During BLE startup call to nrf_sdh_enable_request(), nrf_atfifo_item_alloc fails and returns NULL causing a hard fault.
This sounds like an sdk_config.h problem but I don't know where to start looking.
I can't get CPU registers today until I get my new JLINK. I'm using the SEGGER (Microsoft) IDE and GNU compiler. I'll work on abstracting the important code so I don't have to post the whole thing as there's lots of stuff with I2C that are a distraction.
Here's an abstraction of the code - this compiles but doesn't load due to setup problems.
#include <stdlib.h>
#include <stdint.h>
#include <stdbool.h>
#include <nrf.h>
#include <nrfx_timer.h>
#include <nrf_sdh.h>
static nrfx_timer_config_t timerCheckinConfig =
{.frequency = NRF_TIMER_FREQ_500kHz,
.mode = NRF_TIMER_MODE_TIMER,
.bit_width = NRF_TIMER_BIT_WIDTH_32,
.interrupt_priority = NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY,
.p_context = NULL};
typedef struct {
nrfx_timer_t inst;
uint32_t ms;
uint32_t ticks;
uint32_t running;
uint32_t sinceFlashReset;
} Metronome;
Metronome timerCheckin =
{.inst = NRFX_TIMER_INSTANCE(2),
.ms = 2,
.ticks = 0,
.running = 0,
.sinceFlashReset = 0 };
void timerCheckinEventHandler(nrf_timer_event_t etype, void* pContext)
switch( etype ) {
case NRF_TIMER_EVENT_COMPARE2: break;
default: break;
void timerInit(void)
nrfx_err_t rc;
rc = nrfx_timer_init(&timerCheckin.inst, &timerCheckinConfig, timerCheckinEventHandler);
APP_ERROR_CHECK(rc);
timerCheckin.ticks = nrfx_timer_ms_to_ticks(&timerCheckin.inst, timerCheckin.ms);
nrfx_timer_extended_compare(&timerCheckin.inst,
NRF_TIMER_CC_CHANNEL2,
timerCheckin.ms,
NRF_TIMER_SHORT_COMPARE2_CLEAR_MASK,
true);
nrfx_timer_enable(&timerCheckin.inst);
void ble_stack_init(void)
ret_code_t err_code;
// At this point err_code == 3!
timerInit();
ble_stack_init();
Jed Marti said:this compiles but doesn't load due to setup problems.
Is it related to debugger setup, or are you able to load and debug the original project? The nrf_sdh_enable_request() should not return 0x3 and it doesn't make any calls nrf_atfifo_item_alloc() either.
I will try to run this on a nordic DK if you upload the full project (the simplified version without i2c) as a zip file.
Things behaving differently - I switched to the Linux version (a treat by the way) and followed the request sequence for nrf_sdh_enable_request as follows. The error occurs in a critical region which could be a problem for the debugger but:
sdh_request_observer_notify succeeds
sd_softdevice_enable
ser_app_hal_hw_init succeeds
connectivity_reset_low
nrf_queue_reset
nrf_queue_reset
ser_sd_transport_open fails following
ser_hal_transport_open
ser_phy_open fails following
hci_timer_init fails following
app_timer_create success
hci_timer_reset fails
app_timer_stop fails return code 4, switch error code to NRF_ERROR_INTERNAL==3 and return up
Now sounds like something with the timers needed.
Uploading zip problematic for sponsor.
I followed the app_timer_stop a bit farther, it is failing the nrf_atfifo_wspace_req call (which returns NULL). The linker claims I'm only using 25% of RAM so this must be a memory setup problem. The code in nrf_atfifo_wspace_req is assembly that I'm not competent to interpret.
ser_app_hal_hw_init
nrf_queue_reset
nrf_queue_reset
ser_phy_open
hci_timer_init
app_timer_create
hci_timer_reset
further calls by app_timer_stop now...
timer_req_schedule
nrf_atfifo_item_alloc returns NULL
nrf_atfifo_wspace_req --> No calls here, this is what fails.
