BLE + FDS Problem to read/write FDS
Hello there;
My setup:
NRF52832
SDK 15.3
I'm facing some problems with FDS when i use it with BLE activated.
When i read or write on FDS using fds_record_open or fds_record_update with BLE activated i get fatal erros.
But if i dont initialize the BLE the FDS operates normal without any errors.
Some one have any advice about it? I just need to read the FDS on the initialization of the device and write in flash one or two times while the application runs.
Debug:
<info> app: Fast advertising.
<info> app: Event: FDS_EVT_INIT received (FDS_SUCCESS)
(After FDS INIT i try to read the FDS)
<error> app: Fatal error
My BLE Init:
void ble_init(void) {
    bool erase_bonds;
    ble_conn.sts.disconnected = 1;
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    NRF_LOG_INFO("Modelo esta sendo executado.");
    application_timers_start();
    advertising_start(erase_bonds);
FDS init:
void init_flash_fds(void) {
   ret_code_t rc;
   // Registro p/ receber evento de quanto a inicialização está completa
   (void) fds_register(fds_evt_handler);
   // Inicia flash FDS
   rc = fds_init();
   APP_ERROR_CHECK(rc);
   // Aguarda o FDS inicializar
   wait_for_fds_ready();
   // Analisa estado do FDS
   fds_stat_t stat = {0};
   rc = fds_stat(&stat);
  • Yes, i'm debugging FDS_EVT_UPDATE by a NRF LOG:
    <info> app: Modelo esta sendo executado.
    <info> app: Escrevendo config file...
    <info> app: Event: FDS_EVT_WRITE received (FDS_SUCCESS)
    <info> app: Writed!
    <info> app: Event: FDS_EVT_UPDATE received (FDS_SUCCESS)
    <info> app: Updated!
    After i receive the "Updated!" message i reset the device
    The function to read or write:
    ret_code_t flash_read_n_write(bool wr) {
        ret_code_t rc;
        ret_code_t rc2;
        fds_record_desc_t record_desc = {0};
        fds_find_token_t    ftok;
        ftok.page=0;
        ftok.p_addr=NULL;
        static fds_record_t const m_dummy_record =
            .file_id           = FILE_ID,       // ID Onde sera escrito no FDS
            .key               = REC_KEY,       // Chave de Record
            .data.p_data       = &flash_mngt,   // Estrutura onde estarão os dados que serão armazenados na Flash
            .data.length_words = (sizeof(flash_mngt) + 3) / sizeof(uint32_t), // O tamanho do record é sempre expressado em 4-byte unidades (words)
             // Procura um record de Flash FDS com os dados configurados anteriormente
             rc = fds_record_find(FLASH_ID, FLASH_REC_KEY, &record_desc, &ftok);
             if (rc == FDS_SUCCESS)
              if(wr) {
                     NRF_LOG_INFO("Encontrado Records");
                     // Atualização do arquivo de config da Flash
                     fds_flash_record_t config = {0};
                     // Leitura Flash - Abre a flash FDS e le o conteudo
                     rc = fds_record_open(&record_desc, &config);
                     NRF_LOG_INFO("Encntrou records");
                     // Copia a configuracao da Flash para o m_dummy_cfg
                     memcpy(&flash_mngt, config.p_data, sizeof(flash_mngt));
                     NRF_LOG_INFO("Arquivo de config encontrado, atualizando numero de boot p/ %d.", flash_mngt.boot_cnt);
                     flash_mngt.boot_cnt++;
                     // Fecha a flash FDS
                     rc = fds_record_close(&record_desc);
                     } else {
                         flash_mngt.test++;
                         // Atualiza a Flash
                         rc2 = fds_record_update(&record_desc, &m_dummy_record);
                         NRF_LOG_INFO("GRAVEI!!!!");
                         return rc;
            } else {
           // Configuracao nao encontrada, escreve uma nova
           NRF_LOG_INFO("Escrevendo config file...");
           rc = fds_record_write(&record_desc, &m_dummy_record);
    The write,update and open works normally without BLE
  • Could you post your full project for us to reproduce and debug this?
