NFC is unstable when DCDEN1 is enabled.
I am using nRF52840 DK on VDD_HV. SW9 (nRF power source) set to USB and I am connecting a USB cable to J3 (nRF USB). SW6 is also set to nRF Only. My IC revision is QIAAD0.
In an effort to further reduce current consumption, I have recently tried to enable DCDEN0 with a REGOUT0 setting of 3V0. This works well. However, if I enable DCDEN1 the NFC communication becomes unstable. The FDT is no longer accurate and sometimes ends us in a timeout NAK. I could see the FDT errors in my NFC sniffer. Setting DCDEN1 back to 0x00000000 makes the problem go away but it consumes more power.
I checked the errata documents and I am not sure if this is related to
[218] NFCT: Frame delay timing is too short after SLP_REQ
I suspect that maybe enabling DCDEN1 has a crippling effect on TIMER4?
My firmware does not use a soft device. It is based on the NFC Tag text example from SDK 16.0.0, but I imported a customized hal_t2t.c from sdk 15.2.0 instead of using the precompiled lib.
I have tested this anomaly on 12 different nfc readers and my firmware becomes unusable on 5 readers which possibly have stricter timing constrainsts.
So my question is: How can I use DCDEN1 without affecting NFC FDT?
Best Regards
