Secure DFU: Isn't upgrading firmware with custom files
Hello there,
I am working on secure dfu. I followed all the steps mentioned in this post and successfully created the secure .zip file.
Here's what I did(In this order):
  • Loaded Softdevice 6.1.1
  • Flashed "secure_bootloader_ble_s140_pca10056" into DK
  • Used nRF Connect app on my iOS device to upgrade the application.
Here's what is happening:
  • If I use any file from "secure_dfu_test_images", everything is being upgraded correctly. New appication is working as expected.
  • If I use the .hex file from /project/pca10056/blank/ses/Output/Debug/Exe and create a secure .zip file with nrfutil and try to upgrade the application, the upgrade is complete on nRF Connect App. Then LEDs will be off and nothing happens. On restart, nothing boots up - neither BLE nor new App code.
  • If I manually flash the same .hex file using ses -> Target -> Download File -> Intel Hex(After clearing all memory), the application code is working okay. So, it's not Application problem.
It'd be fantastic if you can help me understand what's going on here and tell me how to fox this.
Thanks
Teja
  • Thanks Amanda.
    I tried updating the firmware using secure UART DFU and I am getting an error.
    COM Port:
    nrfUtil Command:
    nrfutil dfu serial -pkg PDFW.zip -p COM4
    Error:
      File "C:\Users\tejac\AppData\Local\Programs\Python\Python37-32\Scripts\nrfutil-script.py", line 11, in <module>
        load_entry_point('nrfutil==6.0.1', 'console_scripts', 'nrfutil')()
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\click\core.py", line 829, in __call__
        return self.main(*args, **kwargs)
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\click\core.py", line 782, in main
        rv = self.invoke(ctx)
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\click\core.py", line 1259, in invoke
        return _process_result(sub_ctx.command.invoke(sub_ctx))
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\click\core.py", line 1066, in invoke
        return ctx.invoke(self.callback, **ctx.params)
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\click\core.py", line 610, in invoke
        return callback(*args, **kwargs)
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\nordicsemi\__main__.py", line 1035, in serial
        timeout)
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\nordicsemi\__main__.py", line 949, in do_serial
        dfu.dfu_send_images()
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\nordicsemi\dfu\dfu.py", line 127, in dfu_send_images
        self._dfu_send_image(self.manifest.application)
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\nordicsemi\dfu\dfu.py", line 95, in _dfu_send_image
        self.dfu_transport.send_init_packet(data)
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 255, in send_init_packet
        self.__stream_data(data=init_packet)
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 474, in __stream_data
        response = self.__calculate_checksum()
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 409, in __calculate_checksum
        response = self.__get_response(DfuTransportSerial.OP_CODE['CalcChecSum'])
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 492, in __get_response
        + 'Expected: 0x{:02X} Received: 0x{:02X}'.format(operation, resp[1]))
    pc_ble_driver_py.exceptions.NordicSemiException: Unexpected Executed OP_CODE.
    Expected: 0x03 Received: 0xF0
    Can you help me understand what's causing this and how I can fix this?
    How did you generate the PDFW.zip? Do you see this issue if you use a precompiled bootloader example and example .zip file under nRF5_SDK\examples\dfu\secure_dfu_test_images\uart\nrf52840?
    -Amanda H.
  • Hi ,
    Here's the process I follow:
    • Get the .hex file from:\SDK\nRF5_SDK_16.0.0_98a08e2\examples\peripheral\xxxxxxxxxxxxt\pca10056\blank\ses\Output\Release\Exe
    • Create a secure package using nrfutil pkg generate --hw-version 52 --application-version 1 --application blinky_mbr.hex --sd-req 0xB6 --key-file private.key blinkyUARTSecure.zip. Please note that I created a custom keys and I did update the bootloader code with the created public key.
    • Send the created package using nrfutil dfu usb-serial -pkg blinkyUARTSecure.zip -p COM4 command. Where COM4 is JLink CDC UART Port
    I tried with blinky_mbr.hex. from nRF5_SDK\examples\dfu\secure_dfu_test_images\uart\nrf52840 However, I got a similar error:
      File "c:\users\tejac\appdata\local\programs\python\python37-32\lib\site-packages\nordicsemi\__main__.py", line 994, in usb_serial
        timeout)
    Expected: 0x03 Received: 0xCD
  • Hi Teja,
     You should use
    nrfutil pkg generate --hw-version 52 --application-version 1 --application blinky_mbr.hex --sd-req 0x00 --key-file private.key blinkyUARTSecure.zip
    An empty sd_req list is equivalent to an sd_req list containing a single 0x00. Please see Updates without a SoftDevice.
    -Amanda H.
  • Hi Amanda,
    Thank you for responding to this. I really appreciate your help during the pandemic like this.
    I did try with nrfutil pkg generate --hw-version 52 --application-version 1 --application blinky_mbr.hex --sd-req 0x00 --key-file private.key blinkyUARTSecure.zip.e
    With the firmware I have, I got this error:
    nrfutil pkg generate --hw-version 52 --application-version 1 --application Firmware_PD52840V1R1_ParkAssist.hex --sd-req 0x00 --key-file private.key PDFW.zip
    Zip created at PDFW.zip
    C:\Users\tejac>nrfutil dfu usb-serial -pkg PDFW.zip -p COM4
        timeout)
    Expected: 0x03 Received: 0x0D
    With Blinky_mdr.hex, I got this error:
    Zip created at blinkyUARTSecure.zip
    C:\Users\tejac>nrfutil dfu usb-serial -pkg blinkyUARTSecure.zip -p COM4
        timeout)
    Expected: 0x03 Received: 0xF5
    I am not sure what's causing this.
