Frequency detector possible?
Hi. Can anyone think of a way to use the nRF52832 (probably Timer) to detect approximately 125KHz-150KHz variable square wave down to about a 1Hz resolution? I'd like to detect frequency changes at about 100 times a second though. Ideally I'd like to do this without any external hardware (like a heterodyne mixer). Thoughts? Thanks!
(FINAL answer at very bottom. The answer is YES, the nRF52832 can be used even with a SoftDevice to accurately detect a few hundred KHz signal down to a few Hz resolution)
  • This isn't a reply to the last question - dmitry is doing a great job there :-) - but a technique you can use to get enhanced resolution once your code is working.
    In essence once you have a count of the number of input signal cycles in the 10mSec measurement period, we need a way to interpolate the distance from the last input edge trigger (let's assume +ve edge) to the point in time when the 10mSec measurement period terminates. You mention limiting the external hardware, so how about a single capacitor? Well, maybe a resistor as well; using a series capacitor only risks exceeding the rails depending on the input signal, so safer to use a resistor feed to a different layout.
    Feed the input signal to a digital port pin (as now) where the input cycles are counted for the 10mSec sampling interval. Feed the same input signal through a series resistor to a capacitor (to Gnd, acting as an integrator) and a second analogue (analog) port pin. Bias the input signal ac coupling to 50% by enabling both pull-up and pull-down resistor ladders CONFIG.RESP and CONFIG.RESN, although you might get away not doing that. Now (hopefully) taking an SAADC measurement on this ADC channel provides an indication of the time since last +ve edge in conjunction with the knowledge of the current high or low status of the digital input pin (indicates rising or falling voltage) given a suitable capacitor selection (depends on source impedance). Some simple (not-so-simple) math or a simple look-up table converts this voltage into an accurate indication of the point in time in the last cycle when the 10mSec measurement interval terminated provided the SAADC sample is triggered by that same event. Adding that point in time to the coarse measurement and subtracting the deterministic SAADC sampling/conversion time  gives the required fine measurement. 16MHz asynchronous measurement issues ( I know you would ask that) falls out (hopefully) in the wash. Amazing, what?
  • Could you look in the debugger, does your counter ever counts something?
    The method suggested by  is very interesting, I just add that ADC measurement should be done at both edges (first and last), because GPIOTE event is synchronized with PCLK in both cases.
  • OK, finally got things working. Mostly... Turns out the problem I had was in misconfiguring the PPI's. This fixes that and now I am reading frequencies:
    #define FREQ_MEASURE_PIN  11												// P0.11
    #define kPulseDetectionCount 1000											// Detect this many +edges
    static void freqDetectorInit(void)
    		// Pin & GPIOTE init
        IOPinConfig(0, FREQ_MEASURE_PIN, 0, IOPINDIR_INPUT, IOPINRES_NONE, IOPINTYPE_NORMAL);
    	NRF_GPIOTE->CONFIG[0] = 0x01 << 0; 								// Event mode
    	NRF_GPIOTE->CONFIG[0] |= FREQ_MEASURE_PIN << 8;					// Pin number
    	NRF_GPIOTE->CONFIG[0] |= GPIOTE_CONFIG_POLARITY_LoToHi << 16;	// Event rising edge
    		// Calls TIMER4_IRQHandler
    	NVIC_SetPriority(TIMER4_IRQn, APP_IRQ_PRIORITY_LOW);
    	NVIC_EnableIRQ(TIMER4_IRQn);
    		// Timer 4: Rising edge event counter - detect 1000 +edges then generate an interrupt
    	NRF_TIMER4->TASKS_STOP = 1;
    	NRF_TIMER4->MODE = TIMER_MODE_MODE_Counter;												// Counting external pulses
    	NRF_TIMER4->BITMODE = TIMER_BITMODE_BITMODE_16Bit << TIMER_BITMODE_BITMODE_Pos;			// Only need 16 bits to count 1000 pulses
    	NRF_TIMER4->CC[0] = kPulseDetectionCount + 1;											// # pulses to detect (+1)
    	NRF_TIMER4->TASKS_CLEAR = 1;
    	NRF_TIMER4->INTENSET = TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos;	// Generate int when done to get results
    	NRF_TIMER4->TASKS_START = 1;
    		// Timer 3: 16MHz timer during 1000 events
    	NRF_TIMER3->TASKS_STOP = 1;
    	NRF_TIMER3->MODE = TIMER_MODE_MODE_Timer;
    	NRF_TIMER3->BITMODE = TIMER_BITMODE_BITMODE_32Bit << TIMER_BITMODE_BITMODE_Pos;
    	NRF_TIMER3->PRESCALER = 0;
    	NRF_TIMER3->CC[0] = 0;
    	NRF_TIMER3->TASKS_CLEAR = 1;
    		// Using PPI CH0, connect NRF_TIMER4->EVENTS_COMPARE[0] (1000 +transitions) event to NRF_TIMER3->TASKS_CAPTURE[0] (capture the count of 0.0625us periods) task
    		// Add a 2nd task to clear counter and start timer. These together avoid a possible 'spurious' GPIO transition between clearing counter and starting timer
    	NRF_PPI->CH[0].EEP = (uint32_t)&NRF_TIMER4->EVENTS_COMPARE[0];
    	NRF_PPI->CH[0].TEP = (uint32_t)&NRF_TIMER3->TASKS_CAPTURE[0];
    	NRF_PPI->FORK[0].TEP = (uint32_t)&NRF_TIMER3->TASKS_CLEAR;
    	NRF_PPI->CHENSET = 1 << 0;
    		 // On PPI CH1, when a GPIOTE rise event happens start TIMER3 and increment TIMER4
    	NRF_PPI->CH[1].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[0];
    	NRF_PPI->CH[1].TEP = (uint32_t)&NRF_TIMER3->TASKS_START;
    	NRF_PPI->FORK[1].TEP = (uint32_t)&NRF_TIMER4->TASKS_COUNT;
    	NRF_PPI->CHENSET = 1 << 1;										// Go
    static volatile uint32_t pulsesDetected = 0;
    static volatile uint32_t freqDetected = 0;
    extern "C" void TIMER4_IRQHandler(void)
    	if (NRF_TIMER4->EVENTS_COMPARE[0]) {
    		NRF_PPI->CHENCLR = 1 << 1;				// Disable PPI channel CH1 that initiated counting
    		NRF_TIMER3->TASKS_STOP = 1;				// Stop our counter (& do a capture)
    		pulsesDetected = NRF_TIMER3->CC[0];		// Get detected pulses: total count for 1000 +edge events (in 0.0625us units)
    		freqDetected = (pulsesDetected == 0) ? 0 : (16000000.0 * (float)kPulseDetectionCount) / pulsesDetected;
    		pulsesDetected = 0;
    		NRF_TIMER3->TASKS_CLEAR = 1;			// Reset timers
    		NRF_TIMER4->EVENTS_COMPARE[0] = 0;		// Reset for next
    		NRF_PPI->CHENSET = 1 << 1;				// Re-enable PPI - go again
    But there are 2 interesting anomalies:
    1) There is a fixed frequency offset of about 500-600hz. When I measure a dead accurate 100KHz signal, I get frequency readings ranging from 100400 to about 100600.
    2) There is a lot of jitter in the measurement even after 1000 pulses have transpired. I would expect a few Hz difference from reading to reading but I am seeing differences of around 200Hz in the readings.
    Thoughts?
  • Thanks again for the input Hugh. If I understand you correctly, your idea is to try to accurately resolve the very last pulse in the 1000 pulse train - basically to compare the phase difference between when the last pulse happens and when the last sampling of that pulse happens, right?
    If that is a correct understanding, I don't know how much that solution might help given that I am sampling 1000 pulses in order to determine frequency and even if the last pulse was mis-measured the worst it could be (1/2 the pulse width), wouldn't the averaging of the other 999 pulses wash that mistaken measurement out for the most part? I could see where your idea would totally help if I were measuring only a single pulse, but given the large sampling and averaging that is happening, I think that might not result in such a huge accuracy improvement.
    Or maybe I don't fully understand what you are resolving with this refinement...
    In any case, thanks for the input none-the-less!
  • Did you start HFCLK? Don't expect an accurate result from an internal oscillator.
