How to configure the COEX interface as input on nRF9160
Greetings,
The only examples I can seem to locate of using the Coexistence Interface on nRF9160 is with the internal GPS but the documentation states that "COEX0: Input to the LTE modem from the external device. When active high, indicates that the external device transceiver is turned on."
That's the function I'm looking for, where an external device tells the '9160 to be quiet while it's using the airwaves.
I'm not certain I get the  %XCOEX0 AT command, as it seems to relate to using COEX0 as an output that's tied to internal GPS use.  My questions:
  1. Can COEX0 be used as an input from external devices to keep the LTE radio quiet?
  2. Does it need to be configured to behave this way and, if so, how?
Thanks for any hints on this and please don't hesitate if you need more info.
  • All right, CFUN=20 is what the a-gps sample uses, so I'll stick with that.
    As for BLE side controlling the LTE modem: ok, will work around this with software, but please confirm that I did read the docs correctly and that, in theory, this will be possible through COEX0.  Is this so?
    As a PS, it would be really sweet if the docs would mention when a feature is coming soon rather than actually available.
     Yes, you read the docs correctly.
    I completely agree and I'll try to get the documentation improved to reflect the current status of development.
