Unable to log anything on the serial terminal using Nordic Thingy 91
I am trying to follow this tutorial (https://devzone.nordicsemi.com/nordic/cellular-iot-guides/b/getting-started-cellular/posts/ncs-tutorial---temporary) on Nordic Thingy 91 but I am unable to print anything on the serial terminal. Although, when I use the asset tracker application which was provided in the firmware I could see the info on the serial terminal. I added the following lines:
CONFIG_SERIAL=y
CONFIG_UART_0_NRF_UARTE=y
but still couldn't see anything on the terminal. I am using these settings to select the board:
Can you tell me what the issue is?
Thank you.
Haris Ahmed
  • harisahmed said:
    I uploaded your merged.hex file in MCUboot to Thingy91
     Do you have a debugger/programmer that you can connect to the Thingy?
    The sample is not made to support bootloaders, so unless you have an external programmer the sample will not work out of the box.
    You can use the "Debug Out" port on the nRF91DK to program the Thingy.
    harisahmed said:
    I tried running the sample program on nrf9160 dk using pca10090ns as the board
     Did you build from source?
    The Thingy and DK uses different pins for the UART, so you will not get any output if you use a hex file built for the worng board.
  • I have nrf9160dk but I am not sure how to upload the merged.hex file to the Thingy91 using Segger Embedded Studio. Can it be uploaded with SES or do I have to do it via Commands?
    And yes, the sample which I ran on nrf9160 dk, I built it from the source for the pca10090ns board.
  • I uploaded the merged.hex file you provided using nrf Connect Programmer app while using nrf9160dk's debug out. But now whenever I open the serial terminal and select the COM port of Thingy 91 the serial program becomes not responding. I tried with RealTerm, Termite and PuTTy but same result everytime.
     Yes, downloading the firmware from SES should work.
     That is also an option.
     Does the same happen if you use another sample? As you are printing inside a loop without any sleeps/delays the terminals might struggle with allocating memory fast enough.
    When you try the hello_world project, you can also try to build it for the secure version of the boards (without "ns" at the end). As the project does not use the modem, it should function as usual, but it will let us rule out any problems with the SPM.
  • Thanks for the suggestions. I added the loop so that I can see the output continuously but I think serial monitor programs had trouble handling that. I added some delay and the sketch works fine now.
