Write to Flash during App timer_handler
I am using SDK15.0 and added the functionality of nrf_storage into the ble_app_uart in order to store the results of scan (which are kept during run time in an array in RAM).
I want to write the array to flash every 24 hours.
The command nrf_fstorage_write is working OK if it is in the main or in the uart_event_handle
But it doesn't work (Error) if it is inside the App timer handler (which is counting for 24h)
I cannot put a flag in the timer_handler and poll the flag in the main (as it was suggested before) since the polling is power consuming.
How can I do it?
  • The code is attached below
    How can I check which Error I get?
    /// Main //////////////////////////////////////////////////////////
    * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
    * All rights reserved.
    * list of conditions and the following disclaimer.
    * Semiconductor ASA integrated circuit in a product or a software update for
    * such product, must reproduce the above copyright notice, this list of
    * conditions and the following disclaimer in the documentation and/or other
    * materials provided with the distribution.
    * contributors may be used to endorse or promote products derived from this
    * software without specific prior written permission.
    * Nordic Semiconductor ASA integrated circuit.
    * engineered, decompiled, modified and/or disassembled.
    #include <stdio.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include "nordic_common.h"
    #include "app_error.h"
    #include "app_uart.h"
    #include "ble_db_discovery.h"
    #include "app_timer.h"
    #include "bsp.h"
    #include "app_util.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "nrf_soc.h"
    #include "ble_gap.h"
    #include "ble_hci.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "ble_advdata.h"
    #include "ble_nus_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "nrf_nvic.h"
    #include "nrf_fstorage_sd.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
    #define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(500, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
    #define APP_BEACON_INFO_LENGTH 0x17 /**< Total length of information advertised by the Beacon. */
    #define APP_ADV_DATA_LENGTH 0x15 /**< Length of manufacturer specific data in the advertisement. */
    #define APP_DEVICE_TYPE 0x02 /**< 0x02 refers to Beacon. */
    #define APP_MEASURED_RSSI 0xC3 /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
    #define APP_COMPANY_IDENTIFIER 0x0059 /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    #define APP_MAJOR_VALUE 0x00, 0x01 /**< Major value used to identify Beacons. */
    #define APP_MINOR_VALUE 0x03, 0x04 /**< Minor value used to identify Beacons. */
    #define APP_BEACON_UUID 0x01, 0x12, 0x23, 0x34, \
    0x45, 0x56, 0x67, 0x78, \
    0x89, 0x9a, 0xab, 0xbc, \
    0xcd, 0xde, 0xef, 0xf0 /**< Proprietary UUID for Beacon. */
    #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    APP_TIMER_DEF(bas_timer);
    #if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
    #define MAJ_VAL_OFFSET_IN_BEACON_INFO 18 /**< Position of the MSB of the Major Value in m_beacon_info array. */
    #define UICR_ADDRESS 0x10001080 /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
    static ble_gap_adv_params_t m_adv_params; /**< Parameters to be passed to the stack when starting advertising. */
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
    #define APP_BLE_CONN_CFG_TAG 1 /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
    #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shoulnd't need to modify this value. */
    #define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
    #define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
    #define SCAN_INTERVAL 0xBB80 /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW 0x0640 /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_DURATION 0x0000 /**< Timout when scanning. 0x0000 disables timeout. */
    #define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Determines minimum connection interval in millisecond. */
    #define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Determines maximum connection interval in millisecond. */
    #define SLAVE_LATENCY 0 /**< Determines slave latency in counts of connection events. */
    #define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 millisecond. */
    #define ECHOBACK_BLE_UART_DATA 1 /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
    BLE_NUS_C_DEF(m_ble_nus_c); /**< BLE NUS service client instance. */
    NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
    bool uart_on= false;
    uint32_t mac_arr[0xFF]; //Major index,hour_count
    static uint32_t flash_value;
    static uint32_t min_timer=0;
    static uint32_t pages_to_erase = 1;
    bool flash_done=false;
    static void fs_event_handler(nrf_fstorage_evt_t * evt){
    if (evt->result != NRF_SUCCESS){
    NRF_LOG_ERROR("Flash error");
    } else {
    NRF_LOG_INFO("Flash event success");
    NRF_FSTORAGE_DEF(nrf_fstorage_t m_fs1) =
    .evt_handler = fs_event_handler,
    .start_addr = 0x0007C000,
    .end_addr = 0x0007FFFF,
    NRF_FSTORAGE_DEF(nrf_fstorage_t m_fs2) =
    .start_addr = 0x0007D000,
    NRF_FSTORAGE_DEF(nrf_fstorage_t m_fs3) =
    .start_addr = 0x0007E000,
    NRF_FSTORAGE_DEF(nrf_fstorage_t m_fs4) =
    .start_addr = 0x0007F000,
    void erase_flash(nrf_fstorage_t m_fs)
    ret_code_t rc = nrf_fstorage_erase(
    &m_fs, /* The instance to use. */
    m_fs.start_addr, /* The address of the flash pages to erase. */
    pages_to_erase, /* The number of pages to erase. */
    NULL); /* Optional parameter, backend-dependent. */
    if (rc == NRF_SUCCESS)
    /* The operation was accepted.
    Upon completion, the NRF_FSTORAGE_ERASE_RESULT event
    is sent to the callback function registered by the instance. */
    if(uart_on) printf("ERASE SUCCESSFUL");
    if(uart_on) printf("ERASE UNSUCCESFUL ");
    /* Handle error.*/
    void write_to_flash(nrf_fstorage_t m_fs,int add_offset)
    ret_code_t rc;
    rc = nrf_fstorage_write(&m_fs, m_fs.start_addr+add_offset, &flash_value, 4, NULL); //Write data to memory address. Check it with command: nrfjprog --memrd addr --n 32
    if(uart_on) printf("WRITE SUCCESSFUL");
    if(uart_on) printf("WRITE UNSUCCESFUL ");
    /* Handle error.*/
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
    .adv_data =
    .p_data = m_enc_advdata,
    .len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
    .p_data = NULL,
    .len = 0
    static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] = /**< Information advertised by the Beacon. */
    APP_DEVICE_TYPE, // Manufacturer specific information. Specifies the device type in this
    // implementation.
    APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
    // manufacturer specific data in this implementation.
    APP_BEACON_UUID, // 128 bit UUID value.
    APP_MAJOR_VALUE, // Major arbitrary value that can be used to distinguish between Beacons.
    APP_MINOR_VALUE, // Minor arbitrary value that can be used to distinguish between Beacons.
    APP_MEASURED_RSSI // Manufacturer specific information. The Beacon's measured TX power in
    // this implementation.
    /**@brief Connection parameters requested for connection. */
    static ble_gap_conn_params_t const m_connection_param =
    (uint16_t)MIN_CONNECTION_INTERVAL, // Minimum connection
    (uint16_t)MAX_CONNECTION_INTERVAL, // Maximum connection
    (uint16_t)SLAVE_LATENCY, // Slave latency
    (uint16_t)SUPERVISION_TIMEOUT // Supervision time-out
    static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
    /**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
    static ble_data_t m_scan_buffer =
    m_scan_buffer_data,
    /** @brief Parameters used when scanning. */
    static ble_gap_scan_params_t const m_scan_params =
    .active = 1,
    .interval = SCAN_INTERVAL,
    .window = SCAN_WINDOW,
    .timeout = SCAN_DURATION,
    .scan_phys = BLE_GAP_PHY_1MBPS,
    .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    /**@brief NUS uuid. */
    static ble_uuid_t const m_nus_uuid =
    .uuid = BLE_UUID_NUS_SERVICE,
    .type = NUS_SERVICE_UUID_TYPE
    /**@brief Function for asserts in the SoftDevice.
    * how your product is supposed to react in case of Assert.
    * @param[in] line_num Line number of the failing ASSERT call.
    * @param[in] p_file_name File name of the failing ASSERT call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function to start scanning. */
    static void scan_start(void)
    ret_code_t ret;
    ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
    APP_ERROR_CHECK(ret);
    ret = bsp_indication_set(BSP_INDICATE_SCANNING);
    /**@brief Function for handling database discovery events.
    * @details This function is callback function to handle events from the database discovery module.
    * Depending on the UUIDs that are discovered, this function should forward the events
    * to their respective services.
    * @param[in] p_event Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
    /**@brief Function for handling characters received by the Nordic UART Service.
    * @details This function takes a list of characters of length data_len and prints the characters out on UART.
    * If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
    do
    ret_val = app_uart_put(p_data[i]);
    if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
    APP_ERROR_CHECK(ret_val);
    } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
    while (app_uart_put('\n') == NRF_ERROR_BUSY);
    if (ECHOBACK_BLE_UART_DATA)
    // Send data back to peripheral.
    do
    ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
    uint32_t err_code;
    ble_advdata_t advdata;
    uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type = BLE_ADVDATA_NO_NAME;
    advdata.flags = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    #ifdef BOARD_PCA10056
    m_adv_params.primary_phy = BLE_GAP_PHY_CODED;
    m_adv_params.secondary_phy = BLE_GAP_PHY_CODED;
    m_adv_params.scan_req_notification = 0;
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_EXTENDED_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
    m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration = 0; // Never time out.
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_adv_handle, 8); //+8dBm
    APP_ERROR_CHECK(err_code);}
    #ifdef BOARD_PCA10040
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_adv_handle, -4); //-4dBm
    ret_code_t err_code;
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    /**@brief Function for handling app_uart events.
    * a string. The string will be be sent over BLE when the last character received was a
    * 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    static uint16_t index = 0;
    switch (p_event->evt_type)
    /**@snippet [Handling data from UART] */
    case APP_UART_DATA_READY:
    index++;
    if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
    if (data_array[0]=='E' && data_array[1]=='R' && data_array[2]=='F')
    sd_ble_gap_adv_stop(m_adv_handle);
    sd_ble_gap_scan_stop();
    if (data_array[3]=='1') erase_flash(m_fs1);
    else if (data_array[3]=='2') erase_flash(m_fs2);
    else if (data_array[3]=='3') erase_flash(m_fs3);
    else if (data_array[3]=='4') erase_flash(m_fs4);
    advertising_init();
    advertising_start();
    scan_start();
    else if (data_array[0]=='R' && data_array[1]=='D' && data_array[2]=='F')
    int *mem;
    if (data_array[3]=='1') mem = (int *)(0x0007C000+(data_array[4]-'0')*100+(data_array[5]-'0')*10+(data_array[6]-'0'));
    else if (data_array[3]=='2') mem = (int *)(0x0007D000+(data_array[4]-'0')*100+(data_array[5]-'0')*10+(data_array[6]-'0'));
    else if (data_array[3]=='3') mem = (int *)(0x0007E000+(data_array[4]-'0')*100+(data_array[5]-'0')*10+(data_array[6]-'0'));
    else if (data_array[3]=='4') mem = (int *)(0x0007F000+(data_array[4]-'0')*100+(data_array[5]-'0')*10+(data_array[6]-'0'));
    int temp = *mem;
    if (uart_on) printf("tag found:%x",temp);
    else if (data_array[0]=='R' && data_array[1]=='D' && data_array[2]=='M')
    if (uart_on) printf("Mac_array[%d]:%x",(data_array[3]-'0')*100+(data_array[4]-'0')*10+data_array[5]-'0',
    mac_arr[(data_array[3]-'0')*100+(data_array[4]-'0')*10+data_array[5]-'0']);
    else if (data_array[0]=='W' && data_array[1]=='R' && data_array[2]=='F')
    flash_value = data_array[7];
    if (data_array[3]=='1') write_to_flash(m_fs1,(data_array[4]-'0')*100+(data_array[5]-'0')*10+(data_array[6]-'0'));
    else if (data_array[3]=='2') write_to_flash(m_fs2,(data_array[4]-'0')*100+(data_array[5]-'0')*10+(data_array[6]-'0'));
    else if (data_array[3]=='3') write_to_flash(m_fs3,(data_array[4]-'0')*100+(data_array[5]-'0')*10+(data_array[6]-'0'));
    else if (data_array[3]=='4') write_to_flash(m_fs4,(data_array[4]-'0')*100+(data_array[5]-'0')*10+(data_array[6]-'0'));
    advertising_init();
    scan_start();
    index = 0;
    NRF_LOG_ERROR("Communication error occurred while handling UART.");
    case APP_UART_FIFO_ERROR:
    NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@brief Callback handling NUS Client events.
    * @details This function is called to notify the application of NUS client events.
    * @param[in] p_ble_nus_c NUS Client Handle. This identifies the NUS client
    * @param[in] p_ble_nus_evt Pointer to the NUS Client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
    case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
    NRF_LOG_INFO("Discovery complete.");
    err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
    err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
    NRF_LOG_INFO("Connected to device with Nordic UART Service.");
    case BLE_NUS_C_EVT_NUS_TX_EVT:
    ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
    case BLE_NUS_C_EVT_DISCONNECTED:
    NRF_LOG_INFO("Disconnected.");
    scan_start();
    * @brief Function for shutdown events.
    * @param[in] event Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
    case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
    // Prepare wakeup buttons.
    return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    /**@brief Function for handling the advertising report BLE event.
    * @param[in] p_adv_report Advertising report from the SoftDevice.
    static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
    uint8_t uuid[30];
    memmove(uuid, p_adv_report->data.p_data, p_adv_report->data.len);
    if (uuid[9]==0x01 && uuid[10]==0x12 && uuid[11]==0x23 && uuid[12]==0x34)
    if(uart_on) printf("MAC: %x%x%x%x%x%x ",p_adv_report->peer_addr.addr[0], p_adv_report->peer_addr.addr[1],
    p_adv_report->peer_addr.addr[2],p_adv_report->peer_addr.addr[3],p_adv_report->peer_addr.addr[4],
    p_adv_report->peer_addr.addr[5]);
    if(uart_on) printf("MAJOR: %x%x\n", uuid[25], uuid[26]);
    mac_arr[uuid[25]*10+uuid[26]] = (p_adv_report->rssi)*256+min_timer;
    mac_arr[p_adv_report->peer_addr.addr[0]] = 1;
    if (ble_advdata_uuid_find(p_adv_report->data.p_data, p_adv_report->data.len, &m_nus_uuid))
    err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
    &m_scan_params,
    &m_connection_param,
    if (err_code == NRF_SUCCESS)
    // scan is automatically stopped by the connect
    NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
    err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
    * @param[in] p_ble_evt Bluetooth stack event.
    * @param[in] p_context Unused.
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
    case BLE_GAP_EVT_ADV_REPORT:
    on_adv_report(&p_gap_evt->params.adv_report);
    break; // BLE_GAP_EVT_ADV_REPORT
    case BLE_GAP_EVT_CONNECTED:
    NRF_LOG_INFO("Connected to target");
    err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
    // start discovery of services. The NUS Client waits for a discovery result
    err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
    case BLE_GAP_EVT_TIMEOUT:
    if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
    NRF_LOG_INFO("Scan timed out.");
    scan_start();
    else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
    NRF_LOG_INFO("Connection Request timed out.");
    // Pairing not supported
    err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
    case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
    // Accepting parameters requested by peer.
    err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
    &p_gap_evt->params.conn_param_update_request.conn_params);
    ble_gap_phys_t const phys =
    .rx_phys = BLE_GAP_PHY_AUTO,
    .tx_phys = BLE_GAP_PHY_AUTO,
    } break;
    case BLE_GATTC_EVT_TIMEOUT:
    case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
    NRF_LOG_INFO("ATT MTU exchange completed.");
    m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
    NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    * @param[in] event Event generated by button press.
    switch (event)
    case BSP_EVENT_SLEEP:
    nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
    case BSP_EVENT_DISCONNECT:
    err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
    /**@brief Function for initializing the UART. */
    static void uart_init(void)
    .rx_pin_no = RX_PIN_NUMBER,
    .tx_pin_no = TX_PIN_NUMBER,
    .rts_pin_no = RTS_PIN_NUMBER,
    .cts_pin_no = CTS_PIN_NUMBER,
    .use_parity = false,
    .baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
    UART_RX_BUF_SIZE,
    UART_TX_BUF_SIZE,
    uart_event_handle,
    APP_IRQ_PRIORITY_LOWEST,
    err_code);
    /**@brief Function for initializing the NUS Client. */
    static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler = ble_nus_c_evt_handler;
    err_code = ble_nus_c_init(&m_ble_nus_c, &init);
    /**@brief Function for initializing buttons and leds. */
    static void buttons_leds_init(void)
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
    void bas_timer_handler(void * p_context)
    min_timer = min_timer+1;
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
    err_code = app_timer_create(&bas_timer,APP_TIMER_MODE_REPEATED,bas_timer_handler);
    /**@brief Function for initializing the nrf log module. */
    static void log_init(void)
    /** @brief Function for initializing the Database Discovery Module. */
    static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
    * @details Handle any pending log operation(s), then sleep until the next event occurs.
    nrf_pwr_mgmt_run();
    uint32_t err_code;
    // Initialize.
    log_init();
    timer_init();
    for (int i=0;i<100;i++)
    mac_arr[i]=0;
    err_code = nrf_fstorage_init(&m_fs1, &nrf_fstorage_sd, NULL);
    err_code = nrf_fstorage_init(&m_fs2, &nrf_fstorage_sd, NULL);
    err_code = nrf_fstorage_init(&m_fs3, &nrf_fstorage_sd, NULL);
    err_code = nrf_fstorage_init(&m_fs4, &nrf_fstorage_sd, NULL);
    app_timer_start(bas_timer, APP_TIMER_TICKS((60*1000)), NULL);
    nrf_gpio_cfg_input(11,NRF_GPIO_PIN_PULLUP);
    nrf_delay_ms(1000);
    if(!nrf_gpio_pin_read(11)) uart_on = true;
    nrf_gpio_cfg_input(11,NRF_GPIO_PIN_NOPULL);
    if(uart_on) uart_init();
    buttons_leds_init();
    db_discovery_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    nus_c_init();
    advertising_init();
    // Start execution.
    if(uart_on) printf("BLE UART central example started.\r\n");
    NRF_LOG_INFO("BLE UART central example started.");
    scan_start();
    // Enter main loop.
    for (;;)
    if ((min_timer % 3)==1 && !flash_done)
    flash_done = true;
    int i=1;
    if (mac_arr[i]!=0)
    flash_value = mac_arr[i];
    if(uart_on) printf("Write to Flash %d", mac_arr[i]);
    write_to_flash(m_fs1,(min_timer/3)*100+i*4);
    nrf_delay_ms(100);
    advertising_init();
    scan_start();
    else if ((min_timer % 3)==2) flash_done=false;
    idle_state_handle();
  • If you are going to include code, please use the "insert"->"code" functionality.
    I don't know what error you encountered. You said that you had an error: "But it doesn't work (Error) if it is inside the App timer handler (which is counting for 24h)". What does that mean? Is it because you see the "WRITE UNSUCCESFUL" in the log?
  • Eventually I implemented the flash write inside the main as suggested, current consumption is OK. So, I am satisfied with the solution.
    Thank you
