C# PC app development with nRF52840-dongle
Our purpose is to integrate BLE 5 in our embedded application, and do it quickly.. We basically need to send/receive data with maximum throughput.
Per thread below, we are planning to use the ble_app_uart on the embedded side.
For developing the PC app side, assume we are using the nRF52840-dongle you recommended in thread below, where can I find a code example in C# for doing this, implementing the NUS profile? I see there is JS/Node.js code of nrf-connect, but this is somewhat distant from our .NET environment.
Also i see in the Android app - nRF Toolbox - there is a UART app. So basically I'm looking for an equivalent C#/Windows code sample.
Does the pc-ble-driver in C++ cover the NUS service?
Spun off from:
Getting started with MBN52832 BLE Module
  • The pre-built hex files in the pc-ble-driver repo (here) are not complete or up to date. The easiest is to install pc-ble-driver-py via pip, and find it under <site-packages>\pc_ble_driver_py\hex\sd_api_v5. You can find the "site-packages" folder using 'python -m site'
  • Which hex file? I tried them all and always get the same device under Device Manager - "nRF52 SDFU USB (COM10)". Is this the one expected?
  • None of these hex files are doing any better. This is very tedious! How can we get more hands on support on getting the pc-ble-driver running?
    This is the correct place to get pc-ble-driver support (and support for any other nRF product). The error you are seeing match what you see when you use incompatible pc-ble-driver API version and connectivity firmware API version.
    Which exact hex file and which exact example file did you try? Just to make sure the basics are working I suggest the following:
    • Build the heart_rate_collector examples (using VisualStudio all variants are built in one go)
    • Run the nRF Connect BLE app to make sure you have a working connectivity firmware (this will be API version 3).
    • Run the API version 3 heart rate collector example like this (replacing the COM port with your number: ".\heart_rate_collector_sd_api_v3.exe COM6"
    Then you should see an output similar to this:
    λ .\heart_rate_collector_sd_api_v3.exe COM6
    Serial port used: COM6
    Baud rate used: 1000000
    Info: Successfully opened COM6. Baud rate: 1000000. Flow control: none. Parity: none.
    Status: 6, message: Target Reset performed
    Status: 7, message: Connection active
    Scan started
    Received advertisement report with device address: 0xF333BF1473AB
    Received advertisement report with device address: 0x6A8691EE9176
    Received advertisement report with device address: 0xF333723ED24C
    Received advertisement report with device address: 0x66E795F64F45
    Received advertisement report with device address: 0x0212DAE12FDF
    Received advertisement report with device address: 0x4A7357CC6E17
    Received advertisement report with device address: 0x62F5E2A7602A
    Received advertisement report with device address: 0xF33365117774
    You may not want to use the older API version, but if this works, then you know the basic setup is working. Then you can move on to trying a different API version and making sure you have programmed a corresponding connectivity firmware hex file.
