nRF91 firmware upgrade over BLE
I am trying to do firmware upgrade of nRF91 over BLE using nRF52 on the nRF91-DK or Thingy91 board. They both have nRF91 and nRF52840 chips on them which are connected.
As I understand from the documentation, at the moment, on Thingy91 board I can connect to the USB (which is connected to the nRF52) and upgrade the firmware on nRF91. This is also providing two UART ports, and the BLE UART service can be additionally enabled. Like in example: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/connectivity_bridge/README.html
On the nRF91 side, nRF91 application would have to implement the UART management transport so it can be upgraded over UART and the nRF5x act as a bridge from BLE to UART
https://docs.zephyrproject.org/1.13.0/subsystems/mgmt.html
Is this a good way to go and do you have some experience doing this?
At the moment I have a bit different approach. I started with nRF52 app_ble_uart example and created the "UART bridge" between BLE device and nRF91. Next is to have nRF91 able to receive upgrade and probably write some application for PC/mobile deice to push the upgrade over UART.
Let me know your thoughts and if you already have done something like this.
Vojislav.
  • Hi Simon,
    I wish you a happy holiday!
    This is the current situation regarding this issue:
    • I have three boards connected: nrf91-DK (mcuboot with hello_world app) connected with jumper wires (UART RX, TX, and GND) to the nrf52-DK (nrf52832, this runs peripheral_uart app) and nrf52840-DK (nrf52840, this runs central_uart app).
    •  So now I have bidirectional communication in this path: myPC <-USB-> nrf52840-DK <-BLE-> nrf52-DK <-UART-> nrf91-DK.
    • I do not anymore have a problem with the termination of UART messages because I used logic analyzer and sniffed the messaged going back and forth on the UART and saw that responses that nrf91 is sending to mcumgr CLI also have a termination, and this was not written in the mcumgr serial documentation
    • with all this, I am able to send the mcumgr CLI command for reset over my "BLE UART" while the device is in the serial recovery mode and the device will reset and go to the application. This command has rather small send and receives the command, and that is ok for current application
    • now at the last step problem is because firmware upgrade sends much bigger data packets and because BLE is sending it in chunks od 20 bytes a timeout happens at mcumgr CLI application.
    So I was looking to extend buffer size on both ends (peripherial_uart and central_uart) but just setting the buffer to some bigger value is not enough, do you have some tips on this and what else is necessary to achieve bigger buffer size on both ends?
    Vojislav.
  • So what I see now, from investigating this further is that I have a problem in one direction:
    • peripheral to central BLE device is working OK, and sending a lot of data at once
    • central to peripheral is outputting 20 but 20 bytes on the UART.
    Do you think this has to do with BLE central buffer or BLE peripheral buffer?
    Vojislav
  • Let's continue the discussion about this specific issue in this thread.
