How to support MSG_WAITALL flag for recv() operation
Hi
We need the recv() be blocking until the full amount of requested data can be returned or the operation was timeout, how to achieve this?
I tried flag MSG_WAITALL but failed to compile with error 'MSG_WAITALL' undeclared;
I also tried flag NRF_MSG_WAITALL but did not work, the recv() also returned the smaller amount of data for first message.
  • First we open socket and connect to the server;
    Second, invoke the do_socket_receive() to receive data from server with timeout.
    static int do_socket_open(u16_t type, char* url, u16_t dst_port, u16_t src_port)
    	int err = -EINVAL;
    	int client_fd;
    	enum net_sock_type sock_type;
    	enum net_ip_protocol protocol;
    	struct sockaddr_in local_addr;
    	int addr_len;
    	//int reuse = 1;
    	sock_type = type ? SOCK_STREAM : SOCK_DGRAM;
    	protocol = type ? IPPROTO_TCP : IPPROTO_UDP;
    	LOG_DBG("%s:%d", log_strdup(url), dst_port);
    	err = modem_info_params_get(&modem_param);
    	if (err) {
    		LOG_ERR("Unable to obtain modem parameters (%d)", err);
    		return -1;
    	/* Check network connection status by checking local IP address */
    	addr_len = strlen(modem_param.network.ip_address.value_string);
    	if (addr_len == 0) {
    		LOG_ERR("LTE not connected yet");
    		return -1;
    	if (!check_for_ipv4(modem_param.network.ip_address.value_string,
    			addr_len)) {
    		LOG_ERR("Invalid local address");
    		return -1;
    	if (check_for_ipv4(url, strlen(url))) {
    		err = parse_host_by_ipv4(url, dst_port);
    	} else {
    		err = parse_host_by_name(url, dst_port, sock_type);
    	if (err) {
    		LOG_ERR("Parse failed: %d", err);
    		return err;
    	client_fd = socket(AF_INET, sock_type, protocol);
    	if (client_fd < 0) {
    		LOG_ERR("socket() failed: %d", -errno);
    		return -errno;
    /*	err = setsockopt(client_fd, SOL_SOCKET, SO_REUSEADDR,
    					(const char *)&reuse, sizeof(reuse));
    	if (err < 0) {
    		close(client_fd);
    		LOG_ERR("setsockopt() error: %d", -errno);
    		return -errno;
    	sc_client.sock = client_fd;
    	sc_client.protocol = protocol;
    	LOG_DBG("Socket opened");
    	local_addr.sin_family = AF_INET;
    	local_addr.sin_port = htons(src_port);
    	/* NOTE inet_pton() returns 1 as success */
    	if (inet_pton(AF_INET, modem_param.network.ip_address.value_string,
    		&local_addr.sin_addr.s_addr) != 1) {
    		LOG_ERR("Parse local IP address failed: %d", -errno);
    		return -EINVAL;
    	if(protocol == IPPROTO_TCP) {
    		err = connect(client_fd, (struct sockaddr *)&sc_client.remote,
    				  sizeof(struct sockaddr_in));
    		if (err < 0) {
    			LOG_ERR("connect err: %d errno: %d", err, errno);
    			do_socket_close();
    			return -errno;
    		sc_client.connected = true;
    	} else { //UDP use bind() then share the send() and recv()
    		err = bind(client_fd, (struct sockaddr *)&local_addr,
    			   sizeof(local_addr));
    		if (err) {
    			LOG_ERR("bind err: %d errno: %d", err, errno);
    			do_socket_close();
    			return -errno;
    	sc_client.running = true;
    	LOG_INF("Socket connection service started");
    	return err;
    static int do_socket_receive(u16_t size, u16_t timeout_ms, bool crc32_enabled)
    	int ret;
    	u8_t data[NET_IPV4_MTU] = {0};
    	char hexstr[2*NET_IPV4_MTU+4];
    	int sockaddr_len = sizeof(struct sockaddr_in);
    	int sock = sc_client.sock;
    	struct timeval tmo = {
    		.tv_sec = (timeout_ms / 1000),
    		.tv_usec = (timeout_ms % 1000) * 1000,
    	bool gps_is_active;
    	u32_t crc32;
    	if (size > sizeof(data)) {
    		LOG_ERR("socket receive err: requested size %d exceeded data buffer(%d)", size, sizeof(data));
    		return -EINVAL;
    	gps_is_active = gps_is_running();
    	if(gps_is_active) {
    		ret = gps_control_stop();
    	ret = setsockopt(sock, SOL_SOCKET, SO_RCVTIMEO,
    			&tmo, sizeof(struct timeval));
    	if (ret < 0) {
    		//do_socket_close(-errno);
    		goto error;
    	if(sc_client.protocol == IPPROTO_TCP) {
    		if(!sc_client.connected) {
    			LOG_ERR("Socket receive error: TCP client has not connected to server");
    			ret = -ENOPROTOOPT;
    			goto error;
    		ret = recv(sock, data, size, NRF_MSG_WAITALL);
    	else {
    		ret = recvfrom(sock, data, size, NRF_MSG_WAITALL,
    			(struct sockaddr *)&sc_client.remote, &sockaddr_len);
    	if (ret < 0) {
    		LOG_WRN("recv() error: %d", -errno);
    		if (errno != EAGAIN && errno != ETIMEDOUT && errno != EINVAL) {
    			do_socket_close();
    			ret = -errno;
    			//sprintf(buf, "+MSC: %d\r\n", -errno);
    			//sc_client.callback(buf);
    		} else {
    			sprintf(buf, "+MSCRECV: 0\r\n");
    			ret = 0;
    	} else if (ret == 0) {
    		 * When a stream socket peer has performed an orderly shutdown,
    		 * the return value will be 0 (the traditional "end-of-file")
    		 * The value 0 may also be returned if the requested number of
    		 * bytes to receive from a stream socket was 0
    		 * In both cases, treat as normal shutdown by remote
    		LOG_WRN("recv() return 0");
    	} else {
    		data[ret] = '\0';
    		LOG_INF("MSCRECV: %d, data[%s]", ret, log_strdup(data));
    		if(crc32_enabled) {
    			crc32 = crc32_ieee(data, ret);
    			LOG_DBG("CRC32:0x%04X", crc32);
    			sprintf(buf, "+MSCRECV: %d,\"%04X\",", ret, crc32);
    		else {
    			sprintf(buf, "+MSCRECV: %d,\"00000000\",", ret);
    		int_to_hexstring(data, hexstr, ret, 2*MAX_DATA_SIZE+4);
    		sc_client.callback(hexstr);
    		ret = 0;
    error:
    	if(gps_is_active) {
    		gps_control_start();
    	return ret;
  • You should try using the bsdlib socket API, instead of using Zephyr's socket API. For example, you should replace socket() with nrf_socket(), and recv() with nrf_recv().
  • Hi Hakon,
    Thanks, the NRF_MSG_WAITALL works with nrf_recv().
    But for UDP case, it seems that the NRF_MSG_WAITALL has no effect  to nrf_recvfrom(), could you confirm whether it is supported on UDP also?
  • It's hard to tell from the documentation, it doesn't say much about UDP. This is what I found
    "For message-based sockets, such as SOCK_DGRAM and SOCK_SEQPACKET, the entire message shall be read in a single operation. If a message is too long to fit in the supplied buffer, and MSG_PEEK is not set in the flags argument, the excess bytes shall be discarded."
    Can you show me the code where you set up the UDP socket?
  • Thank Hakon, the UDP behaves as design, resolved.
