Sending a CSV File over ble Gatt connection
I need to send data from a CSV file on the nordic board(Via fatfs library). I have presently gotten a Gatt service up and running.
I have a mobile application which, can see the gatt service and write to the characteristics. From a specific write command from the mobile device I want the nordic board to send the CSV file over.
I can presently read a single line of the CSV file formatted like this: (Time stamp, data1, data 2, data3, data 4, data 5).
What I need to implement is:
  • Reading the whole file but, one or multiple lines at a time due to the size of the CSV
  • Changing the read pointer of the SD card (So I know where to continue to read from)
  • Send this data to the characteristic
  • Read this characteristic data.
My code is based upon :  https://github.com/bjornspockeli/custom_ble_service_example
My CSV file size depends on the length of time I have been storing data from. It could be upto around 1-2mbytes. I beleive I need to set up some kind of notification service. Where I read a line(or several) of the SD card, set the GATT characteristic value to this. Then change the SD card pointer. Wait till the data is received by the mobile application. Then repeat until the file is read full.y
Note I am using SDK 16 NRF52840-dk PCA 10056 S140.
This post is similar and mentions using two characteristics one from commication from the mobile app and, one for receiving the data.
https://devzone.nordicsemi.com/f/nordic-q-a/53987/nrf52840-file-transfer-via-ble
  • You need to enable notifications from your mobile app, if you develop your own application. I don't know how this is done from the phone side.
    Try to google how to do it, together with what IDE tools/libraries that you use for your mobile application. (Android/iOS, Javascript/other, ...).
    Edvin
  • Ok I've sorted out how to do my notifications. I do however have another question. I am passing a command via a gatt connection to a custom service. It then passes the received data to a statemachine. From this certain actions take place. However they only work inside of the Gatt connection on_write statement and not in the main. I would like to run functionality from my main code by setting a global boolean value from my on_write method. But when I do this, nothing in the main loop runs.
    I have another question post with it here : https://devzone.nordicsemi.com/f/nordic-q-a/58666/issue-reading-sd-card-from-within-a-gatt-connection
    with the code as follows but it does not work.
    main()
    for(;;)
         if (m_rcvd_data_request) // Always checked after application interrupts
                 m_rcvd_data_request = false;
                 //TODO: add calls to load data from SD and send over BLE
          else if( <flag>)
          idle_state_handle(); // sleep while waiting for new events
    Are you able to propagate these events to main.c? See step 7 in the github that you linked to. It seems like this is pretty much what you are looking for, if you are not able to set the flags in main.
    EDIT: I just read your last post in the link to your other case. Remember to also set your main_test to "volatile", so if it is currently:
    bool main_test;
    Try set it to:
    volatile bool main_test;
    This means that the compiler will tell the application to always check this variable's value, and not assume it is the same as the last time you were in that function. But you still need to propagate your events to main.c, so do Step 7 as well.
  • Ah I think that makes sense. Just let me check my assumptions with you.
    • You can set a variable within the on_write function to my structure for ble_cus_evt_type_t?
    • By creating a new type in there for instance BLE_CUS_EVT_WRITE_SD_DATA for instance.
    • Then from inside the main.c file the function on_cus_evt should be able to see that via its switch statement if I add it to a case?
    • Then I can do my processing inside of there. Or I can set  a boolean value inside of there(volatile) to issue a command to my main loop(give an if statement inside of the  loop).
    Is this correct?
  • You shouldn't use variables across different files (only definitions), such as global variables. It is easy to lose track of who uses it and where it is updated. It is considered bad habit in C Slight smile
    You should use the on_write event in your custom file (let us call it ble_cus.c) to generate an event in main, e.g. BLE_CUS_EVT_WRITE_SD_DATA.
    Then, from this event in main.c, you can set the (volatile) variable to issue a command in the main loop.
    Something like this:
    // in main.c:
    #include "ble_cus.h"
    volatile bool my_flag2 = false;
    static void my_ble_cus_evt_handler(...)
        switch(evt_type)
        case BLE_CUS_EVT_WRITE_SD_DATA:
            my_flag1 = true;
        case SOME_OTHER_CASE:
            // Do something else ...
            // No implementation needed.
    main()
        // init stuff...
        for (;;)
            if (my_flag1)
                my_flag1 = false;
                do_stuff();
            sd_app_evt_wait();
    You can follow the guide, but you can also have a look at the ble_app_uart example from the SDK, if you want to see how this example propagate the events to main.c, if you get stuck. It does pretty much the same thing.
    Edvin
