nrf52 disable interrupt below a certain level
My goal is that disabling the interrupts other than soft device interrupt.
I think that this is achieved by disabling interrupts below a certain level (in this case, 2?), is this possible?
Or I suppose that to set the current interrupt priority state high is another solution, but I couldn't find the method to realize this, either.
Please tell me sample codes to realize those.
  • The problem has solved, the cause is our software bug (SOFTDEVICE_PRESENT definition is disabled.).
    Thanks to your advice, I tried to watch inside the CRITICAL_REGION_ENTER function and could find this bug. Thank you so much.
    But I still want to know how to realize following 2 methods;
    1. change current interrupt level
    2. disable interrupt below a certain level
    Glad to hear that you found the source of the initial issue.
    k.k said:
    I thought that the cause of the error handler  is called is that some of the important interrupts of softdevice or anything else modules are disabled for a long time, is it correct?
    I know that you're already found this issue, but: this is a side-effect of when you're re-enabling interrupts again where you get many events triggered at the same time.
    The softdevice has a predictive order of events, and when things happen out-of-order, it detects and asserts.
    k.k said:
    If so, I thought that disabling interrupts below a certain level is one of the best solution, but I couldn't find the corresponding API.
    There is no API for this, you need to parse each interrupt and check manually.
     Do you mean exit the interrupt handler? I am not sure I understand really what you want to obtain here.
    Håkon
