How to intercept 802.15.4 frames while using Thread
Hi!
I read that your Thread stack uses a different 802.15.4 implementation than the MAC driver. Is it possible to intercept special broadcast data packets e.g. from energy harvesting switches while using thread?
The special packets that I want to intercept have a MAC header that looks like this:
Frame Control: 0x0801 (use short addresses)
Sequene Number: 1 byte
Address field: 0xffffffff (short destination address and pan id)
Source address and pan are not included
Is there a possibility to use Thread and set a callback to intercept these packets and process them "by hand" and pass everything else on to Thread?
Jochen
  • Other question would be if you will release the source code of the 802.15.4 packet sniffer in the future. It seems to me that it just forwards the packets to the USB port, but would be handy for experimenting.
  • This sniffer doesn't use Zigbee or OpenThread. As far as I know there isn't plans to release the source code for this.
    The function nrf_802154_received_timestamp_raw from SDK\nrf5\external\zboss\osif\zb_nrf52_transceiver.c is the function you are looking for in Zigbee. It is called by the radio driver whenever a frame is received, in which the function will pass the frame to the ZBOSS stack when it is called. Because this is called from an interrupt, and it is in charge of passing the packets to the zboss stack, you should not do any further processing of the packet here. You can forward it to your application, and do the processing there, so that the interrupt handler is immediately ready for a new packet. In addition, the ZBOSS stack will decide to free up this buffer when it is processed, so you should copy the data to your own buffer (and not just send the pointer to the original buffer).
    Edvin
  • Thanks for the info. What is the correct way to notify the application from the interrupt and prevent race conditions on the copied data? Is there an example for this? Is it OK for Thread to do the processing in the callback or is it also called in the interrupt handler?
  • We don't have any examples doing this, unfortunately.
    I would suggest to study how the BLE examples use the ble event handler in the ble_examples to propagate an event to main.c. E.g. how the ble_app_uart example receives an event in ble_nus_on_ble_evt() in ble_nus.c, and use the on_write() function to send the event BLE_NUS_EVT_RX_DATA to main.c.
    Remember to make a copy of the message in your own buffer before sending the message through to the ZBOSS stack, because after this, it may be freed at any time (possibly before you have time to handle it in main.c).
