Swift Pairing for custom gatt service
I am using custom gatt service & I have included some of the code which supports swift pairing from ble_hid_mouse example. Here is my sniffer log -
mtu_log.pcapng
& the jlink rtt log -
paired - Copy.txt
For my application, the MTU size is 32 & data length is 36.
Windows keeps negotiating the size to be 512.
After I pair to the peripheral by connecting through the Windows bluetooth menu, it takes 1 minute to establish the ble connection & start data communication. If I dont pair, then the connection is quick. Now I know you will tell me the app has to make a connection. But I would also like to support manual pairing. Our device gets bricked if someone accidentally pairs with the device through Windows bluetooth menu. To avoid this I had to add the swift pairing support.
How do I expedite the connection on Windows for swift pairing? (note the same firmware without swift pairing feature works on Android OS perfectly fine with or without pairing.)
  • I tried adding all these functions, seems like they have been deprecated in SDK 16 according to few tickets and the Migration doc.
    I'm getting these errors in my Keil project.
  • Sorry, you are right. I was looking at an old SDK.
    My suggestion now is to take a look at the \examples\ble_peripheral\ble_app_hids_keyboard or ble_hid_mouse, replace all the parameters and callbacks from that project to your project. Double check that you have not by accident modified any of the SDK libraries for instance to test something earlier.
    You will notice that the \examples\ble_peripheral\ble_app_hids_keyboard or ble_hid_mouse will not send the "Security Request: AuthReq: Bonding". If you are not able to find the problem, then only way forward would be to share a project that can be unzipped to the examples\ble_peripheral and run an nRF52-DK to test here.
    Kenneth
  • This workaround only works for Windows, not Android
        // Pairing not supported
        err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_SUCCESS, NULL, NULL);
    OR
    But on Android, I get an error 'incorrect pin or passkey', how do I overcome that?
  • If you have included peer manager, then those softdevice calls and events are already handled by the module. You should not add additional handling of those two BLE softdevice events directly in your application code. You may however instead use events from the peer manager to override or change the reply by in pm_evt_handler(), you can find a list of events that come from the peer manager module in peer_manager_types.h:
    /**@brief Types of events that can come from the @ref peer_manager module.
    typedef enum
        PM_EVT_BONDED_PEER_CONNECTED,           /**< @brief A connected peer has been identified as one with which we have a bond. When performing bonding with a peer for the first time, this event will not be sent until a new connection is established with the peer. When we are central, this event is always sent when the Peer Manager receives the @ref BLE_GAP_EVT_CONNECTED event. When we are peripheral, this event might in rare cases arrive later. */
        PM_EVT_CONN_SEC_START,                  /**< @brief A security procedure has started on a link, initiated either locally or remotely. The security procedure is using the last parameters provided via @ref pm_sec_params_set. This event is always followed by either a @ref PM_EVT_CONN_SEC_SUCCEEDED or a @ref PM_EVT_CONN_SEC_FAILED event. This is an informational event; no action is needed for the procedure to proceed. */
        PM_EVT_CONN_SEC_SUCCEEDED,              /**< @brief A link has been encrypted, either as a result of a call to @ref pm_conn_secure or a result of an action by the peer. The event structure contains more information about the circumstances. This event might contain a peer ID with the value @ref PM_PEER_ID_INVALID, which means that the peer (central) used an address that could not be identified, but it used an encryption key (LTK) that is present in the database. */
        PM_EVT_CONN_SEC_FAILED,                 /**< @brief A pairing or encryption procedure has failed. In some cases, this means that security is not possible on this link (temporarily or permanently). How to handle this error depends on the application. */
        PM_EVT_CONN_SEC_CONFIG_REQ,             /**< @brief The peer (central) has requested pairing, but a bond already exists with that peer. Reply by calling @ref pm_conn_sec_config_reply before the event handler returns. If no reply is sent, a default is used. */
        PM_EVT_CONN_SEC_PARAMS_REQ,             /**< @brief Security parameters (@ref ble_gap_sec_params_t) are needed for an ongoing security procedure. Reply with @ref pm_conn_sec_params_reply before the event handler returns. If no reply is sent, the parameters given in @ref pm_sec_params_set are used. If a peripheral connection, the central's sec_params will be available in the event. */
        PM_EVT_STORAGE_FULL,                    /**< @brief There is no more room for peer data in flash storage. To solve this problem, delete data that is not needed anymore and run a garbage collection procedure in FDS. */
        PM_EVT_ERROR_UNEXPECTED,                /**< @brief An unrecoverable error happened inside Peer Manager. An operation failed with the provided error. */
        PM_EVT_PEER_DATA_UPDATE_SUCCEEDED,      /**< @brief A piece of peer data was stored, updated, or cleared in flash storage. This event is sent for all successful changes to peer data, also those initiated internally in Peer Manager. To identify an operation, compare the store token in the event with the store token received during the initiating function call. Events from internally initiated changes might have invalid store tokens. */
        PM_EVT_PEER_DATA_UPDATE_FAILED,         /**< @brief A piece of peer data could not be stored, updated, or cleared in flash storage. This event is sent instead of @ref PM_EVT_PEER_DATA_UPDATE_SUCCEEDED for the failed operation. */
        PM_EVT_PEER_DELETE_SUCCEEDED,           /**< @brief A peer was cleared from flash storage, for example because a call to @ref pm_peer_delete succeeded. This event can also be sent as part of a call to @ref pm_peers_delete or internal cleanup. */
        PM_EVT_PEER_DELETE_FAILED,              /**< @brief A peer could not be cleared from flash storage. This event is sent instead of @ref PM_EVT_PEER_DELETE_SUCCEEDED for the failed operation. */
        PM_EVT_PEERS_DELETE_SUCCEEDED,          /**< @brief A call to @ref pm_peers_delete has completed successfully. Flash storage now contains no peer data. */
        PM_EVT_PEERS_DELETE_FAILED,             /**< @brief A call to @ref pm_peers_delete has failed, which means that at least one of the peers could not be deleted. Other peers might have been deleted, or might still be queued to be deleted. No more @ref PM_EVT_PEERS_DELETE_SUCCEEDED or @ref PM_EVT_PEERS_DELETE_FAILED events are sent until the next time @ref pm_peers_delete is called. */
        PM_EVT_LOCAL_DB_CACHE_APPLIED,          /**< @brief Local database values for a peer (taken from flash storage) have been provided to the SoftDevice. */
        PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED,     /**< @brief Local database values for a peer (taken from flash storage) were rejected by the SoftDevice, which means that either the database has changed or the user has manually set the local database to an invalid value (using @ref pm_peer_data_store). */
        PM_EVT_SERVICE_CHANGED_IND_SENT,        /**< @brief A service changed indication has been sent to a peer, as a result of a call to @ref pm_local_database_has_changed. This event will be followed by a @ref PM_EVT_SERVICE_CHANGED_IND_CONFIRMED event if the peer acknowledges the indication. */
        PM_EVT_SERVICE_CHANGED_IND_CONFIRMED,   /**< @brief A service changed indication that was sent has been confirmed by a peer. The peer can now be considered aware that the local database has changed. */
        PM_EVT_SLAVE_SECURITY_REQ,              /**< @brief The peer (peripheral) has requested link encryption, which has been enabled. */
        PM_EVT_FLASH_GARBAGE_COLLECTED,         /**< @brief The flash has been garbage collected (By FDS), possibly freeing up space. */
        PM_EVT_FLASH_GARBAGE_COLLECTION_FAILED, /**< @brief Garbage collection was attempted but failed. */
    } pm_evt_id_t;
