BLE Peripheral NUS connected to multiple Central devices on nrf52840 S140 and SDK V16.0.0
Is it possible to configure the board as a peripheral device that provides the Nordic UART Service and allows multiple central devices to connect and exchange data.
Sort of like the "usbd_ble_uart_freertos" example but allows more than one Central device to connect at the same time.
Thanks
Omid
  • Hi Edvin,
    So I guess the reason I couldn't see the debug output is because I am using the "usbd_ble_uart_freertos" example and the logger task does not get the chance to output before the fault handler stops the execution.
    Any way I was able to find the ram_start location and the ram max size and changed them in the Linker "Section Placement Macros" and now I am able to build and run the app.  I also placed the code to restart advertising after a connection provided the num_peripherals is less than the MAX
    if (periph_link_cnt < NRF_SDH_BLE_PERIPHERAL_LINK_COUNT)
    // Continue advertising. More connections can be established because the maximum link count has not been reached.
    advertising_start(NULL);
    It appears I still have some issues because the moment I connect the board crashes in the softdevice_task when it tries to start advertising again.  I am probably missing an important piece of the puzzle.
    Would you be able to modify the "usbd_ble_uart_freertos"  SDK 16.0.0 , pca10056 example to handle multiple connections.  Our application requires the rtos version because we need to spawn other tasks for other functionality.
    I would much appreciate your help.
  • I am not that experienced with FreeRTOS. Why don't you explain kind of issues you encounter when you establish the connection? Is it the error handler that kicks in? Is it a hardfault? (NB Hardfault != Error handler).
    It is probably a bit too late, but do you really need FreeRTOS? In my experience many users think they need it, but it creates more issues than it solves. Usually, you can use interrupts and timers to do pretty much everything that you need.
  • Hi Edvin,
    To make this effort more manageable I took the "ble_app_uart" example which does not use the rtos and attempted to establish multiple central connections,
    Changed the NRF_SDH_BLE_PERIPHERAL_LINK_COUNT  to 2
    Set up the linker Linker Section Placement correctly
    I also included the code to restart the advertising once  the first connection is established in the ble_evt_handler.
    The program stops with this error as soon as the first connection is established.
    <info> app_timer: RTC: initialized.
    <info> app: Debug logging for UART over RTT started.
    <info> app: Connected
    <error> app: ERROR 18 [NRF_ERROR_CONN_COUNT] at /home/nikola/Nordic-tools/nRF5_SDK_16.0.0_98a08e2/examples/ble_peripheral/ble_app_uart/main.c:700
    PC at: 0x000305FD
    <error> app: End of error report
    If I remove the code that restarts the advertising the app works fine.  Obviously there are other modifications that I need to make but have not been able to make any progress.
    I have zipped and attached the project.
    I work for NikolaMotor https://nikolamotor.com/ and this project is for providing remote access to our trucks.  Nordic sales team was very excited to hear that we have chosen nrf52840 for our production.  At this point I am in a situation that requires me to demonstrate multiple connections with ble_uart service.  I appreciate your help.
    Regards
    4606.ble_app_uart.zip
  • I see that you didn't change NRF_SDH_BLE_TOTAL_LINK_COUNT as well as NRF_SDH_BLE_PERIPHERAL_LINK_COUNT.
    I don't know why NRF_SDH_BLE_TOTAL_LINK_COUNT isn't dynamic (just adding NRF_SDH_BLE_PERIPHERAL_LINK_COUNT and NRF_SDH_BLE_CENTRAL_LINK_COUNT), but I tested your project. Setting NRF_SDH_BLE_TOTAL_LINK_COUNT to 2, and adjusting to the RAM settings again made the peripheral able to keep advertising after the first connection was made. Also, there were no issues when I connected the second device.
    Edvin
  • Hi Edvin,
    Thanks very much for your help. That certainly was what I was missing. It is working fine.
    Regards
