Secure DFU Bootloader BLE not working with nRF Connect PC
What could be the reasons that cause DFU Bootloader BLE not working with nRF Connect on PC (while it works with nRF Connect on iOS)? I have had various problem with nRF Connect on PC so far:
1/ With my custom board: I modified the custom_board.h and create a new bootloader for my custom board. I can find the board on nRF Connect scanner, connect to it, but can't load new zip file through the DFU service. I attached the screenshot, the nRF Connect log file and the log file from my custom board (nRF52382) for more information.
 nrfConnect_bootloader_log.txt
00> <info> app: Inside main
00> <debug> app: In nrf_bootloader_init
00> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
00> <debug> nrf_dfu_settings: Resetting bootloader settings.
00> <debug> nrf_dfu_settings: Writing settings...
00> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 0
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x200092A4, len=440 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
00> <debug> app: Enter nrf_bootloader_fw_activate
00> <info> app: No firmwareto activate.
00> <debug> app: Enter nrf_dfu_app_is_valid
00> <debug> app: Return false in valid app check
00> <debug> app: DFU mode because app is not valid.
00> <info> nrf_bootloader_wdt: WDT is not enabled
00> <debug> app: in weak nrf_dfu_init_user
00> <info> app_timer: RTC: initialized.
00> <info> app: Entering DFU mode.
00> <debug> app: Initializing transports (found: 1)
00> <debug> nrf_dfu_ble: Initializing BLE DFU transport
00> <debug> nrf_dfu_ble: Setting up vector table: 0x00072000
00> <debug> nrf_dfu_ble: Enabling SoftDevice.
00> <debug> nrf_dfu_ble: Configuring BLE stack.
00> <debug> nrf_dfu_ble: Enabling the BLE stack.
00> <debug> nrf_dfu_ble: No advertising name found
00> <debug> nrf_dfu_ble: Using default advertising name
00> <debug> nrf_dfu_ble: Advertising...
00> <debug> nrf_dfu_ble: BLE DFU transport initialized.
00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
00> <debug> app: Enter main loop
00> <debug> nrf_dfu_ble: Connected
00> <debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
00> <debug> nrf_dfu_ble: max_conn_interval: 12
00> <debug> nrf_dfu_ble: min_conn_interval: 12
00> <debug> nrf_dfu_ble: slave_latency: 0
00> <debug> nrf_dfu_ble: conn_sup_timeout: 600
00> <debug> nrf_dfu_ble: Finished handling conn sec update
00> <debug> nrf_dfu_ble: Set receipt notif
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
00> <debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 247, reply: 247).
00> <debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST.
00> <debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE (251, max_rx_time 2120).
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
00> <debug> app: Shutting down transports (found: 1)
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
2/ With my nRF52 development board (PCA 10040): For this board, I tried both the bootloaders from SDK15.0.0\examples\dfu\secure_bootloader\pca10040_ble and pca10040_ble_debug. In both case the nRF Connect on PC does not see the board on the scanner. There is no "DFU Targ" device. I had this problem with my custom board before, and fixed it by changing the LF Clock  setting in sdk_config.h but with PCA10040 I have tried different combinations settings but it still didn't work.
Note that the bootloaders work okay on both boards when I used nRF Connect on iOS. I use softdevice s132v6.0.0 and sdk15.0.0.
  • I forgot to mention, I also need to switch the library for micro-ecc because I use IAR 8 (according to SDK v16 Note Release).
    I have tried to unzip an unmodified SDK, but got the same error. After the error, the DK that I used for nRF Connect BLE Scan froze. After power cycle the DK, it can scan normally, but it doesn't see the DFU Targ device. I have to reprogram the DK in order to see the DFU Targ on Scanner.
    I have tried the bootloader with a DK, and same thing happened. Could it be something wrong with nRF Connect? I have nRF Connect v3.3.0 and Bluetooth Low Energy tool v2.3.2
  • Ok, so it seems like the bootloader may not be the issue afterall. Perhaps you can try to update to nRF Connect v3.3.2. Also, please check your Segger version. What version do you currently have?
    I see that I have nRF Connect v3.3.2 and Bluetooth Low Energy tool 2.3.2. Can you try to update the nRF Connect version?
    Also, I have JLink version v6.70e. Can you try this version if you don't already have it?
    BR,
    Edvin
  • I found the problem. I didn't attach the private key when generate the dfu package. It seems like nRF Connect on iOS doesn't check for the key while nRF Connect on PC does.
    Anyway, thanks for your help!
