nrfx_gpiote interrupt causing hard fault
Hi
Using the nrf52840-dk with SD S140 and nrfx_gpiote, everything runs fund (BLE, TWI etc) but interrup on pin 0,28 causes a Hard Fault. I can not get any sensible logs to diagnose the issue (I'm using VSC and not familiar with Debug).
//IMU Interrup PIN Handler
    nrfx_gpiote_in_config_t in_config = NRFX_GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
    in_config.pull = NRF_GPIO_PIN_PULLDOWN; //NRF_GPIO_PIN_NOPULL;
    in_config.hi_accuracy = true;
    err_code = nrfx_gpiote_in_init(MPU_INT_PIN, &in_config, in_pin_handler);
    nrfx_gpiote_in_event_enable(MPU_INT_PIN, true);
Any ideas?
Thanks
  • Hi
    This is the output from arm-none-eabi-gdb:
    c
    Continuing.
    {"token":33,"outOfBandRecord":[],"resultRecords":{"resultClass":"running","results":[]}}
    Program
     received signal SIGTRAP, Trace/breakpoint trap.
    0x00028a10 in app_error_fault_handler (id=id@entry=16385, pc=pc@entry=0, info=info@entry=537132804) at ../../../../nRF5SDK160098a08e2/components/libraries/util/app_error_weak.c:100
    100	    NRF_BREAKPOINT_COND;
    bt full
    #0  0x00028a10 in app_error_fault_handler (id=id@entry=16385, pc=pc@entry=0, info=info@entry=537132804) at ../../../../nRF5SDK160098a08e2/components/libraries/util/app_error_weak.c:100
    No locals.
    #1  0x000289dc in app_error_handler_bare (error_code=<optimized out>) at ../../../../nRF5SDK160098a08e2/components/libraries/util/app_error.c:73
            error_info = {line_num = 0
    , p_file_name = 0x0
    , err_code = 537132796
    #2  0x000343d4 in ble_stack_init () at ../../../main.c:635
            LOCAL_ERR_CODE = <optimized out>
            err_code = <optimized out>
            ram_start = 785441024
    Thank you for the stack trace.
    The compiler is optimizing a bit too much here, but I suspect this error is due to the amount of RAM that the stack is given.
    Could you try to adjust the RAM start address in your linker script (.ld file in your armgcc folder) to see if this helps?
    https://devzone.nordicsemi.com/nordic/short-range-guides/b/getting-started/posts/adjustment-of-ram-and-flash-memory
    If you change the optimization level to "-Og -ggdb" in your makefile, and recompile/flash, you should see more symbols in the debug view. If you in addition, add the CFLAGS += -DDEBUG, you will enable blocking assertions with "error_info" struct above being populated with file name, line number, error code, so you can see exactly where the assert occurred.
    Håkon
  • Hi
    After a lot of stepping through, I've found that I receive the following error after receding and interrupt signal on P0,28:
    "SOFTDEVICE: ASSERTION FAILED" which is followed by: NRF_BREAKPOINT_COND (On assert, the system can only recover with a reset.
    This is the output I get from Debug Console:
    0001431775: 5929-exec-continue --thread 1
    0001431776: GDB -> App: {"token":5929,"outOfBandRecord":[],"resultRecords":{"resultClass":"running","results":[]}}
    0001431776: GDB -> App: {"outOfBandRecord":[{"isStream":false,"type":"exec","asyncClass":"running","output":[["thread-id","all"]]}]}
    0001442172: GDB -> App: {"outOfBandRecord":[{"isStream":true,"type":"console","content":"\nProgram"}]}
    0001442172:
    Program
    0001442172: GDB -> App: {"outOfBandRecord":[{"isStream":true,"type":"console","content":" received signal SIGTRAP, Trace/breakpoint trap.\n"}]}
    0001442172:  received signal SIGTRAP, Trace/breakpoint trap.
    0001442176: GDB -> App: {"outOfBandRecord":[{"isStream":true,"type":"console","content":"0x00028724 in app_error_fault_handler (id=1, pc=86108, info=0) at ../../../../nRF5SDK160098a08e2/components/libraries/util/app_error_weak.c:100\n"}]}
    0001442176: 0x00028724 in app_error_fault_handler (id=1, pc=86108, info=0) at ../../../../nRF5SDK160098a08e2/components/libraries/util/app_error_weak.c:100
    0001442176: GDB -> App: {"outOfBandRecord":[{"isStream":true,"type":"console","content":"100\t    NRF_BREAKPOINT_COND;\n"}]}
    0001442176: 100	    NRF_BREAKPOINT_COND;
    Thanks for your help. Any ideas?
    There's no backtrack in your gdb trace.
    if you break/continue/break with the softdevice enabled, it will assert inside the softdevice, as the debugger only halts the CPU core, not the peripherals (like RTC, Radio, and timers). This will then cause all events to occur at the same time when starting the CPU again, and the softdevice then gets interrupts out-of-order and asserts.
    Every time you break, do a "mon reset" before continuing again to avoid this.
    Håkon
  • Hi Hakon
    Managed to get the Jlink GDB Server up and running.
    Had to issue a CTRL-C in order to run 'bt full' as the'b HardFault_Handler' breakpoint wasn't hit. Output as follows:
    (gdb) bt full
    #0  0x0002749e in serial_tx (p_context=<optimized out>, p_buffer=<optimized out>, len=<optimized out>)
        at ../../../../nRF5SDK160098a08e2/components/libraries/log/src/nrf_log_backend_uart.c:88
            len8 = <optimized out>
    #1  0x0002a61a in nrf_fprintf_buffer_flush (p_ctx=p_ctx@entry=0x2003fef0)
        at ../../../../nRF5SDK160098a08e2/external/fprintf/nrf_fprintf.c:56
    No locals.
    #2  0x00028184 in postfix_process (p_params=p_params@entry=0x2003fee4, p_ctx=p_ctx@entry=0x2003fef0,
        newline=newline@entry=false) at ../../../../nRF5SDK160098a08e2/components/libraries/log/src/nrf_log_str_formatter.c:150
    No locals.
    #3  0x000281ee in nrf_log_std_entry_process (p_str=p_str@entry=0x37260 "Transfer type: %s.", p_args=p_args@entry=0x2003fec0,
        nargs=nargs@entry=1, p_params=p_params@entry=0x2003fee4, p_ctx=p_ctx@entry=0x2003fef0)
        at ../../../../nRF5SDK160098a08e2/components/libraries/log/src/nrf_log_str_formatter.c:192
            auto_flush = false
    #4  0x00027388 in nrf_log_backend_serial_put (p_backend=<optimized out>, p_msg=0x20002444 <log_mempool_nrf_balloc_pool_mem>,
        p_buffer=p_buffer@entry=0x200023f8 <m_string_buff> "<info> TWI: Transfer type: XFER_RX.\r\r\nn_init, error code: NRF_SU",
        length=length@entry=64, tx_func=tx_func@entry=0x27481 <serial_tx>)
        at ../../../../nRF5SDK160098a08e2/components/libraries/log/src/nrf_log_backend_serial.c:87
            p_log_str = 0x37260 "Transfer type: %s."
            nargs = 1
            args = {225872, 537132928, 537132880, 183151, 183141, 180577}
            fprintf_ctx = {
              p_io_buffer = 0x200023f8 <m_string_buff> "<info> TWI: Transfer type: XFER_RX.\r\r\nn_init, error code: NRF_SU",
              io_buffer_size = 64, io_buffer_cnt = 38, auto_flush = false, p_user_ctx = 0x0, fwrite = 0x27481 <serial_tx>}
            params = {timestamp = 0, module_id = 5, dropped = 0, severity = NRF_LOG_SEVERITY_INFO, use_colors = 0 '\000'}
            header = {base = {generic = {type = 1, in_progress = 0, data = 28913675}, std = {type = 1, in_progress = 0,
                  severity = 3, nargs = 1, addr = 225888}, hexdump = {type = 1, in_progress = 0, severity = 3, offset = 513,
                  reserved = 9, len = 55}, raw = 231309401}, module_id = 5, dropped = 0, timestamp = 0}
            memobj_offset = 12
    #5  0x00027470 in nrf_log_backend_uart_put (p_backend=<optimized out>, p_msg=<optimized out>)
        at ../../../../nRF5SDK160098a08e2/components/libraries/log/src/nrf_log_backend_uart.c:95
    No locals.
    #6  0x00027922 in nrf_log_backend_put (p_msg=0x20002444 <log_mempool_nrf_balloc_pool_mem>,
        p_backend=0x37570 <uart_log_backend>)
        at ../../../../nRF5SDK160098a08e2/components/libraries/log/nrf_log_backend_interface.h:225
    No locals.
    --Type <RET> for more, q to quit, c to continue without paging--
    #7  nrf_log_frontend_dequeue () at ../../../../nRF5SDK160098a08e2/components/libraries/log/src/nrf_log_frontend.c:862
            entry_accepted = true
            backend_id = <optimized out>
            p_module_filter = <optimized out>
            backend_lvl = <optimized out>
            p_backend = 0x37570 <uart_log_backend>
            rd_idx = 46
            mask = <optimized out>
            p_header = <optimized out>
            header = {base = {generic = {type = 1, in_progress = 0, data = 28913675}, std = {type = 1, in_progress = 0, severity = 3, nargs = 1, addr = 225888},
                hexdump = {type = 1, in_progress = 0, severity = 3, offset = 513, reserved = 9, len = 55}, raw = 231309401}, module_id = 5, dropped = 0,
              timestamp = 0}
            p_msg_buf = 0x20002444 <log_mempool_nrf_balloc_pool_mem>
            memobj_offset = <optimized out>
            severity = <optimized out>
            i = <optimized out>
    #8  0x00034456 in in_pin_handler (pin=<optimized out>, action=<optimized out>) at ../../../bno080-nrf-twi.c:114
    No locals.
    #9  0x0002bfae in GPIOTE_IRQHandler () at ../../../../nRF5SDK160098a08e2/modules/nrfx/drivers/src/nrfx_gpiote.c:716
            pin = <optimized out>
            polarity = <optimized out>
            handler = <optimized out>
            status = 1
            input = {0, 0}
            i = 0
            event = <optimized out>
            mask = 1
    #10 <signal handler called>
    No symbol table info available.
    #11 0x000372d0 in delay_machine_code ()
    #12 0x000344a2 in nrfx_coredep_delay_us (time_us=500) at ../../../../nRF5SDK160098a08e2/modules/nrfx/soc/nrfx_coredep.h:173
            delay_cycles = 0x372d1 <delay_machine_code>
            cycles = 32000
            delay_machine_code = {14339, 55549, 18288}
            delay_cycles = <optimized out>
    #13 BNO_080_set_mode () at ../../../bno080-nrf-twi.c:46
            reg = "\024\001"
            xfer_desc = {type = NRFX_TWI_XFER_RX, address = 75 'K', primary_length = 2, secondary_length = 524291, p_primary_buf = 0x2003ffe4 "\024\001",
              p_secondary_buf = 0x10001000 '\377' <repeats 200 times>...}
    #14 0x000336e4 in main () at ../../../main.c:838
            erase_bonds = false
    (gdb)
    And this is the output without setting 'b HardFault_Handler' (again required CTR-C to obtain a 'bt full'):
    (gdb) bt full
    #0  0x000274a0 in serial_tx (p_context=<optimized out>, p_buffer=<optimized out>, len=<optimized out>)
    #1  0x0002a61a in nrf_fprintf_buffer_flush (p_ctx=p_ctx@entry=0x2003fef0) at ../../../../nRF5SDK160098a08e2/external/fprintf/nrf_fprintf.c:56
    No locals.
    #2  0x00028184 in postfix_process (p_params=p_params@entry=0x2003fee4, p_ctx=p_ctx@entry=0x2003fef0, newline=newline@entry=false)
    No locals.
    #3  0x000281ee in nrf_log_std_entry_process (p_str=p_str@entry=0x37260 "Transfer type: %s.", p_args=p_args@entry=0x2003fec0, nargs=nargs@entry=1,
        p_params=p_params@entry=0x2003fee4, p_ctx=p_ctx@entry=0x2003fef0) at ../../../../nRF5SDK160098a08e2/components/libraries/log/src/nrf_log_str_formatter.c:192
            auto_flush = false
        p_buffer=p_buffer@entry=0x200023f8 <m_string_buff> "<info> TWI: Transfer type: XFER_RX.\r\r\nn_init, error code: NRF_SU", length=length@entry=64,
        tx_func=tx_func@entry=0x27481 <serial_tx>) at ../../../../nRF5SDK160098a08e2/components/libraries/log/src/nrf_log_backend_serial.c:87
            nargs = 1
            fprintf_ctx = {p_io_buffer = 0x200023f8 <m_string_buff> "<info> TWI: Transfer type: XFER_RX.\r\r\nn_init, error code: NRF_SU", io_buffer_size = 64,
            header = {base = {generic = {type = 1, in_progress = 0, data = 28913675}, std = {type = 1, in_progress = 0, severity = 3, nargs = 1, addr = 225888}, hexdump = {
                  type = 1, in_progress = 0, severity = 3, offset = 513, reserved = 9, len = 55}, raw = 231309401}, module_id = 5, dropped = 0, timestamp = 0}
            memobj_offset = 12
    No locals.
    #6  0x00027922 in nrf_log_backend_put (p_msg=0x20002444 <log_mempool_nrf_balloc_pool_mem>, p_backend=0x37570 <uart_log_backend>)
    No locals.
            rd_idx = 46
            i = <optimized out>
    No locals.
            status = 1
            input = {0, 0}
            i = 0
            mask = 1
    #11 0x000372d2 in delay_machine_code ()
            cycles = 32000
            reg = "\024\201"
            xfer_desc = {type = NRFX_TWI_XFER_RX, address = 75 'K', primary_length = 2, secondary_length = 524291, p_primary_buf = 0x2003ffe4 "\024\201",
            erase_bonds = false
    Thanks
    Andrew
