How to add buttonless_dfu and serial_dfu functions at the same time.
Now the code in the application part has added the buttonless_dfu function, which has also been successfully implemented. But I ’m not familiar with serial_dfu, I don’t know how to continue to add serial_dfu function. And how to achieve coexistence of ble_dfu and serial_dfu in bootload code?
  • I try to use pca10056_uart project, only use serial_dfu, will not use HWFC, the serial port baud rate is changed to 9600
    nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
        uart_config.pseltxd   = TX_PIN_NUMBER;
        uart_config.pselrxd   = RX_PIN_NUMBER;
        uart_config.pselcts   = CTS_PIN_NUMBER;
        uart_config.pselrts   = RTS_PIN_NUMBER;
    //    uart_config.hwfc      = NRF_DFU_SERIAL_UART_USES_HWFC ?
    //                                NRF_UART_HWFC_ENABLED : NRF_UART_HWFC_DISABLED;
    		uart_config.hwfc      = NRF_UART_HWFC_DISABLED;
    		uart_config.baudrate  = 2576384; // Corresponds to 9600 baud
        uart_config.p_context = &m_serial;
    The following changes were made in the dfu_transport_serial.py file in the pc-nrfutil-master \ nordicsemi \ dfu path
    class DfuTransportSerial(DfuTransport):
        DEFAULT_BAUD_RATE = 9600 #115200
        DEFAULT_FLOW_CONTROL = False #True
        DEFAULT_TIMEOUT = 30.0  # Timeout time for board response
        DEFAULT_SERIAL_PORT_TIMEOUT = 1.0  # Timeout time on serial port read
        DEFAULT_PRN                 = 0
        DEFAULT_DO_PING = True
        OP_CODE = {
            'CreateObject'          : 0x01,
            'SetPRN'                : 0x02,
            'CalcChecSum'           : 0x03,
            'Execute'               : 0x04,
            'ReadError'             : 0x05,
            'ReadObject'            : 0x06,
            'GetSerialMTU'          : 0x07,
            'WriteObject'           : 0x08,
            'Ping'                  : 0x09,
            'Response'              : 0x60,
    Execute
    nrfutil dfu serial -pkg production_DFU.zip -p COM14 -b 9600
    instruction still error
      File "D:\Application\Python38\Scripts\nrfutil-script.py", line 11, in <module>
        load_entry_point('nrfutil==6.0.1', 'console_scripts', 'nrfutil')()
      File "D:\Application\Python38\lib\site-packages\click-7.1.1-py3.8.egg\click\core.py", line 829, in __call__
        return self.main(*args, **kwargs)
      File "D:\Application\Python38\lib\site-packages\click-7.1.1-py3.8.egg\click\core.py", line 782, in main
        rv = self.invoke(ctx)
      File "D:\Application\Python38\lib\site-packages\click-7.1.1-py3.8.egg\click\core.py", line 1259, in invoke
        return _process_result(sub_ctx.command.invoke(sub_ctx))
      File "D:\Application\Python38\lib\site-packages\click-7.1.1-py3.8.egg\click\core.py", line 1066, in invoke
        return ctx.invoke(self.callback, **ctx.params)
      File "D:\Application\Python38\lib\site-packages\click-7.1.1-py3.8.egg\click\core.py", line 610, in invoke
        return callback(*args, **kwargs)
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\__main__.py", line 1055, in serial
        do_serial(package, port, connect_delay, flow_control, packet_receipt_notification, baud_rate, serial_number, True,
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\__main__.py", line 970, in do_serial
        dfu.dfu_send_images()
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu.py", line 127, in dfu_send_images
        self._dfu_send_image(self.manifest.application)
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu.py", line 95, in _dfu_send_image
        self.dfu_transport.send_init_packet(data)
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu_transport_serial.py", line 255, in send_init_packet
        self.__stream_data(data=init_packet)
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu_transport_serial.py", line 474, in __stream_data
        response = self.__calculate_checksum()
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu_transport_serial.py", line 409, in __calculate_checksum
        response = self.__get_response(DfuTransportSerial.OP_CODE['CalcChecSum'])
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu_transport_serial.py", line 491, in __get_response
        raise NordicSemiException('Unexpected Executed OP_CODE.\n' \
    pc_ble_driver_py.exceptions.NordicSemiException: Unexpected Executed OP_CODE.
    Expected: 0x03 Received: 0x64
    PS D:\Application\Python38\Scripts\DFU\UART\15.3-52840> nrfutil dfu serial -pkg production_DFU.zip -p COM14 -b 9600
  • Could you verify that you can do serial DFU with the stock serial DFU example (not my combination example) ? it's the uart projects inside \examples\dfu\secure_bootloader
  • I verified and reported this error:
  • How does it has anything to do with pc_ble_driver_py ?
    Could you post the full logging of the command line ?
    Please test with the uart example in \examples\dfu\secure_bootloader.
  • I used the uart examples in \ examples \ dfu \ secure_bootloader. The full log of the command line is as follows:
