Hi teams,
During development, I need quite a long period timer for hours.
Searching for the subject, I found application timer can only handle few minutes because of 24bit register.
Is there other proper way to get longer timer?
Hi teams,
APP_TIMER_CONFIG_RTC_FREQUENCY with non-zero is not working, as I tried.
OK. I will try alternatives. Can you give me a link to the references that I can refer to?
I need some clarification how to be notified when RTC overflow occurs, and etc.
And, can I use secondary RTC without hardware modification?
I think, in your case the easiest way is to split a long interval into a series of shorter ones, every time decreasing a counter that holds remaining time. A single wakeup every few minutes won't affect battery life time.
I agree. Now I am reviewing app_timer.c and can find enough informations what I want to get.
Thank you.
