Module requires 3 power cycles to initialize FDS Manager.
Hardware Description:
MKBN02A00 module based on nRF52832 SOC
Software Description
nRF SDK 15.2.0 , SoftDevice S112
Observation:
When power_manager_init() is called before fds_manager_init(). It requires 3 power cycles to initialize FDS module. For the first 2 power cycle applications stays in wait_for_fds_ready() loop.
When power_manager_init() is called after fds_manager_init(), FDS module initializes on 1st power cycle without any problem.
Question:
What could be the possible reason for such behavior? Does power_management (sleep mode) affects the "fds module initialization" status events being generated/captured for
fds_evt_handler. And if so why it works fine on the 3rd power cycle. Or if there is any other problem?
Application Code:
Below is the sequence of initialization in the main function.
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
    // power_management_init();
    ble_stack_init();
    timers_init();
    buttons_leds_init();
    rtc_start();
    fds_manager_init();
    load_device_config();
fds_manager_init(void) function
void fds_manager_init(void)
    ret_code_t ret;
    ret = fds_register(fds_evt_handler);
    if (ret != FDS_SUCCESS)
        // Registering of the FDS event handler has failed.
    ret = fds_init();
        // Handle error.
    wait_for_fds_ready();
    fds_stat_t stat = {0};
    ret = fds_stat(&stat);
    APP_ERROR_CHECK(ret);
    fds_gc();
wait_for_fds_ready() function
static void wait_for_fds_ready(void)
    while (!m_fds_initialized)
       (void) sd_app_evt_wait();
power_management_init() calls nrf_pwr_mgmt_int()
ret_code_t nrf_pwr_mgmt_init(void)
    m_shutdown_started = false;
    nrf_mtx_init(&m_sysoff_mtx);
    nrf_section_iter_init(&m_handlers_iter, &pwr_mgmt_data);
    PWR_MGMT_SLEEP_INIT();
    PWR_MGMT_DEBUG_PINS_INIT();
    PWR_MGMT_STANDBY_TIMEOUT_INIT();
    PWR_MGMT_CPU_USAGE_MONITOR_INIT();
    return PWR_MGMT_TIMER_CREATE();
  • fds_init() notifies the application with the FDS_EVT_INIT event right away if all the fds pages have been tagged previously. In this case, the m_fds_initialized flag will get cleared before entering the wait loop. Remember that FDS is able to tag one page on each boot, so the number of resets you need is going to depend on the number of flash pages you have allocated to FDS.
  • I am seeing the same on SDK16.0.0
    My application is operating with FreeRTOS, so I need to search out a solution here.
    fds_init() occurs after FreeRTOS is running ...
    Not clear the path to solve this problem. I surely don't want a customer to powercycle the product 3 times to force resets ...
    Found a solution ... replaced nrf_delay_ms(50) inside the while() loop, with FreeRTOS friendly vTaskDelay(50)
    This way the FDS_EVT_INIT is able to be returned to the fds_evt_handler()
    This issue only occured on a 'virgin' FDS setup.
