We have 2 identical development boards and have been using only one until now. I was able to download code into the 2nd board successfully but it will not run. It does not run in either standalone or debug mode (PICKit3). What are the likely causes?
But since it programs is successfully doesn't that imply that it is connected properly - no shorts or opens? In order to program power, ground, SWDIO and SWDCLK must be connected. I believe the crystal must also be connected to program. Aren't those are the only pins required to run?
I again verified that is does not run with Segger connected or disconnected and it does not run in Debug mode with Segger connected.
I did a visual inspection under a microscope and did not see any shorts or opens around the nRF51822. It seems that there might be a problem inside the MCU. Other than downloading the program code, is there any other code that must be downloaded to configure the MCU?
If some of the decoupling capacitors are no connected or shorted, the MCU may fail. The MCU core runs on a separate power domain. Programming of the flash doesn't involve the MCU so even if you can program it, the HW may cause it to fail when the MCU starts.
The problem can also be soldering under the chip, CSP parts can be tricky sometimes. See if a reflow solves the problem. Or have the board x-ray'ed.
Comparing the crystal input to the MCU indicates that on a working board there is a signal (albeit distorted and at a much lower frequency because the probe is pulling it). But on the bad board nothing - sitting firmly at 0V.
Also checked the supply voltage at one of the caps (C3) and it is 3V as expected. The MCU pins are too small to probe but inspection under a microscope shows that this cap is tied to the MCU pin. I think that eliminates the "shorted decoupling cap" issue.
Also verified that SWDIO/RESET- is 3V (i.e. not held in reset).
SWDCLK and SWDIO are used to program the flash so the MCU is not involved (I agree). But if the flash can be programmed does that not prove that the chip is powered correctly? If that is true, then it seems the problem is a faulty MCU.
In light of the above, please expand on your thought that the soldering may be an issue. Unfortunately I do now have the ability to reflow or X-ray the board.
So what happens if you change your code to use the internal oscillator?
Why didn't I think of that? Actually I did but since the external crystal is required for the radio I dismissed it.
In order to try resolving the board problem I attempted to select the internal RC 16MHz clock but was unable to do it. It looks like something like the following must be in the code (but I don't know where to put it). I would think it should be in the startup code???
NRF_CLOCK->HFCLKSTAT = 0x00010000; // HFCLK running, use 16MHz RC oscillator
