nRF9160 modem states 20, 21, 30, 31, 44
The modem reports that it supports states 0, 1, 4, 20, 21, 30, 31, 44 when I give the "AT+CFUN=?" command.
Using the at_client sample, or other software like asset_tracker, and now that I know to not check "Automatic requests" in LTE Link Monitor, the only states I can read back
using "AT+CFUN?" are 0, 1, and 4, even if I issue the command "AT+CFUN=x" where x is one of 20, 21, 30, 31, or 44. How do I get to states 20, 21, 30, 31, and/or 44? Thanks.
  • Okay, Oyvind, it sounds like when I am programming, I should not concern myself whether LTE or GNSS is currently on: if I am not sure about the state, and I know, for example, that I want LTE on, I should just go ahead and issue AT+CFUN=21. I am sure that will work -- I just wanted to know that I was not missing any secret status indicator. I will go ahead and close this ticket out next.
  • Hi Øyvind,
    If you send AT+CFUN=20 twice, the modem responds with an error. That means there is not only no way to check which parts of the modem are on or not, but no way enforce them either.
    For example:
    Device has GPS on with AT+CFUN=31. Device tries to turn modem on with AT+CFUN=21, but gets an error. The Device now can't check what state the modem is in, and any attempts to call AT+CFUN=20 return an error, but the device doesn't know if that is because it is already off or because of some other reason.
    Should't calls to AT+CFUN=30 and AT+CFUN=20 return OK if they are already off?
    Thomas
