Minimalist Bootloader S110
Background :
I'm working with an nRF51822-EK development board. We're working on a project implementing the S110 soft device. We need to create a minimalist Bootloader. All we want to do is implement our own proprietary serial (UART) protocol to erase and write our application.
I had been (mistakenly) developing with the S120 soft device. I was able to use Segger's J-Link Commander to flash the image (s120_nrf51_2.0.0_softdevice.hex) into the part on the development board. I was able to initialize the soft device, and tell it to pass interrupts to my bootloader. All seemed to be working well. It was brought to my attention that I should be using the S110 soft device. I erased the part, and flashed the S110 soft device (s110_nrf51822_6.2.1_softdevice.hex).
Current :
Now all functions that call the soft device for configuration (sd_mbr_command(), sd_softdevice_disable(), softdevice_handler_sd_disable(), sd_softdevice_vector_table_base_set()) just "lock up" the device. What really happens is that execution wanders off into code space that makes no sense.
I have tried the above soft devices, as well as s110_nrf51822_7.1.0_softdevice.hex. In all cases, I can erase the part with J-Link Commander, and use "loadfile" to flash the part with the target soft device.
I've even tried re-flashing the original S120 soft device and I can't even get that back to working. Have I somehow damaged the part by erasing and reflashing? I can't imagine that I could have.
Further :
I'm using IAR v7.30. I've edited my icf file to push the start of my boot loader up to 0x1A000, I'm also passing that address via sd_softdevice_vector_table_base_set(). As I mentioned, it was all working at one point, but I cannot even get back to that point.
