Get DFU/OTA to work with Android/IOS
I am trying to get DFU/OTA to work with the supplied sample Apps, so far no luck. I bought the nRF51 DK to have the hardware matching and tried with SD S310 2.01 and dfu_dual_bank_ble_s310_pca10028.uvprojx sample from SDK 7.2 and also with SD S110 8.0 and dfu_dual_bank_ble_s110_pca10028.uvprojx from SDK 8.0 and tried to load dfu_test_app_hrm.zip or dfu_test_app_hrm.hex (supplied with SDK 8.0 in test_images_update) with nRF Toolbox and nRF Master control panel under Android 4.4.2 all without luck. I see the DfuTarg advertising, in some cases I see the connected LED going on but I never got a successful load. Error messages vary, f.e. GATT error, nrf file error(2), remote DFU not supp ...
Could somebody please clarify, which versions of the Apps are compatible with which versions of SDK+SD and which file formats they support ? In the 8.0 bootloader there is a requirement for 'Master Control Panel v3.8 or later', which is obviously a PC version, which seems not available yet ?
A complete set of files to get the chain running for the 1st time would be really helpful.
BR Uwe
  • Hi Uwenord,
    Sorry that I didn't get back earlier. I just tested here with the nRFToolbox v1.12 and the zip file dfu_test_app_hrm.zip and found no problem. Not sure why it didn't work for you at the begining. Which softdevice & bootloader did you flash ? I may need a sniffer trace when you update the firmware to know what went wrong.
    One of the reason we removed S310 bootloader in SDK v8.0 is that the API for S310 v2.01 is not aligned with the S110 v8.0. So some minor modifications needed if you want to port the examples to work with S310.
    We will bring the S310 back when the newer version of the stack is updated with the API matched with S110 v8.x.
    For now, our suggestion is either to modify the code in SDK v8.0 or to switch back to SDK v7.1
