How to add buttonless_dfu and serial_dfu functions at the same time.
Now the code in the application part has added the buttonless_dfu function, which has also been successfully implemented. But I ’m not familiar with serial_dfu, I don’t know how to continue to add serial_dfu function. And how to achieve coexistence of ble_dfu and serial_dfu in bootload code?
  • The error message is as follows:
      File "D:\Application\Python38\Scripts\nrfutil-script.py", line 11, in <module>
        load_entry_point('nrfutil==6.0.1', 'console_scripts', 'nrfutil')()
      File "D:\Application\Python38\lib\site-packages\click-7.1.1-py3.8.egg\click\core.py", line 829, in __call__
        return self.main(*args, **kwargs)
      File "D:\Application\Python38\lib\site-packages\click-7.1.1-py3.8.egg\click\core.py", line 782, in main
        rv = self.invoke(ctx)
      File "D:\Application\Python38\lib\site-packages\click-7.1.1-py3.8.egg\click\core.py", line 1259, in invoke
        return _process_result(sub_ctx.command.invoke(sub_ctx))
      File "D:\Application\Python38\lib\site-packages\click-7.1.1-py3.8.egg\click\core.py", line 1066, in invoke
        return ctx.invoke(self.callback, **ctx.params)
      File "D:\Application\Python38\lib\site-packages\click-7.1.1-py3.8.egg\click\core.py", line 610, in invoke
        return callback(*args, **kwargs)
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\__main__.py", line 1055, in serial
        do_serial(package, port, connect_delay, flow_control, packet_receipt_notification, baud_rate, serial_number, True,
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\__main__.py", line 970, in do_serial
        dfu.dfu_send_images()
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu.py", line 127, in dfu_send_images
        self._dfu_send_image(self.manifest.application)
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu.py", line 88, in _dfu_send_image
        self.dfu_transport.open()
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu_transport_serial.py", line 217, in open
        self.__get_mtu()
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu_transport_serial.py", line 364, in __get_mtu
        response = self.__get_response(DfuTransportSerial.OP_CODE['GetSerialMTU'])
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu_transport_serial.py", line 504, in __get_response
        raise NordicSemiException('Response Code {}'.format(
    pc_ble_driver_py.exceptions.NordicSemiException: Response Code NotSupported
  • Is it convenient to provide the code based on SDK 15.3? I really don't know where is the bug
  • Hi Hung,
    I tried it in the ble_uart_debug ses project transplanted based on SDK 15.3, there is already log output, the following is the log generated during the DFU process
    <debug> nrf_dfu_serial: Received ping 1
    <info> nrf_dfu_serial_uart: Allocated buffer 2000B08C
    <info> nrf_dfu_req_handler: Invalid opcode received: 0x9.
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x2
    <warning> nrf_dfu_serial: DFU request completed with result: 0x2
    <debug> nrf_dfu_serial: Sending Response: [0x9, 0x2]
    <debug> nrf_dfu_serial: Set receipt notif target: 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_serial: Sending Response: [0x2, 0x1]
    <debug> nrf_dfu_serial: Received serial mtu
    <info> nrf_dfu_req_handler: Invalid opcode received: 0x7.
    <debug> nrf_dfu_serial: Sending Response: [0x7, 0x2]
    Among them, I noticed a warning
    Will this be the key factor for my upgrade failure?
  • Hi June,
    Could you verify that you can test my example in SDK v15.2 and it works without any issue ?
    This way we can rule out any issue with the hardware or nrfutil.
  • Your example program is normal on the 52832DK board, but on the 52840DK board, once the HWFC is turned off, although I have reduced the baud rate to 9600 and executed the MSDDisable command, the upgrade will still fail
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu.py", line 100, in _dfu_send_image
        self.dfu_transport.send_firmware(data)
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu_transport_serial.py", line 301, in send_firmware
        response['crc'] = self.__stream_data(data=data, crc=response['crc'], offset=i)
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu_transport_serial.py", line 474, in __stream_data
        response = self.__calculate_checksum()
      File "D:\Application\Python38\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\dfu\dfu_transport_serial.py", line 412, in __calculate_checksum
        raise NordicSemiException('Did not receive checksum response from DFU target. '
    pc_ble_driver_py.exceptions.NordicSemiException: Did not receive checksum response from DFU target. If MSD is enabled on the target device, try to disable it ref. https://wiki.segger.com/index.php?title=J-Link-OB_SAM3U
