nRF52832 write one service another service will also receive the same data
As already mentioned if you should properly check the handles when a Softdevice event is generated. It seems that you call your event handler in the bcon service as long as data_handler is valid, which by itself isn't a good enough check. In addition you are missing some brackets in the if sentence which results in the event handler being called as long as the program passes the if else ( which it will since data handler is valid).
static void on_write(ble_bcon_t * p_bcon, ble_evt_t const * p_ble_evt)
ble_bcon_evt_t evt;
ble_bcon_client_context_t * p_client;
ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
uint32_t err_code;
err_code = blcm_link_ctx_get(p_bcon->p_link_ctx_storage,
p_ble_evt->evt.gatts_evt.conn_handle,
(void *) &p_client);
if (err_code != NRF_SUCCESS)
NRF_LOG_ERROR("Link context for 0x%02X connection handle could not be fetched.",
p_ble_evt->evt.gatts_evt.conn_handle);
memset(&evt, 0, sizeof(ble_bcon_evt_t));
evt.p_bcon = p_bcon;
evt.conn_handle = p_ble_evt->evt.gatts_evt.conn_handle;
evt.p_link_ctx = p_client;
if ((p_evt_write->handle == p_bcon->tx_handles.cccd_handle) &&
(p_evt_write->len == 2))
if (p_client != NULL)
if (ble_srv_is_notification_enabled(p_evt_write->data))
p_client->is_notification_enabled = true;
evt.type = BLE_BCON_EVT_COMM_STARTED;
p_client->is_notification_enabled = false;
evt.type = BLE_BCON_EVT_COMM_STOPPED;
if (p_bcon->data_handler != NULL)
p_bcon->data_handler(&evt);
else if (p_bcon->data_handler != NULL)
if(p_evt_write->handle == p_bcon->major_handles.value_handle)
evt.type = BLE_BCON_EVT_MAJOR_SET;
else if(p_evt_write->handle == p_bcon->minor_handles.value_handle)
evt.type = BLE_BCON_EVT_MINOR_SET;
else if(p_evt_write->handle == p_bcon->rssi_handles.value_handle)
evt.type = BLE_BCON_EVT_RSSI_SET;
else if((p_evt_write->handle == p_bcon->uuid_handles.value_handle))
evt.type = BLE_BCON_EVT_UUID_SET;
evt.params.rx_data.p_data = p_evt_write->data;
evt.params.rx_data.length = p_evt_write->len;
Compare your on_write function with the on_write function from the NUS service, and you'll see that the latter also checks the p_evt_write->handle before it calls the event handler :
static void on_write(ble_nus_t * p_nus, ble_evt_t const * p_ble_evt)
ret_code_t err_code;
ble_nus_evt_t evt;
ble_nus_client_context_t * p_client;
err_code = blcm_link_ctx_get(p_nus->p_link_ctx_storage,
memset(&evt, 0, sizeof(ble_nus_evt_t));
evt.p_nus = p_nus;
if ((p_evt_write->handle == p_nus->tx_handles.cccd_handle) &&
evt.type = BLE_NUS_EVT_COMM_STARTED;
evt.type = BLE_NUS_EVT_COMM_STOPPED;
if (p_nus->data_handler != NULL)
p_nus->data_handler(&evt);
else if ((p_evt_write->handle == p_nus->rx_handles.value_handle) &&
(p_nus->data_handler != NULL))
evt.type = BLE_NUS_EVT_RX_DATA;
// Do Nothing. This event is not relevant for this service.
