nRF Connect for Cloud not displaying asset tracker graphical data
I have my Thingy:91 working now but I can only see "terminal" data in nRF Connect for Cloud. I was expecting to see graphs of the data and a map when I have a GPS fix. The "Cellular Link Monitor" says I should update my firmware but I am on the latest version. What's going on?
  • I completely understand, here you go. Make sure to set SW2 to the nRF52 position when flashing.
    I also attached a newly built copy of the asset_tracker sample from the master branch of NCS with support for NB-IoT (not legacy) and the trace config enabled in case you wanted to try getting a modem trace again.
    I understand the process might be hard, but it's difficult for me to understand what the issue might be without it.
    thingy91_connectivity_bridge.hex
    thingy91_asset_tracker_nbiot_2704.hex
    Heidi
  • Thanks.
    I have flashed the connectivity bridge to the nRF52 and your asset_tracker sample to the nRF91. I also made sure that the November 2019 versions of the modem firmware and the UART bridge were installed.
    This does not seem to connect to anything and the asset_tracker application doesn't find the Vodafone network that I had connected to previously. I got some sort of modem trace but I suspect it won't be much help because the size stopped growing fairly quickly. This is attached in case it's useful.
    The tutorial on getting the modem trace that you linked to previously has mysteriously disappeared ("Unfortunately, the page you've requested no longer exists.") so I couldn't check if I followed all the steps properly.
    Steve
    trace-2020-04-24T14-19-08.582Z.bin
  • Hi, I updated the modem trace link. It seems they moved the blog post to another page on DevZone.
    Your trace was unfortunately empty.
    From the screenshot in LTE Link Monitor, I see you're getting registration status 5 from +CEREG, i.e Registered, roaming. So, the device is connecting to a network.
    Do you have a log file with the full debug output from the app?
  • Yep. Attached.
    2020-04-24T14:26:14.762Z INFO Application data folder: C:\Users\steph\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2020-04-24T14:26:14.953Z DEBUG App pc-nrfconnect-linkmonitor v1.1.1 official
    2020-04-24T14:26:14.954Z DEBUG App path: C:\Users\steph\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2020-04-24T14:26:14.954Z DEBUG nRFConnect 3.3.0 is supported by the app (^3.2.0)
    2020-04-24T14:26:14.954Z DEBUG nRFConnect path: C:\Users\steph\AppData\Local\Programs\nrfconnect\resources\app.asar
    2020-04-24T14:26:14.954Z DEBUG HomeDir: C:\Users\steph
    2020-04-24T14:26:14.955Z DEBUG TmpDir: C:\Users\steph\AppData\Local\Temp
    2020-04-24T14:26:20.279Z INFO Modem port is opened
    2020-04-24T14:26:39.975Z INFO Modem port is opened
    2020-04-24T14:26:39.985Z DEBUG modem << Non-secure callable region 0 placed in flash region 2 with size 32.\x0D\x0A\x0D\x0A
    2020-04-24T14:26:39.998Z DEBUG modem << SRAM region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2020-04-24T14:26:40.008Z DEBUG modem << 00 07 0x00000 0x10000 \x09Secure\x09\x09rwxl\x0D\x0A
    2020-04-24T14:26:40.012Z DEBUG modem << 08 31 0x10000 0x40000 \x09Non-Secure\x09rwxl\x0D\x0A\x0D\x0A
    2020-04-24T14:26:40.016Z DEBUG modem << Peripheral\x09\x09Domain\x09\x09Status\x0D\x0A
    2020-04-24T14:26:40.020Z DEBUG modem << 00 NRF_P0               Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.024Z DEBUG modem << 01 NRF_CLOCK            Non-Secure\x09OK\x0D
    2020-04-24T14:26:40.111Z DEBUG modem << 02 NRF_RTC0             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.115Z DEBUG modem << 03 NRF_RTC1             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.122Z DEBUG modem << 04 NRF_NVMC             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.128Z DEBUG modem << 05 NRF_UARTE1           Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.132Z DEBUG modem << 06 NRF_UARTE2           Secure\x09\x09SKIP\x0D\x0A
    2020-04-24T14:26:40.137Z DEBUG modem << 07 NRF_TWIM2            Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.143Z DEBUG modem << 08 NRF_SPIM3            Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.147Z DEBUG modem << 09 NRF_TIMER0           Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.153Z DEBUG modem << 10 NRF_TIMER1           Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.156Z DEBUG modem << 11 NRF_TIMER2           Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.160Z DEBUG modem << 12 NRF_SAADC            Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.163Z DEBUG modem << 13 NRF_PWM0             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.167Z DEBUG modem << 14 NRF_PWM1             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.173Z DEBUG modem << 15 NRF_PWM2             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.184Z DEBUG modem << 16 NRF_PWM3             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.187Z DEBUG modem << 17 NRF_WDT              Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.190Z DEBUG modem << 18 NRF_IPC              Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.193Z DEBUG modem << 19 NRF_VMC              Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.196Z DEBUG modem << 20 NRF_FPU              Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.200Z DEBUG modem << 21 NRF_EGU1             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.203Z DEBUG modem << 22 NRF_EGU2             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.207Z DEBUG modem << 23 NRF_DPPIC            Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.210Z DEBUG modem << 24 NRF_GPIOTE1          Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:26:40.216Z DEBUG modem << 25 NRF_REGULATORS       Non-Secure\x09OK\x0D\x0A\x0D\x0A
    2020-04-24T14:26:40.222Z DEBUG modem << SPM: NS image at 0x18200\x0D\x0A
    2020-04-24T14:26:40.226Z DEBUG modem << SPM: NS MSP at 0x2002eee0\x0D\x0A
    2020-04-24T14:26:40.229Z DEBUG modem << SPM: NS reset vector at 0x203bd\x0D\x0A
    2020-04-24T14:26:40.232Z DEBUG modem << SPM: prepare to jump to Non-Secure image.\x0D\x0A
    2020-04-24T14:26:40.235Z DEBUG modem << *** Booting Zephyr OS build v2.1.99[00:00:00.203,521] \x1B[0m<inf> BH1749: BH1749 initialized\x1B[0m\x0D\x0A
    2020-04-24T14:26:40.238Z DEBUG modem << -ncs1-1145-g13dc96f83bab  ***\x0D\x0A
    2020-04-24T14:26:40.241Z DEBUG modem << [00:00:00.218,048] \x1B[0m<inf> at_host: UART check failed: 12. Dropping buffer and retrying.\x1B[0m\x0D\x0A
    2020-04-24T14:26:40.243Z DEBUG modem << [00:00:00.259,399] \x1B[0m<inf> asset_tracker: Asset tracker started\x1B[0m\x0D\x0A
    2020-04-24T14:26:40.246Z DEBUG modem << [00:00:00.272,735] \x1B[0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100827982\x1B[0m\x0D\x0A
    2020-04-24T14:26:40.249Z DEBUG modem << [00:00:00.281,951] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656100827982/shadow\x1B[0m\x0D\x0A
    2020-04-24T14:26:40.252Z DEBUG modem << [00:00:00.293,609] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: nrf-352656100827982/shadow/get/accepted\x1B[0m\x0D\x0A
    2020-04-24T14:26:40.255Z DEBUG modem << [00:00:00.305,114] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656100827982/shadow/get/rejected\x1B[0m\x0D\x0A
    2020-04-24T14:26:40.258Z DEBUG modem << [00:00:00.317,687] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656100827982/shadow/update/delta\x1B[0m\x0D\x0A
    2020-04-24T14:26:40.261Z DEBUG modem << [00:00:00.330,596] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656100827982/shadow/update\x1B[0m\x0D\x0A
    2020-04-24T14:26:40.264Z DEBUG modem << [00:00:00.342,437] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656100827982/shadow/get\x1B[0m\x0D\x0A
    2020-04-24T14:26:40.268Z DEBUG modem << [00:00:00.354,583] \x1B[0m<inf> asset_tracker: Connecting to LTE network. \x1B[0m\x0D\x0A
    2020-04-24T14:26:40.274Z DEBUG modem << [00:00:00.361,358] \x1B[0m<inf> asset_tracker: This may take several minutes.\x1B[0m\x0D\x0A
    2020-04-24T14:26:40.277Z DEBUG modem << [00:00:00.376,800] \x1B[0m<dbg> lte_lc.w_lte_lc_connect: Network mode: AT%XSYSTEMMODE=1,0,1,0\x1B[0m\x0D\x0A
    2020-04-24T14:27:23.362Z DEBUG modem << +CEREG: 2,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"\x0D\x0A
    2020-04-24T14:27:23.503Z DEBUG modem << [00:00:46.143,981] \x1B[0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 2\x1B[0m\x0D\x0A
    2020-04-24T14:27:23.575Z DEBUG modem >> AT+COPS=?\x0D\x0A
    2020-04-24T14:28:23.574Z ERROR Network search failed: Error: 'AT+COPS=?
    ' timed out
    2020-04-24T14:29:42.190Z DEBUG modem << +COPS: \x0D\x0A
    2020-04-24T14:29:42.200Z DEBUG modem << OK\x0D\x0A
    2020-04-24T14:34:21.810Z INFO Modem port is opened
    2020-04-24T14:34:21.814Z DEBUG modem << Non-secure callable region 0 placed in flash region 2 with size 32.\x0D\x0A\x0D\x0A
    2020-04-24T14:34:21.817Z DEBUG modem << SRAM region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2020-04-24T14:34:21.821Z DEBUG modem << 00 07 0x00000 0x10000 \x09Secure\x09\x09rwxl\x0D\x0A
    2020-04-24T14:34:21.824Z DEBUG modem << 08 31 0x10000 0x40000 \x09Non-Secure\x09rwxl\x0D\x0A\x0D
    2020-04-24T14:34:21.852Z DEBUG modem << Peripheral\x09\x09Domain\x09\x09Status\x0D\x0A
    2020-04-24T14:34:21.856Z DEBUG modem << 00 NRF_P0               Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.860Z DEBUG modem << 01 NRF_CLOCK            Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.863Z DEBUG modem << 02 NRF_RTC0             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.866Z DEBUG modem << 03 NRF_RTC1             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.869Z DEBUG modem << 04 NRF_NVMC             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.873Z DEBUG modem << 05 NRF_UARTE1           Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.876Z DEBUG modem << 06 NRF_UARTE2           Secure\x09\x09SKIP\x0D\x0A
    2020-04-24T14:34:21.879Z DEBUG modem << 07 NRF_TWIM2            Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.882Z DEBUG modem << 08 NRF_SPIM3            Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.885Z DEBUG modem << 09 NRF_TIMER0           Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.889Z DEBUG modem << 10 NRF_TIMER1           Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.894Z DEBUG modem << 11 NRF_TIMER2           Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.897Z DEBUG modem << 12 NRF_SAADC            Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.905Z DEBUG modem << 13 NRF_PWM0             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.908Z DEBUG modem << 14 NRF_PWM1             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.910Z DEBUG modem << 15 NRF_PWM2             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.913Z DEBUG modem << 16 NRF_PWM3             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.916Z DEBUG modem << 17 NRF_WDT              Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.919Z DEBUG modem << 18 NRF_IPC              Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.923Z DEBUG modem << 19 NRF_VMC              Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.926Z DEBUG modem << 20 NRF_FPU              Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.932Z DEBUG modem << 21 NRF_EGU1             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.941Z DEBUG modem << 22 NRF_EGU2             Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.945Z DEBUG modem << 23 NRF_DPPIC            Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.948Z DEBUG modem << 24 NRF_GPIOTE1          Non-Secure\x09OK\x0D\x0A
    2020-04-24T14:34:21.952Z DEBUG modem << 25 NRF_REGULATORS       Non-Secure\x09OK\x0D\x0A\x0D\x0A
    2020-04-24T14:34:21.956Z DEBUG modem << SPM: NS image at 0x18200\x0D\x0A
    2020-04-24T14:34:21.959Z DEBUG modem << SPM: NS MSP at 0x2002eee0\x0D\x0A
    2020-04-24T14:34:21.961Z DEBUG modem << SPM: NS reset vector at 0x203bd\x0D\x0A
    2020-04-24T14:34:21.964Z DEBUG modem << SPM: prepare to jump to Non-Secure image.\x0D\x0A
    2020-04-24T14:34:21.966Z DEBUG modem << *** Booting Zephyr OS build v2.1.99[00:00:00.203,460] \x1B[0m<inf> BH1749: BH1749 initialized\x1B[0m\x0D\x0A
    2020-04-24T14:34:21.972Z DEBUG modem << -ncs1-1145-g13dc96f83bab  ***\x0D
    2020-04-24T14:34:22.005Z DEBUG modem << [00:00:00.217,987] \x1B[0m<inf> at_host: UART check failed: 12. Dropping buffer and retrying.\x1B[0m\x0D\x0A
    2020-04-24T14:34:22.007Z DEBUG modem << [00:00:00.259,338] \x1B[0m<inf> asset_tracker: Asset tracker started\x1B[0m\x0D\x0A
    2020-04-24T14:34:22.009Z DEBUG modem << [00:00:00.272,674] \x1B[0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100827982\x1B[0m\x0D\x0A
    2020-04-24T14:34:22.014Z DEBUG modem << [00:00:00.281,890] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656100827982/shadow\x1B[0m\x0D\x0A
    2020-04-24T14:34:22.017Z DEBUG modem << [00:00:00.293,548] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: nrf-352656100827982/shadow/get/accepted\x1B[0m\x0D\x0A
    2020-04-24T14:34:22.020Z DEBUG modem << [00:00:00.305,084] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656100827982/shadow/get/rejected\x1B[0m\x0D\x0A
    2020-04-24T14:34:22.024Z DEBUG modem << [00:00:00.317,657] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656100827982/shadow/update/delta\x1B[0m\x0D\x0A
    2020-04-24T14:34:22.027Z DEBUG modem << [00:00:00.330,566] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656100827982/shadow/update\x1B[0m\x0D\x0A
    2020-04-24T14:34:22.029Z DEBUG modem << [00:00:00.342,437] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656100827982/shadow/get\x1B[0m\x0D\x0A
    2020-04-24T14:34:22.034Z DEBUG modem << [00:00:00.354,553] \x1B[0m<inf> asset_tracker: Connecting to LTE network. \x1B[0m\x0D\x0A
    2020-04-24T14:34:22.038Z DEBUG modem << [00:00:00.361,328] \x1B[0m<inf> asset_tracker: This may take several minutes.\x1B[0m\x0D\x0A
    2020-04-24T14:34:22.042Z DEBUG modem << [00:00:00.376,770] \x1B[0m<dbg> lte_lc.w_lte_lc_connect: Network mode: AT%XSYSTEMMODE=1,0,1,0\x1B[0m\x0D\x0A
    2020-04-24T14:35:04.321Z DEBUG modem << +CEREG: 2,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"\x0D\x0A
    2020-04-24T14:35:04.389Z DEBUG modem << [00:00:46.045,471] \x1B[0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 2\x1B[0m\x0D\x0A
    2020-04-24T14:44:18.682Z DEBUG modem << [00:10:00.424,591] \x1B[0m<inf> lte_lc: Network connection attempt timed out\x1B[0m\x0D\x0A
    2020-04-24T14:44:18.691Z DEBUG modem << +CEREG: 0,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"\x0D\x0A
    2020-04-24T14:44:18.727Z DEBUG modem << [00:10:00.442,169] \x1B[0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 0\x1B[0m\x0D\x0A
    2020-04-24T14:44:18.730Z DEBUG modem << [00:10:00.450,469] \x1B[0m<inf> lte_lc: Using fallback network mode\x1B[0m\x0D\x0A
    2020-04-24T14:44:18.735Z DEBUG modem << [00:10:00.456,604] \x1B[0m<dbg> lte_lc.w_lte_lc_connect: Network mode: AT%XSYSTEMMODE=0,1,1,0\x1B[0m\x0D\x0A
    2020-04-24T14:44:19.254Z DEBUG modem << +CEREG: 0,"33F6","001F3615",9,0,0,"11100000","11100000"\x0D\x0A
    2020-04-24T14:44:19.322Z DEBUG modem << [00:10:01.002,349] \x1B[0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 0\x1B[0m\x0D\x0A
    2020-04-24T14:44:19.663Z DEBUG modem << +CEREG: 2,"33F6","001F3615",9,0,0,"11100000","11100000"\x0D\x0A
    2020-04-24T14:44:19.728Z DEBUG modem << [00:10:01.412,078] \x1B[0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 2\x1B[0m\x0D\x0A
    2020-04-24T14:44:25.375Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T14:44:25.411Z DEBUG modem << [00:10:07.123,382] \x1B[0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 5\x1B[0m\x0D\x0A
    2020-04-24T14:44:25.414Z DEBUG modem << [00:10:07.131,713] \x1B[0m<inf> asset_tracker: Connected to LTE network\x1B[0m\x0D\x0A
    2020-04-24T14:44:25.652Z DEBUG modem << [00:10:07.392,333] \x1B[0m<dbg> nrf_cloud_transport.nct_connect: IPv4 Address 0x165fca22\x1B[0m\x0D\x0A
    2020-04-24T14:44:25.693Z DEBUG modem << [00:10:07.400,360] \x1B[0m<dbg> nrf_cloud_transport.nct_mqtt_connect: mqtt_connect requesting persistent session\x1B[0m\x0D\x0A
    2020-04-24T14:44:34.598Z DEBUG modem << [00:10:16.338,928] \x1B[0m<inf> aws_jobs: Subscribe: $aws/things/nrf-352656100827982/jobs/notify-next\x1B[0m\x0D\x0A
    2020-04-24T14:44:34.646Z DEBUG modem << [00:10:16.348,907] \x1B[0m<inf> aws_jobs: Subscribe: $aws/things/nrf-352656100827982/jobs/$next/get/#\x1B[0m\x0D\x0A
    2020-04-24T14:44:34.659Z DEBUG modem << [00:10:16.358,673] \x1B[0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_CONNACK\x1B[0m\x0D\x0A
    2020-04-24T14:44:34.664Z DEBUG modem << [00:10:16.366,821] \x1B[0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 2\x1B[0m\x0D\x0A
    2020-04-24T14:44:34.671Z DEBUG modem << [00:10:16.374,511] \x1B[0m<dbg> nrf_cloud.event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTED\x1B[0m\x0D\x0A
    2020-04-24T14:44:34.674Z DEBUG modem << [00:10:16.382,659] \x1B[0m<inf> asset_tracker: CLOUD_EVT_CONNECTED\x1B[0m\x0D\x0A
    2020-04-24T14:44:34.677Z DEBUG modem << [00:10:16.388,732] \x1B[0m<inf> asset_tracker: Persistent Sessions = 0\x1B[0m\x0D\x0A
    2020-04-24T14:44:34.680Z DEBUG modem << [00:10:16.395,141] \x1B[0m<dbg> nrf_cloud_transport.nct_cc_connect: nct_cc_connect\x1B[0m\x0D\x0A
    2020-04-24T14:44:34.687Z DEBUG modem << [00:10:16.403,442] \x1B[0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 3\x1B[0m\x0D\x0A
    2020-04-24T14:44:35.121Z DEBUG modem << [00:10:16.864,837] \x1B[0m<inf> aws_fota: subscribed to notify-next topic\x1B[0m\x0D\x0A
    2020-04-24T14:44:35.171Z DEBUG modem << [00:10:16.871,643] \x1B[0m<inf> aws_jobs: Publish topic: $aws/things/nrf-352656100827982/jobs/$next/get\x1B[0m\x0D
    2020-04-24T14:44:35.181Z DEBUG modem << [00:10:16.880,889] \x1B[0m<inf> aws_jobs: Publish payload {"clientToken": ""}\x1B[0m\x0D\x0A
    2020-04-24T14:44:35.399Z DEBUG modem << [00:10:17.139,068] \x1B[0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 2114 result = 0\x1B[0m\x0D\x0A
    2020-04-24T14:44:35.484Z DEBUG modem << [00:10:17.224,853] \x1B[0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 1234 result = 0\x1B[0m\x0D\x0A
    2020-04-24T14:44:35.493Z DEBUG modem << [00:10:17.234,832] \x1B[0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 4\x1B[0m\x0D\x0A
    2020-04-24T14:44:35.518Z DEBUG modem << [00:10:17.242,523] \x1B[0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 5678 opcode = 0 len = 0\x1B[0m\x0D
    2020-04-24T14:44:35.541Z DEBUG modem << [00:10:17.252,960] \x1B[0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5\x1B[0m\x0D\x0A
    2020-04-24T14:44:35.861Z DEBUG modem << [00:10:17.601,806] \x1B[0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 29096 result = 0\x1B[0m\x0D\x0A
    2020-04-24T14:44:35.898Z DEBUG modem << [00:10:17.612,182] \x1B[0m<dbg> aws_fota.on_publish_evt: Received topic: $aws/things/nrf-352656100827982/jobs/$next/get/accepted\x1B[0m\x0D\x0A
    2020-04-24T14:44:35.902Z DEBUG modem << [00:10:17.623,596] \x1B[0m<inf> aws_fota: Checking for an available job\x1B[0m\x0D\x0A
    2020-04-24T14:44:35.906Z DEBUG modem << [00:10:17.630,157] \x1B[0m<dbg> aws_fota.get_job_execution: Job doc: {"clientToken":"","timestamp":1587739476}\x1B[0m\x0D\x0A
    2020-04-24T14:44:35.910Z DEBUG modem << [00:10:17.640,289] \x1B[0m<dbg> aws_fota.get_job_execution: Got only one field\x1B[0m\x0D\x0A
    2020-04-24T14:44:35.936Z DEBUG modem << [00:10:17.647,399] \x1B[0m<inf> aws_fota: No queued jobs for this device\x1B[0m\x0D\x0A
    2020-04-24T14:44:36.108Z DEBUG modem << [00:10:17.849,029] \x1B[0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 5678 result = 0\x1B[0m\x0D\x0A
    2020-04-24T14:44:36.160Z DEBUG modem << [00:10:17.859,039] \x1B[0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5\x1B[0m\x0D\x0A
    2020-04-24T14:44:36.405Z DEBUG modem << [00:10:18.145,202] \x1B[0m<dbg> aws_fota.on_publish_evt: Received topic: nrf-352656100827982/shadow/get/accepted\x1B[0m\x0D\x0A
    2020-04-24T14:44:36.464Z DEBUG modem << [00:10:18.155,273] \x1B[0m<dbg> aws_fota.on_publish_evt: received an unhandled MQTT publish event on topic: nrf-352656100827982/shadow/get/accepted\x1B[0m\x0D\x0A
    2020-04-24T14:44:36.477Z DEBUG modem << [00:10:18.168,365] \x1B[0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 15012 len = 283\x1B[0m\x0D\x0A
    2020-04-24T14:44:36.487Z DEBUG modem << [00:10:18.180,206] \x1B[0m<dbg> nrf_cloud_transport.nct_dc_endpoint_set: nct_dc_endpoint_set\x1B[0m\x0D\x0A
    2020-04-24T14:44:36.490Z DEBUG modem << [00:10:18.188,659] \x1B[0m<dbg> nrf_cloud_transport.nct_dc_endpoint_get: nct_dc_endpoint_get\x1B[0m\x0D\x0A
    2020-04-24T14:44:36.493Z DEBUG modem << [00:10:18.197,845] \x1B[0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 7890 opcode = 1 len = 329\x1B[0m\x0D\x0A
    2020-04-24T14:44:36.520Z DEBUG modem << [00:10:18.209,472] \x1B[0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 7\x1B[0m\x0D\x0A
    2020-04-24T14:44:36.529Z DEBUG modem << [00:10:18.217,163] \x1B[0m<dbg> nrf_cloud.event_handler: NRF_CLOUD_EVT_USER_ASSOCIATED\x1B[0m\x0D\x0A
    2020-04-24T14:44:36.532Z DEBUG modem << [00:10:18.224,945] \x1B[0m<inf> asset_tracker: CLOUD_EVT_PAIR_DONE\x1B[0m\x0D\x0A
    2020-04-24T14:44:37.376Z DEBUG modem << [00:10:19.116,912] \x1B[0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 7890 result = 0\x1B[0m\x0D\x0A
    2020-04-24T14:44:37.423Z DEBUG modem << [00:10:19.126,922] \x1B[0m<dbg> nrf_cloud_transport.nct_dc_connect: nct_dc_connect\x1B[0m\x0D\x0A
    2020-04-24T14:44:37.446Z DEBUG modem << [00:10:19.135,284] \x1B[0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 8\x1B[0m\x0D\x0A
    2020-04-24T14:44:37.853Z DEBUG modem << [00:10:19.592,956] \x1B[0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 8765 result = 0\x1B[0m\x0D\x0A
    2020-04-24T14:44:37.910Z DEBUG modem << [00:10:19.602,905] \x1B[0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 9\x1B[0m\x0D\x0A
    2020-04-24T14:44:37.945Z DEBUG modem << [00:10:19.610,595] \x1B[0m<dbg> nrf_cloud.event_handler: NRF_CLOUD_EVT_READY\x1B[0m\x0D\x0A
    2020-04-24T14:44:37.948Z DEBUG modem << [00:10:19.617,523] \x1B[0m<inf> asset_tracker: CLOUD_EVT_READY\x1B[0m\x0D\x0A
    2020-04-24T14:44:37.951Z DEBUG modem << [00:10:19.626,129] \x1B[0m<dbg> nrf9160_gps.init: GPS socket created, fd: 1232491587\x1B[0m\x0D\x0A
    2020-04-24T14:44:37.954Z DEBUG modem << [00:10:19.633,758] \x1B[0m<inf> gps_control: GPS initialized\x1B[0m\x0D\x0A
    2020-04-24T14:44:37.981Z DEBUG modem << [00:10:19.678,497] \x1B[0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 1 opcode = 1 len = 627\x1B[0m\x0D\x0A
    2020-04-24T14:44:37.988Z DEBUG modem << [00:10:19.690,551] \x1B[0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 2 opcode = 1 len = 58\x1B[0m\x0D\x0A
    2020-04-24T14:44:38.768Z DEBUG modem << [00:10:20.507,965] \x1B[0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 1 result = 0\x1B[0m\x0D\x0A
    2020-04-24T14:44:38.825Z DEBUG modem << [00:10:20.566,894] \x1B[0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 2 result = 0\x1B[0m\x0D
    2020-04-24T14:45:09.907Z DEBUG modem << %CESQ: 43,2,24,3\x0D\x0A
    2020-04-24T14:46:24.943Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T14:46:32.373Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T14:46:57.967Z DEBUG modem << %CESQ: 43,2,19,2\x0D\x0A
    2020-04-24T14:47:05.105Z DEBUG modem << %CESQ: 43,2,24,3\x0D\x0A
    2020-04-24T14:51:27.018Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T14:51:34.449Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T14:52:58.380Z DEBUG modem << %CESQ: 43,2,19,2\x0D
    2020-04-24T14:53:08.086Z DEBUG modem >> AT+COPS=?\x0D\x0A
    2020-04-24T14:54:07.501Z DEBUG modem << %CESQ: 43,2,24,3\x0D\x0A
    2020-04-24T14:54:40.779Z DEBUG modem << %CESQ: 43,2,17,2\x0D\x0A
    2020-04-24T14:55:03.819Z DEBUG modem << %CESQ: 43,2,23,3\x0D\x0A
    2020-04-24T14:56:33.418Z DEBUG modem << %CESQ: 43,2,17,2\x0D\x0A
    2020-04-24T14:56:35.978Z DEBUG modem << %CESQ: 43,2,22,3\x0D\x0A
    2020-04-24T14:57:39.977Z DEBUG modem << %CESQ: 43,2,17,2\x0D\x0A
    2020-04-24T14:57:42.537Z DEBUG modem << %CESQ: 43,2,22,3\x0D\x0A
    2020-04-24T14:57:56.207Z DEBUG modem << [00:23:37.983,032] \x1B[1;31m<err> at_host: Error while processing AT command: -8\x1B[0m\x0D\x0A
    2020-04-24T14:57:56.269Z DEBUG modem << ERROR\x0D\x0A
    2020-04-24T14:57:56.279Z ERROR Network search failed: Error: AT+COPS=?
     failed
    2020-04-24T14:59:28.293Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T14:59:35.722Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T14:59:59.012Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:00:01.322Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:00:04.132Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:00:06.442Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:00:09.251Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:00:57.641Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:03:28.929Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:03:31.239Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:06:58.846Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:07:01.156Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:09:27.324Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:09:29.634Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:11:55.803Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:11:58.112Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:12:00.922Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:12:03.228Z DEBUG modem << %CESQ: 43,2,17,2\x0D\x0A
    2020-04-24T15:12:03.312Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:12:06.042Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:12:13.473Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:12:30.846Z DEBUG modem << %CESQ: 43,2,22,3\x0D\x0A
    2020-04-24T15:16:57.879Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:17:00.189Z DEBUG modem << +CEREG: 5,"33F6","001F3615",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:18:30.038Z DEBUG modem << +CEREG: 5,"33EF","0002071F",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:18:35.351Z DEBUG modem << %CESQ: 36,1,15,2\x0D\x0A
    2020-04-24T15:18:35.429Z DEBUG modem << +CEREG: 5,"33EF","00020715",9,,,"11100000","00101000"\x0D\x0A
    2020-04-24T15:18:58.517Z INFO Modem port is closed
  • Hi, I have contacted the nRF Connect for Cloud team to ask about any issues on their end with this problem.
    In the meantime, there is a new MFW version out (v 1.2.0) and at new nRF Connect version (v3.3.3).
    Could you upgrade to all the newest firmware, just to eliminate this as the issue?
    I have also attached the compiled asset tracker (nRF9160) and usb-uart bridge (nRF52840) applications from the 1.2 tag of NCS (as opposed to the master branch) just to eliminate the possibility of the master branch being unstable.
    I would also like to apologize for all the issues you're having with this device. The Thingy:91 is meant to work as an out-of-box experience, but unfortunately, there are occasional issues with things like this.
    mfw_nrf9160_1.2.0.zip
    thingy91_asset_tracker_nbiot_v_1_2_27_04.hex
    thingy91_usb_uart_bridge_v1_2_27_04.hex
