Sending a CSV File over ble Gatt connection
I need to send data from a CSV file on the nordic board(Via fatfs library). I have presently gotten a Gatt service up and running.
I have a mobile application which, can see the gatt service and write to the characteristics. From a specific write command from the mobile device I want the nordic board to send the CSV file over.
I can presently read a single line of the CSV file formatted like this: (Time stamp, data1, data 2, data3, data 4, data 5).
What I need to implement is:
  • Reading the whole file but, one or multiple lines at a time due to the size of the CSV
  • Changing the read pointer of the SD card (So I know where to continue to read from)
  • Send this data to the characteristic
  • Read this characteristic data.
My code is based upon :  https://github.com/bjornspockeli/custom_ble_service_example
My CSV file size depends on the length of time I have been storing data from. It could be upto around 1-2mbytes. I beleive I need to set up some kind of notification service. Where I read a line(or several) of the SD card, set the GATT characteristic value to this. Then change the SD card pointer. Wait till the data is received by the mobile application. Then repeat until the file is read full.y
Note I am using SDK 16 NRF52840-dk PCA 10056 S140.
This post is similar and mentions using two characteristics one from commication from the mobile app and, one for receiving the data.
https://devzone.nordicsemi.com/f/nordic-q-a/53987/nrf52840-file-transfer-via-ble
  • Thanks, that did seem to fix it. I have another question. I am now reading my CSV file by manually each time calling my function send CSV. This is working however, I want it to be automatic.
    Therefore I presume I can loop this until all my data is sent. My question is: Is there a way to confirm each time data is sent it is received before sending the next data?
    I need this as I want to send my full log of data. This will be done using the notifications and, checking for a notification value change.
  • If you want this to happen fast, you can just queue up as many packets as you like. Queue one using the sd_ble_gatts_hvx function, which you already do, and if that returns NRF_SUCCESS, try to queue another one immediately. Do this as long as it returns NRF_SUCCESS. Eventually, it will return NRF_ERROR_RESOURCES, which means that the buffer is full. When this happens, you must wait for the BLE_GATTS_EVT_HVN_TX_COMPLETE event (add this to your ble_evt_handler()). When you receive this event, you can continue to queue packets until it returns NRF_ERROR_RESOURCES.
    Remember that the packet you queue that returns NRF_ERROR_RESOURCES isn't queued, so this would be the first packet you try to queue after the BLE_GATTS_EVT_HVN_TX_COMPLETE event.
  • I am not quite sure what you mean by queue. Presently I am sending all my data (10 CSV lines for testing like below)
    • Receive notification command
    • Loop
      • If flag = true(set by notification timer 10 times a second)
      • Read sd card line
      • send data (ble_cus_send)
      • Check error
      • reset flag
      • Exit condition is all CSV read
    This works but is this queuing? If so how can I speed it up atm its 510bytes per second.
  • Your function ble_cus_send() is calling sd_ble_gatts_hvx(). This is what I mean by queuing. ble_cus_send() = queuing.
  • So therefore, My bullet point code shown above works via queuing?
    This means then I don't need a flag to make it loop 10 times a second.
    Therefore, I just need to queue up all my data?
