Sending a CSV File over ble Gatt connection
I need to send data from a CSV file on the nordic board(Via fatfs library). I have presently gotten a Gatt service up and running.
I have a mobile application which, can see the gatt service and write to the characteristics. From a specific write command from the mobile device I want the nordic board to send the CSV file over.
I can presently read a single line of the CSV file formatted like this: (Time stamp, data1, data 2, data3, data 4, data 5).
What I need to implement is:
  • Reading the whole file but, one or multiple lines at a time due to the size of the CSV
  • Changing the read pointer of the SD card (So I know where to continue to read from)
  • Send this data to the characteristic
  • Read this characteristic data.
My code is based upon :  https://github.com/bjornspockeli/custom_ble_service_example
My CSV file size depends on the length of time I have been storing data from. It could be upto around 1-2mbytes. I beleive I need to set up some kind of notification service. Where I read a line(or several) of the SD card, set the GATT characteristic value to this. Then change the SD card pointer. Wait till the data is received by the mobile application. Then repeat until the file is read full.y
Note I am using SDK 16 NRF52840-dk PCA 10056 S140.
This post is similar and mentions using two characteristics one from commication from the mobile app and, one for receiving the data.
https://devzone.nordicsemi.com/f/nordic-q-a/53987/nrf52840-file-transfer-via-ble
  • Yeah it does work, I was surprised I could just move it across though with only minor tweaks but, all my functionality seems to still work fine.
    What is the best way of adapting the notification timer so that I can send the CSV file over.
  • Trial and error.
    I honestly don't know. Start at one end of the CSV file, and iterate through it. Try to send as large packets as possible. Try to increase the MTU size, data size and enable data length extension in order to be able to send packets longer than 20 bytes. If you ask me how to do it, I will refer to the ble_app_uart example again. Try it, and let me know if you are stuck.
  • How do I increase the size of what is sent via the notification? Each datum I have is 51 bytes. Therefore, I would like to be at least this large.
  • Please refer to the ble_app_uart example. look at where it calls ble_nus_data_send, and what this function does.
    Are you able to send an array of 51 bytes? If not, what is it that prevents you from doing so? what does sd_ble_gatts_hvx() return?
  • I have not tried to send more than 8 bytes. And only with using the notification timer as well. As the parameter that gets passed into is uint8.  How do I change this so I can use a larger size than 51bytes?
    I have looked at the ble_app_uart and, its a bit confusing. I do not need its uart functionality. Also I do not need blcm_link_ctx_get. Below is my update code.
    uint32_t ble_cus_custom_value_update(ble_cus_t * p_cus, uint8_t custom_value)
        NRF_LOG_INFO("In ble_cus_custom_value_update. \r\n");
        if (p_cus == NULL)
            return NRF_ERROR_NULL;
        uint32_t err_code = NRF_SUCCESS;
        ble_gatts_value_t gatts_value;
        // Initialize value struct.
        memset(&gatts_value, 0, sizeof(gatts_value));
        gatts_value.len     = sizeof(uint8_t);
        gatts_value.offset  = 0;
        gatts_value.p_value = &custom_value;
        // Update database.
        err_code = sd_ble_gatts_value_set(p_cus->conn_handle,
                                          p_cus->custom_value_handles.value_handle,
                                          &gatts_value);
        if (err_code != NRF_SUCCESS)
            return err_code;
        // Send value if connected and notifying.
        if ((p_cus->conn_handle != BLE_CONN_HANDLE_INVALID))
            ble_gatts_hvx_params_t hvx_params;
            memset(&hvx_params, 0, sizeof(hvx_params));
            hvx_params.handle = p_cus->custom_value_handles.value_handle;
            hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
            hvx_params.offset = gatts_value.offset;
            hvx_params.p_len  = &gatts_value.len;
            hvx_params.p_data = gatts_value.p_value;
            err_code = sd_ble_gatts_hvx(p_cus->conn_handle, &hvx_params);
            NRF_LOG_INFO("sd_ble_gatts_hvx result: %x. \r\n", err_code);
            err_code = NRF_ERROR_INVALID_STATE;
            NRF_LOG_INFO("sd_ble_gatts_hvx result: NRF_ERROR_INVALID_STATE. \r\n");
        return err_code;
