The Buttonless DFU Template Application is not working on a custom board
I am currently working on a custom product that uses module BMD-300 from u-blox, which has nrf52382 chip in it. My application works fine and now I want to integrate the Secure DFU function into it. I programmed the board with the DFU test image sd_s132_bootloader_buttonless_with_setting_page_dfu_secure_ble_debug_without_bonds.hex but I could not see it advertising when I scan for devices on nrf Connect. Does anyone know what problem could cause it to not advertising? I am using sdk v15.0.0.
Thank you in advance.
  • Is it because you don't have IAR or are there compiling errors?
    I will try your suggestions and get back to you.
  • I have no problem importing the IAR project into SES and rebuild it. Could you please tell me what was the problem when you compiled it? I attached the makefile I exported from the SES ( I zipped it because the browser doesn't accept .mak file)
    Ctrl_2000M.zip
    There were compiler errors.
    Is this based on an example from the SDK? If so, which one? Perhaps If so, perhaps I can just add in the custom files that you are using to compile it elsewhere. I am not sure what exactly to do with the .mak file.
    I tried importing the project to segger, but I got about the same error:
    What version of IAR do you use? Perhaps I can try to reinstall it with the same version.
    I tried to just take your main.c file and the others files in your 2000M folder and compile it in ble_app_uart. Some hickups regarding UART and UAURTE with your sdk_config.h.
    Note that I copied your project into a clean SDK. Can you try the same? Are you able to compile without any changes outside the project folder? If so, where does e.g. nrf_uarte_error_mask_t point to? Where is this defined?
  • I use IAR Embedded Workbench - Arm 8.30.1 and sdk version 15.0.0
    The only thing I need to change if I use a clean SDK is to change "#define BUTTONS_NUMBER 0" to "#define BUTTONS_NUMBER 1" in file 2790_003A.h
    I don't use uart and uarte in my project so I don't have them enabled in my sdk_config.h
     I am struggling with this one. Where is this defined? What file?
    in nrf_drv_uart.h, is NRF_DRV_UART_WITH_UARTE or NRF_DRV_UART_WITH_UART defined? Because in my project, with the sdk_config.h that you use, none of them are.
    In your sdk_config.h:
    UARTE_PRESENT 1
    NRFX_UARTE_ENABLED 0
    UART_PRESENT is defined
    NRFX_UART_ENABLED 0
    This makes neither of the checks:
    #if defined(UARTE_PRESENT) && NRFX_CHECK(NRFX_UARTE_ENABLED)
        #define NRF_DRV_UART_WITH_UARTE
    #if defined(UART_PRESENT) && NRFX_CHECK(NRFX_UART_ENABLED)
    return true, so NRF_DRV_UART_WITH_UART nor NRF_DRV_UART_WITH_UARTE is defined.
    Edvin
