nRF52840 DK permanent hang during flashing
We have a stability issue with nRF52840 DK after it has been upgraded to JLink DLL version V6.60e and firmware OB-SAM3U128-V2-NordicSemi compiled Jan 7 2019 14:07:15.
Please see the below scenario which typically reproduces this problem:
1) Start JLinkExe
16:36 $ sudo JLinkExe -if swd -speed 9600 -device NRF52840_XXAA -autoconnect 1
SEGGER J-Link Commander V6.60e (Compiled Jan 17 2020 17:28:37)
DLL version V6.60e, compiled Jan 17 2020 17:28:19
Connecting to J-Link via USB...O.K.
Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 7 2019 14:07:15
Hardware version: V1.00
S/N: 683122431
License(s): RDI, FlashBP, FlashDL, JFlash, GDB
VTref=3.300V
Device "NRF52840_XXAA" selected.
Connecting to target via SWD
InitTarget() start
InitTarget() end
Found SW-DP with ID 0x2BA01477
Scanning AP map to find all available APs
AP[2]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x24770011)
AP[1]: JTAG-AP (IDR: 0x02880000)
Iterating through AP map to find AHB-AP to use
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00FF000
CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
Found Cortex-M4 r0p1, Little endian.
FPUnit: 6 code (BP) slots and 2 literal slots
CoreSight components:
ROMTbl[0] @ E00FF000
ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
Cortex-M4 identified.
J-Link>r
Reset delay: 0 ms
Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
Reset: Halt core after reset via DEMCR.VC_CORERESET.
Reset: Reset device via AIRCR.SYSRESETREQ.
J-Link>g
J-Link>
****** Error: Communication timed out: Requested 12 bytes, received 0 bytes !
2) Start JLinkRTTClient to see logs from device
3) Start flash programming
sudo nrfjprog -f nrf52 -r --program nrf52840_xxaa.hex --sectorerase
ERROR: nrfjprog failed for an unknown reason. Run the same command again with
ERROR: argument --log, contact Nordic Semiconductor and provide the generated
ERROR: log.log file to them.
In step 3) the programming does not start and below error appears in JLinkExe:
nrfjprog -i does not show any connected SWD device when this problem appears.
Rebooting PC with Linux with nRF52840 DK in such state causes that PC hangs on bootup. It's very problematic for us, since we are working remotely with this setup.
The only way to recover the nRF52840 DK is to physically disconnect it from USB and then reconnect.
Please let me know if there is some solution to this issue, because it's very problematic in our development.
  • So if I understand it correctly this worked on previous version of nrfjprog/jlink (do you know which one?), but the latest 10.7.0/6.64b this does not work anymore? Or is it only 6.60e that fails?
    kristofbo said:
    I also found out, that the issue does not appear when I close JLink connection and quit using "qc" command before flash programming.
    It seems like conflict between jlink and nrfjprog, I can report it internally. Can you type nrfjprog --version just so I have that.
    Kenneth
  • The problem appears on 6.60e as well. We didn't experience such issues some time before (maybe a year before) but I don't remember what version it was...
    Machine 1:
    $ nrfjprog --version
    nrfjprog version: 10.7.0
    JLinkARM.dll version: 6.64b
    Machine 2:
    nrfjprog version: 10.6.0
    Issue occurs on both machines like above.
  • Hi again,
    Can you also run "nrfjprog" command with logging enabled? use --log and send us the log.log file?
    nrfjprog -f nrf52 -r --program nrf52840_xxaa.hex --sectorerase --log
    Kenneth
  • Logs from running flash command, and attached log.log.
    $ sudo nrfjprog -f nrf52 -r --program node_thread.hex --sectorerase --log
    Segmentation fault
    2020-Mar-31 13:02:44  --------------------------------------------------------------------------------
    2020-Mar-31 13:02:44  nrfjprog -f nrf52 -r --program node_thread.hex --sectorerase --log
    2020-Mar-31 13:02:44  nrfjprog version 10.7.0
    2020-Mar-31 13:02:44  nRF_logger_open
    2020-Mar-31 13:02:44  nRF_logger_open:	nRFJProg logger opened to callback at address 0X5603EA6C9970
    2020-Mar-31 13:02:44  nRF_open_dll
    2020-Mar-31 13:02:44  nRF_open_dll:	Load library at "/opt/nrfjprog/libjlinkarm_nrf52_nrfjprogdll.so".
    2020-Mar-31 13:02:44  . nRF52_logger_open
    2020-Mar-31 13:02:44  . nRF52_logger_open:	nRFJProg logger opened to callback at address 0X7FF264F8FEB0
    2020-Mar-31 13:02:44  . nRF52_open_dll
    2020-Mar-31 13:02:44  . . Segger_logger_open
    2020-Mar-31 13:02:44  . . Segger_logger_open:	nRFJProg logger opened to callback at address 0X7FF264BEDA80
    2020-Mar-31 13:02:44  . . Segger_open_dll
    2020-Mar-31 13:02:44  . . Segger_open_dll:	Load library at "/opt/SEGGER/JLink/libjlinkarm.so.6".
    2020-Mar-31 13:02:44  . . . Segger_dll_version
    2020-Mar-31 13:02:44  . . Segger_set_core_data
    2020-Mar-31 13:02:44  nRF_enum_emu_snr
    2020-Mar-31 13:02:44  . nRF52_enum_emu_snr
    2020-Mar-31 13:02:44  . . Segger_enum_emu_snr
    2020-Mar-31 13:02:44  . . . Segger_enum_emu_snr
    2020-Mar-31 13:02:44  . . . . Segger_get_num_emus
    2020-Mar-31 13:02:44  nRF_connect_to_emu_with_snr
    2020-Mar-31 13:02:44  . nRF52_connect_to_emu_with_snr
    2020-Mar-31 13:02:44  . . Segger_connect_to_emu_with_snr
    2020-Mar-31 13:02:44  . . . Segger_is_connected_to_emu
    2020-Mar-31 13:02:44  . . . Segger_connect_to_emu_with_snr
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	Segger logging enabled with callback at 0x140679049041856.
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:756.776
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Mar 17 2020 14:43:00
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:775.168
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	Hardware: V1.00
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:775.247
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	S/N: 683122431
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:775.266
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	OEM: SEGGER
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:775.283
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:787.063
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	TELNET listener socket opened on port 19021
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:787.158
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	WEBSRV Starting webserver
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:787.196
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	WEBSRV Failed to put socket into listener state (port 19080)
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:787.243
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	WEBSRV Webserver running on local port 19081
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:787.268
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 40.161ms returns O.K.
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:787.318
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_GetHWStatus(...)
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:793.090
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 5.827ms returns 0x00
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:793.180
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:793.214
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 0.014ms returns 0x01
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:793.241
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_ExecCommand("DisableFlashDL", ...).
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:793.270
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 0.015ms returns 0x00
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:793.295
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:793.323
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 0.013ms returns 0x00
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:793.350
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_SetHookUnsecureDialog(...)
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:793.374
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 0.036ms returns 0
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:793.399
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_TIF_Select(JLINKARM_TIF_SWD)
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:805.374
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 12.026ms returns 0x00
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:805.478
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	JLINK_SetSpeed(2000)
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	T65A91740 000:808.496
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_emu_without_snr:	JLink INFO	- 3.067ms
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	T65A91740 000:808.629
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	T65A91740 000:808.674
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	- 0.020ms returns 0x00
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	T65A91740 000:808.714
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	JLINK_ExecCommand("device = nRF52832_xxAA", ...).
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	T65A91740 000:820.668
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	XML file found at: /opt/SEGGER/JLink/JLinkDevices.xml
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	T65A91740 000:821.814
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	/opt/SEGGER/JLink/JLinkDevices.xml evaluated successfully.
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	T65A91740 000:833.807
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	Device "NRF52832_XXAA" selected.
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	T65A91740 000:834.063
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	- 25.346ms returns 0x00
    2020-Mar-31 13:02:45  . . Segger_read_debug_port_idr
    2020-Mar-31 13:02:45  . . . Segger_read_debug_port_register
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:834.205
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	JLINK_IsOpen()
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:834.247
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	- 0.063ms returns 0x01
    2020-Mar-31 13:02:45  . . . . Segger_read_debug_port_register
    2020-Mar-31 13:02:45  . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:834.310
    2020-Mar-31 13:02:45  . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_Lock()
    2020-Mar-31 13:02:45  . . . . . Segger_coresight_configure
    2020-Mar-31 13:02:45  . . . . . Segger_coresight_configure:	JLink INFO	T65A91740 000:834.372
    2020-Mar-31 13:02:45  . . . . . Segger_coresight_configure:	JLink INFO	JLINK_CORESIGHT_Configure()
    2020-Mar-31 13:02:45  . . . . . Segger_coresight_configure:	JLink INFO	T65A91740 000:838.049
    2020-Mar-31 13:02:45  . . . . . Segger_coresight_configure:	JLink INFO	- 3.725ms returns 0
    2020-Mar-31 13:02:45  . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:838.121
    2020-Mar-31 13:02:45  . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
    2020-Mar-31 13:02:45  . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:838.742
    2020-Mar-31 13:02:45  . . . . Segger_read_debug_port_register:	JLink INFO	Value=0x2BA01477
    2020-Mar-31 13:02:45  . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:838.807
    2020-Mar-31 13:02:45  . . . . Segger_read_debug_port_register:	JLink INFO	- 0.704ms returns 0
    2020-Mar-31 13:02:45  . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:838.844
    2020-Mar-31 13:02:45  . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_Unlock()
    2020-Mar-31 13:02:45  nRF_read_device_version
    2020-Mar-31 13:02:45  . nRF52_read_device_version
    2020-Mar-31 13:02:45  . . nRF52_readback_status
    2020-Mar-31 13:02:45  . . . nRF52_is_ctrl_ap_available
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_emu
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:839.001
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_emu:	JLink INFO	JLINK_IsOpen()
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:839.035
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_emu:	JLink INFO	- 0.050ms returns 0x01
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:839.086
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	JLINK_Lock()
    2020-Mar-31 13:02:45  . . . . . . Segger_is_debug_region_powered
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:839.166
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:839.808
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.688ms returns 0
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:839.878
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:840.539
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	Value=0xF0000040
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:840.604
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	- 0.743ms returns 0
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:840.660
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:841.293
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.678ms returns 0
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:841.362
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:842.022
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	Value=0x02880000
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:842.089
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	- 0.745ms returns 0
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:842.126
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	JLINK_Unlock()
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:842.220
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:842.253
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_emu:	JLink INFO	- 0.049ms returns 0x01
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:842.304
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:842.383
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:842.888
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.570ms returns 0
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:842.977
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:843.496
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:843.561
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	- 0.603ms returns 0
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:843.617
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:844.115
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.543ms returns 0
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:844.185
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:844.865
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:844.931
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	- 0.763ms returns 0
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:844.967
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:845.061
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:845.094
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:845.156
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:845.248
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:845.648
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.433ms returns 0
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:845.701
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:846.043
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:846.109
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	- 0.426ms returns 0
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:846.164
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:846.725
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.605ms returns 0
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:846.794
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:847.432
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:847.518
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	- 0.749ms returns 0
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:847.564
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:847.658
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:847.691
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:847.742
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:847.822
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:848.316
    2020-Mar-31 13:02:45  . . . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.540ms returns 0
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:848.385
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:848.910
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:848.975
    2020-Mar-31 13:02:45  . . . . . . . Segger_read_debug_port_register:	JLink INFO	- 0.607ms returns 0
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:849.031
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:849.596
    2020-Mar-31 13:02:45  . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.623ms returns 0
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:849.678
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:850.277
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:850.347
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	- 0.685ms returns 0
    2020-Mar-31 13:02:45  . . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:850.381
    2020-Mar-31 13:02:45  . . . Segger_read_access_port_register
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:850.469
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:850.502
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	- 0.057ms returns 0x01
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:850.561
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	JLINK_Lock()
    2020-Mar-31 13:02:45  . . . . . Segger_is_debug_region_powered
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:850.641
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:851.155
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.545ms returns 0
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:851.205
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:851.741
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	Value=0xF0000040
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:851.810
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	- 0.621ms returns 0
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:851.861
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:852.361
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.569ms returns 0
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:852.449
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:853.026
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	Value=0x00000001
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:853.094
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	- 0.661ms returns 0
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:853.128
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	JLINK_Unlock()
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:853.210
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:853.243
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	- 0.049ms returns 0x01
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:853.292
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:853.370
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:853.787
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.471ms returns 0
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:853.860
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:854.335
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:854.404
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	- 0.560ms returns 0
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:854.455
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:854.912
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.526ms returns 0
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:855.001
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:855.485
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:855.555
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	- 0.570ms returns 0
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:855.589
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:855.672
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:855.704
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	- 0.048ms returns 0x01
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:855.762
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:855.849
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:859.215
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	- 3.401ms returns 0
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:859.270
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:859.795
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:859.864
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	- 0.611ms returns 0
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:859.923
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:860.421
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.566ms returns 0
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:860.509
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:861.086
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:861.154
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	- 0.662ms returns 0
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:861.188
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:861.274
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:861.307
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:861.360
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:861.438
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:861.910
    2020-Mar-31 13:02:45  . . . . . . . Segger_write_debug_port_register:	JLink INFO	- 0.525ms returns 0
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:861.983
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:862.487
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	T65A91740 000:862.555
    2020-Mar-31 13:02:45  . . . . . . Segger_read_debug_port_register:	JLink INFO	- 0.589ms returns 0
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:862.607
    2020-Mar-31 13:02:45  . . . . . Segger_write_debug_port_register:	JLink INFO	T65A91740 000:863.105
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:863.193
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:863.762
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:863.836
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	- 0.659ms returns 0
    2020-Mar-31 13:02:45  . . . . Segger_read_access_port_register:	JLink INFO	T65A91740 000:863.869
    2020-Mar-31 13:02:45  . . nRF52_readback_status:	Protection status read as NONE
    2020-Mar-31 13:02:45  . . nRF52_just_read_device_version
    2020-Mar-31 13:02:45  . . . Segger_read_u32
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:863.989
    2020-Mar-31 13:02:45  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 000:864.021
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_device
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_device:	JLink INFO	T65A91740 000:864.087
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_device:	JLink INFO	JLINK_IsConnected()
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_device:	JLink INFO	T65A91740 000:864.119
    2020-Mar-31 13:02:45  . . . . . Segger_is_connected_to_device:	JLink INFO	- 0.048ms returns FALSE
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	T65A91740 000:864.171
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	T65A91740 000:864.209
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	- 0.018ms returns 0x00
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	T65A91740 000:864.243
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	T65A91740 000:864.402
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	T65A91740 000:864.513
    2020-Mar-31 13:02:45  . . . . . Segger_load_core_data:	JLink INFO	- 0.263ms returns 0x00
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:864.559
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	JLINK_Connect()
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:865.029
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	InitTarget() start
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:865.077
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	 J-Link Script File: Executing InitTarget()
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:868.743
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	InitTarget() end
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:869.775
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	Found SW-DP with ID 0x2BA01477
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:872.269
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	DPIDR: 0x2BA01477
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:872.314
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	AP map detection skipped. Manually configured AP map found.
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:872.332
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	AP[0]: AHB-AP (IDR: Not set)
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:873.486
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	AP[0]: Core found
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:873.546
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	AP[0]: AHB-AP ROM base: 0xE00FF000
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:874.081
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:874.125
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	Found Cortex-M4 r0p1, Little endian.
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:975.475
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	 -- Max. mem block: 0x00000D68
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 000:975.669
    2020-Mar-31 13:02:45  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_ReadMem(4 bytes @ 0xE000EDF0)
    2020-Mar-31 13:02:47  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 003:025.755
    2020-Mar-31 13:02:47  . . . . Segger_connect_to_device:	JLink INFO	   ***** Error:
    2020-Mar-31 13:02:47  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 003:025.941
    2020-Mar-31 13:02:47  . . . . Segger_connect_to_device:	JLink INFO	Communication timed out: Requested 12 bytes, received -2 bytes !
    2020-Mar-31 13:02:49  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 005:073.769
    2020-Mar-31 13:02:49  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_WriteMem(4 bytes @ 0xE000EDF0)
    2020-Mar-31 13:02:53  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 009:169.776
    2020-Mar-31 13:02:53  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_ReadMem(4 bytes @ 0xE0002000)
    2020-Mar-31 13:02:57  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 013:269.760
    2020-Mar-31 13:02:57  . . . . Segger_connect_to_device:	JLink INFO	FPUnit: 0 code (BP) slots and 0 literal slots
    2020-Mar-31 13:02:57  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 013:269.984
    2020-Mar-31 13:02:57  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_ReadMem(4 bytes @ 0xE000EDFC)
    2020-Mar-31 13:03:01  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 017:361.724
    2020-Mar-31 13:03:01  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_WriteMem(4 bytes @ 0xE000EDFC)
    2020-Mar-31 13:03:05  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 021:457.720
    2020-Mar-31 13:03:05  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_ReadMem(4 bytes @ 0xE0001000)
    2020-Mar-31 13:03:09  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 025:585.743
    2020-Mar-31 13:03:09  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_WriteMem(4 bytes @ 0xE0001000)
    2020-Mar-31 13:03:14  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 029:685.742
    2020-Mar-31 13:03:14  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_ReadMem(4 bytes @ 0xE000ED88)
    2020-Mar-31 13:03:18  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 033:781.763
    2020-Mar-31 13:03:18  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_WriteMem(4 bytes @ 0xE000ED88)
    2020-Mar-31 13:03:22  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 037:873.721
    2020-Mar-31 13:03:22  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_ReadMem(4 bytes @ 0xE000ED88)
    2020-Mar-31 13:03:26  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 041:969.750
    2020-Mar-31 13:03:26  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_WriteMem(4 bytes @ 0xE000ED88)
    2020-Mar-31 13:03:30  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 046:065.752
    2020-Mar-31 13:03:30  . . . . Segger_connect_to_device:	JLink INFO	CoreSight components:
    2020-Mar-31 13:03:30  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 046:065.982
    2020-Mar-31 13:03:30  . . . . Segger_connect_to_device:	JLink INFO	ROMTbl[0] @ E00FF000
    2020-Mar-31 13:03:30  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 046:066.125
    2020-Mar-31 13:03:30  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_ReadMem(64 bytes @ 0xE00FF000)
    2020-Mar-31 13:03:34  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 050:165.665
    2020-Mar-31 13:03:34  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_ReadMem(32 bytes @ 0x911B0FE0)
    2020-Mar-31 13:03:38  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 054:257.657
    2020-Mar-31 13:03:38  . . . . Segger_connect_to_device:	JLink INFO	ROMTbl[0][0]: 911B0000, CID: 00000000, PID: FB7FFFFC ???
    2020-Mar-31 13:03:38  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 054:283.848
    2020-Mar-31 13:03:38  . . . . Segger_connect_to_device:	JLink INFO	 -- CPU_ReadMem(32 bytes @ 0xE00FFFE0)
    2020-Mar-31 13:03:42  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 058:385.745
    2020-Mar-31 13:03:42  . . . . Segger_connect_to_device:	JLink INFO	ROMTbl[0][2]: E00FF000, CID: 00000000, PID: FB7FFFFC ???
    2020-Mar-31 13:03:42  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 058:386.025
    2020-Mar-31 13:03:42  . . . . Segger_connect_to_device:	JLink INFO	- 57521.512ms returns 0x00
    2020-Mar-31 13:03:42  . . . . Segger_connect_to_device:	JLink ERROR	Communication timed out: Requested 12 bytes, received -2 bytes !
    2020-Mar-31 13:03:46  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 062:481.822
    2020-Mar-31 13:03:46  . . . . Segger_connect_to_device:	JLink INFO	JLINK_CORE_GetFound()
    2020-Mar-31 13:03:46  . . . . Segger_connect_to_device:	JLink INFO	T65A91740 062:482.027
    2020-Mar-31 13:03:46  . . . . Segger_connect_to_device:	JLink INFO	- 0.244ms returns 0xE0000FF
    2020-Mar-31 13:03:46  . . . . Segger_read_u32
    2020-Mar-31 13:03:46  . . . . . Segger_invalidate_cache
    2020-Mar-31 13:03:46  . . . . . Segger_invalidate_cache:	JLink INFO	T65A91740 062:482.181
    2020-Mar-31 13:03:46  . . . . . Segger_invalidate_cache:	JLink INFO	JLINK_ExecCommand("InvalidateCache", ...).
    2020-Mar-31 13:03:46  . . . . . Segger_invalidate_cache:	JLink INFO	T65A91740 062:482.292
    2020-Mar-31 13:03:46  . . . . . Segger_invalidate_cache:	JLink INFO	- 0.074ms returns 0x00
    2020-Mar-31 13:03:46  . . . . Segger_read_u32:	JLink INFO	T65A91740 062:482.373
    2020-Mar-31 13:03:46  . . . . Segger_read_u32:	JLink INFO	JLINK_ReadMemU32(0x10000130, 0x0001 Items, ...)
    2020-Mar-31 13:03:46  . . . . Segger_read_u32:	JLink INFO	T65A91740 062:482.467
    2020-Mar-31 13:03:46  . . . . Segger_read_u32:	JLink INFO	 -- CPU_ReadMem(4 bytes @ 0x10000130)
    2020-Mar-31 13:03:50  . . . . Segger_read_u32:	JLink INFO	T65A91740 066:577.695
    2020-Mar-31 13:03:50  . . . . Segger_read_u32:	JLink INFO	failed
    2020-Mar-31 13:03:50  . . . . Segger_read_u32:	JLink INFO	T65A91740 066:577.913
    2020-Mar-31 13:03:50  . . . . Segger_read_u32:	JLink INFO	- 4095.582ms returns -1
    2020-Mar-31 13:03:50  . . . . Segger_read_u32:	JLinkARM.dll ReadMemU32 detected a read error 1.
    2020-Mar-31 13:03:50  . . . . Segger_read_u32:	This typically indicates the read was blocked by a memory protection mechanism.
    2020-Mar-31 13:03:50  nRF_close_dll
    2020-Mar-31 13:03:50  . nRF52_close_dll
    2020-Mar-31 13:03:50  . . Segger_close
    2020-Mar-31 13:03:50  . . . Segger_disconnect_from_emu
    2020-Mar-31 13:03:50  . . . . Segger_is_connected_to_emu
    2020-Mar-31 13:03:52  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 068:629.873
    2020-Mar-31 13:03:52  . . . . Segger_is_connected_to_emu:	JLink INFO	JLINK_IsOpen()
    2020-Mar-31 13:03:52  . . . . Segger_is_connected_to_emu:	JLink INFO	T65A91740 068:630.091
    2020-Mar-31 13:03:52  . . . . Segger_is_connected_to_emu:	JLink INFO	- 0.259ms returns 0x01
    2020-Mar-31 13:03:52  . . . . Segger_disconnect_from_emu
    2020-Mar-31 13:03:52  . . . . . Segger_is_connected_to_device
    2020-Mar-31 13:03:52  . . . . . Segger_is_connected_to_device:	JLink INFO	T65A91740 068:630.250
    2020-Mar-31 13:03:52  . . . . . Segger_is_connected_to_device:	JLink INFO	JLINK_IsConnected()
    2020-Mar-31 13:03:52  . . . . . Segger_is_connected_to_device:	JLink INFO	T65A91740 068:630.344
    2020-Mar-31 13:03:52  . . . . . Segger_is_connected_to_device:	JLink INFO	- 0.131ms returns TRUE
    2020-Mar-31 13:03:52  . . . . Segger_disconnect_from_emu:	Disable trace before closing connection.
    2020-Mar-31 13:03:52  . . . . . Segger_write_u32
    2020-Mar-31 13:03:52  . . . . . Segger_write_u32:	JLink INFO	T65A91740 068:630.485
    2020-Mar-31 13:03:52  . . . . . Segger_write_u32:	JLink INFO	JLINK_WriteU32(0xE000EDFC, 0x00000000)
    2020-Mar-31 13:03:52  . . . . . Segger_write_u32:	JLink INFO	T65A91740 068:630.559
    2020-Mar-31 13:03:52  . . . . . Segger_write_u32:	JLink INFO	 - DEMCR
    2020-Mar-31 13:03:52  . . . . . Segger_write_u32:	JLink INFO	T65A91740 068:630.649
    2020-Mar-31 13:03:52  . . . . . Segger_write_u32:	JLink INFO	CPU is running
    2020-Mar-31 13:03:52  . . . . . Segger_write_u32:	JLink INFO	T65A91740 068:630.731
    2020-Mar-31 13:03:52  . . . . . Segger_write_u32:	JLink INFO	 -- CPU_WriteMem(4 bytes @ 0xE000EDFC)
    2020-Mar-31 13:03:57  . . . . . Segger_write_u32:	JLink INFO	T65A91740 072:721.731
    2020-Mar-31 13:03:57  . . . . . Segger_write_u32:	JLink INFO	- 4091.396ms returns -1
    2020-Mar-31 13:03:57  . . . . . Segger_write_u32:	JLinkARM.dll WriteU32 returned error -1.
    2020-Mar-31 13:03:57  . . . . . . Segger_abort_debug_action
    2020-Mar-31 13:03:57  . . . . . . Segger_abort_debug_action:	Attempting to clear any configuration errors in debug port before closing connection.
    2020-Mar-31 13:03:59  . . . . . . Segger_abort_debug_action:	JLink INFO	T65A91740 074:769.765
    2020-Mar-31 13:03:59  . . . . . . Segger_abort_debug_action:	JLink INFO	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2020-Mar-31 13:04:01  . . . . . . Segger_abort_debug_action:	JLink INFO	T65A91740 076:821.671
    2020-Mar-31 13:04:01  . . . . . . Segger_abort_debug_action:	JLink INFO	- 2052.063ms returns -1324619824
    2020-Mar-31 13:04:01  . . . . . . Segger_abort_debug_action:	JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -1324619824.
    2020-Mar-31 13:04:01  . . Segger_close:	Freeing Library.
  • It looks like Jlink have communication errors (read error) when connected to the device, maybe reducing clock speed can help, but this may be an SEGGER Jlink issue. I can in any case report it, let me know if you find a solution or workaround. You may also consider reach out to SEGGER, I think it would help if you knew version this worked on.
    Kenneth
