SPI communication between nRF9160DK and nRF52840DK
I want to transfer data from nRF52840DK to nRF9160DK using SPI. I want to use nRF52840DK as master which will transfer the data and nRF9160DK as slave which will receive the data.
I have never worked with nRF52840DK. For SPI master, I tried SPI example on nRF52840DK. When I connect MOSI to MISO, the data is transferred. Now I want to transfer this data to nRF9160DK.
On nRF9160DK, I tried SPI master example to check if it works. Now I want to use nRF91 as SPI slave. So I added spi slave drivers and changed overlay file also. But I am not understanding how to configure spi_config struct for slave.
static const struct spi_config spi_cfg = {
//	.operation = SPI_OP_MODE_SLAVE | SPI_MODE_CPOL | SPI_MODE_CPHA,
        .operation = SPI_OP_MODE_SLAVE,
	.frequency = 4000000,
	//.slave = 1,
I am not understanding how to set these parameters to configure spi in slave and receive the data.
I connected both the dks to check if nrf91 can receive the data, but spi_read shows error
  • Yes the performance was as expected when I flashed SPI master example on nrf52 and as well as on nrf91. On nrf91, I used zephyr spi drivers. But when I connected nrf91 spi salve to nrf52 spi master. The data was not received on nrf91. There was error on nrf91 side. I think I did not configure nrf91 as spi slave properly. That's why the error is coming and there is no communication between nrf52 and nrf91. I have not yet understood how to the configuration for spi slave. I must be missing something.
  • I see.
    If you would share the relevant code you have written to configure your nRF9160 as SPI Slave, I could take a look.
    Do you configure it as SPI_OP_MODE_SLAVE in the SPI config?
    The different configuration parameters are detailed in the Zephyr SPI API Reference I linked earlier.
    Karl
  • I read the SPI API reference. But still few things were unclear.
    My spi config struct looks like this:
    	//.slave = 1,
    I did not understand how to set other parameters. As it is a slave, the cs pin will be active_low. But how to set the spi mode that I did not understand and even in .slave parameter what value goes, that is also not clear to me. While configuring master, it was set to 0.
    Is there certain parameters you are uncertain about? Please let me know, then I will explain their usage. You may also want to see the different defines in the spi.h file. It is located in NCS\zephyr\include\drivers\spi.h
    There you can read the description of each parameter, if you would like.
    Are you referring to the bitwise or ' | ' operation taking place in the example code?
    The main thing to note here is that the .operation element of the spi_config struct is a 16 bit bit-field. So, you configure this by doing the bitwise or operation between the different functionality you would like. Are you familiar with bitfields and bitwise operations?
    As an example, if you were to configure slave mode and a word_size of 8, it would look like this:
        .operation = SPI_OP_MODE_SLAVE | SPI_WORD_SIZE_SET(8),
    This option is not for configuring it as a slave. The option exists because some devices would rather like the CS signal to be active high, instead of active low. This is not necessary to set for your application.
    The default value is active_low, so you do not need to do anything with it when using SPI between nRF9160 and nRF52840, since both of these devices use active_low.
    If you are not certain how to use the SPI, you could take a look at the hci_spi example from the ncs sdk, located in ncs\zephyr\samples\bluetooth\hci_spi
    This example demonstrates pushing data received from BLE to another device using SPI.
    The example documentation can be seen here.
    Please let me know if things are still unclear.
    Karl
    Thank you so much for the detailed answer. Many things are now clear to me. I will try your solution.
