Different SDK levels for Application and Bootloader
Does it cause issues if the application was built with a different SDK level than the bootloader? I have a project I'm adding a bootloader to, and it isn't working. I have done over a dozen of these, yet I'm at a loss why I can't get this one working. One thing I noted that is different, is that the Application was built using SDK 15.2, while the Bootloader is currently setup to use SDK 15.3. The soft device is S112_v6.1.1.
I can obviously put them at the same level, but since the question has not been asked as far as I could find, I wanted to put the question on the forum for a real answer. This may not even be related to my issue, but I was curious.
  • Thank you!
    When that was working, the space was so constrained on the application that the peer manager was failing trying to init fds. This was the curve ball as to why it worked when I tested individually, but failed on a merge.
    Maybe not what happened in your case, but FDS may fail to re-claim pages during init if they have been completely or partially overwritten during the DFU process. It is important to make sure the NRF_DFU_APP_DATA_AREA_SIZE matches the FDS_VIRTUAL_PAGES setting used by the application to prevent this.
