    2313.nrf_log.txt
  • Thank you! In the full output, I found the following:
    C:\ncs\nrf>git rebase v1.2.0
    error: cannot rebase: You have unstaged changes.
    error: Please commit or stash them.
    You need to do remove changes. Please issue a git stash, then switch to master and do git pull.
  • I tried with v1.1.0 and there was no error. But when I start SES. I am getting error.
  • The error while opening the SES
    Loading solution mqtt_uart_gnss.emProject
    Executing load commands
    cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=C:/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb -BC:/ncs/nrf/samples/jagruti_codes/mqtt_uart_gnss/build_nrf9160_pca10090ns -HC:/ncs/nrf/samples/jagruti_codes/mqtt_uart_gnss -DDTC_OVERLAY_FILE=C:/ncs/nrf/samples/jagruti_codes/mqtt_uart_gnss/nrf9160_pca10090ns.overlay -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=D:/nRF9160-DK/EmbeddedStudio_ARM_Nordic_v420a_win_x64/arm_segger_embedded_studio_v420a_win_x64_nordic/html/configure_nordic_project_menuconfig.py
    -- Using application from 'C:/ncs/nrf/samples/jagruti_codes/mqtt_uart_gnss'
    Zephyr version: 2.0.99
    -- Selected BOARD nrf9160_pca10090ns
    -- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.6.2", minimum required is "0.6.0")
    CMake Error at C:/ncs/zephyr/cmake/zephyr_module.cmake:45 (message):
      validation.invalid
       --- All found errors ---
      ["Cannot find required key 'build'.  Path: ''", "Key 'samples' was not
      defined.  Path: ''"]
      ERROR: Malformed "build" section in file:
      C:/ncs/bootloader/mcuboot\zephyr/module.yml
      <SchemaError: error code 2: Schema validation failed:
       - Cannot find required key 'build'. Path: ''.
       - Key 'samples' was not defined. Path: ''.: Path: '/'>
      C:/ncs/zephyr/cmake/app/boilerplate.cmake:251 (include)
      CMakeLists.txt:10 (include)
    See also "C:/ncs/nrf/samples/jagruti_codes/mqtt_uart_gnss/build_nrf9160_pca10090ns/CMakeFiles/CMakeOutput.log".
    See also "C:/ncs/nrf/samples/jagruti_codes/mqtt_uart_gnss/build_nrf9160_pca10090ns/CMakeFiles/CMakeError.log".
    Project load failed
    Reported error: solution load command failed (1)
  • Did you remember to run west update after git checkout v1.1.0?
    If so, please provide the following:
