FOTA Hangs
I’m using the latest version of the modem 1.2.0 and sdk v1.2.0
For the most part AWS FOTA seems to be functioning.
However it will start the FOTA job and hang and fail to proceed until the device is rebooted, after which the originally initiated FOTA job will start and finish as expected.
The following log shows what is happening and where the reboot is.
I'm unsure if this issue is related to the TLS cache  problem referred to in many other posts whereby a second attempt at communicating over a socket will fail.
Just eneed some guidance and help if possible please.
[00:05:02.673,980] [1B][0m<dbg> aws_fota.on_publish_evt: Received topic: $aws/things/ogw-352656100322588/jobs/notify-next[1B][0m
[00:05:02.684,936] [1B][0m<inf> aws_fota: Checking for an available job[1B][0m
[00:05:02.691,955] [1B][0m<dbg> aws_fota.get_job_execution: Job ID: 795[1B][0m
[00:05:02.698,516] [1B][0m<dbg> aws_fota.get_job_execution: hostname: ozark-iot-fota.s3-ap-southeast-2.amazonaws.com[1B][0m
[00:05:02.709,045] [1B][0m<dbg> aws_fota.get_job_execution: file_path app_update.bin[1B][0m
[00:05:02.716,735] [1B][0m<dbg> aws_fota.get_job_execution: execution_version_number: 1 [1B][0m
[00:05:02.724,853] [1B][0m<inf> aws_jobs: Subscribe: $aws/things/ogw-352656100322588/jobs/795/update/#[1B][0m
[00:05:03.989,715] [1B][0m<dbg> aws_fota.on_publish_evt: Received topic: $aws/things/ogw-352656100322588/jobs/notify-next[1B][0m
[00:05:04.000,671] [1B][0m<inf> aws_fota: Checking for an available job[1B][0m
[00:05:04.007,720] [1B][0m<dbg> aws_fota.get_job_execution: Job ID: 795[1B][0m
[00:05:04.014,282] [1B][0m<dbg> aws_fota.get_job_execution: hostname: ozark-iot-fota.s3-ap-southeast-2.amazonaws.com[1B][0m
[00:05:04.024,780] [1B][0m<dbg> aws_fota.get_job_execution: file_path app_update.bin[1B][0m
[00:05:04.032,501] [1B][0m<dbg> aws_fota.get_job_execution: execution_version_number: 1 [1B][0m
[00:05:04.040,618] [1B][0m<inf> aws_jobs: Subscribe: $aws/things/ogw-352656100322588/jobs/795/update/#[1B][0m
[00:05:04.483,184] [1B][0m<dbg> aws_fota.on_publish_evt: Received topic: $aws/things/ogw-352656100322588/jobs/notify-next[1B][0m
[00:05:04.494,140] [1B][0m<inf> aws_fota: Checking for an available job[1B][0m
[00:05:04.501,190] [1B][0m<dbg> aws_fota.get_job_execution: Job ID: 795[1B][0m
[00:05:04.507,751] [1B][0m<dbg> aws_fota.get_job_execution: hostname: ozark-iot-fota.s3-ap-southeast-2.amazonaws.com[1B][0m
[00:05:04.518,249] [1B][0m<dbg> aws_fota.get_job_execution: file_path app_update.bin[1B][0m
[00:05:04.525,939] [1B][0m<dbg> aws_fota.get_job_execution: execution_version_number: 1 [1B][0m
[00:05:04.534,088] [1B][0m<inf> aws_jobs: Subscribe: $aws/things/ogw-352656100322588/jobs/795/update/#[1B][0m
[00:05:04.957,000] [1B][0m<dbg> aws_fota.update_job_execution: update_job_execution, state: 1, status: 1, version_number: 1[1B][0m
[00:05:04.968,322] [1B][0m<inf> aws_jobs: Publish topic: $aws/things/ogw-352656100322588/jobs/795/update[1B][0m
[00:05:04.977,783] [1B][0m<inf> aws_jobs: Publish payload {"status":"IN_PROGRESS","statusDetails": {"nextState":"download_firmware","progress":0},"expectedVersion": "1","clientToken": ""}[1B][0m
Device powered off and rebooted here……,
[00]*** Booting Zephyr OS build v2.1.99-ncs1  ***
[00:00:00.004,211] [1B][0m<inf> mcuboot: Starting bootloader[1B][0m
[00:00:00.012,329] [1B][0m<inf> mcuboot: Primary image: magic=good, swap_type=0x2, copy_done=0x1, image_ok=0x3[1B][0m
[00:00:00.025,390] [1B][0m<inf> mcuboot: Boot source: none[1B][0m
[00:00:00.032,562] [1B][0m<inf> mcuboot: Swap type: revert[1B][0m
[00:00:00.432,189] [1B][0m<inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3[1B][0m
[00:00:22.045,471] [1B][0m<inf> mcuboot: Bootloader chainload address offset: 0xc000[1B][0m
[00:00:22.053,192] [1B][0m<inf> mcuboot: Jumping to the first image slot[1B][0m
Flash region                        Domain                 Permissions
00 0x00000 0x08000      Secure                  rwxl
01 0x08000 0x10000      Secure                  rwxl
02 0x10000 0x18000      Secure                  rwxl
03 0x18000 0x20000      Non-Secure         rwxl
04 0x20000 0x28000      Non-Secure         rwxl
05 0x28000 0x30000      Non-Secure         rwxl
06 0x30000 0x38000      Non-Secure         rwxl
07 0x38000 0x40000      Non-Secure         rwxl
08 0x40000 0x48000      Non-Secure         rwxl
09 0x48000 0x50000      Non-Secure         rwxl
10 0x50000 0x58000      Non-Secure         rwxl
11 0x58000 0x60000      Non-Secure         rwxl
12 0x60000 0x68000      Non-Secure         rwxl
13 0x68000 0x70000      Non-Secure         rwxl
14 0x70000 0x78000      Non-Secure         rwxl
15 0x78000 0x80000      Non-Secure         rwxl
16 0x80000 0x88000      Non-Secure         rwxl
17 0x88000 0x90000      Non-Secure         rwxl
18 0x90000 0x98000      Non-Secure         rwxl
19 0x98000 0xa0000      Non-Secure         rwxl
20 0xa0000 0xa8000      Non-Secure         rwxl
21 0xa8000 0xb0000      Non-Secure         rwxl
22 0xb0000 0xb8000      Non-Secure         rwxl
23 0xb8000 0xc0000       Non-Secure         rwxl
24 0xc0000 0xc8000       Non-Secure         rwxl
25 0xc8000 0xd0000       Non-Secure         rwxl
26 0xd0000 0xd8000      Non-Secure         rwxl
27 0xd8000 0xe0000      Non-Secure         rwxl
28 0xe0000 0xe8000      Non-Secure         rwxl
29 0xe8000 0xf0000        Non-Secure         rwxl
30 0xf0000 0xf8000         Non-Secure         rwxl
31 0xf8000 0x100000     Non-Secure         rwxl
Non-secure callable region 0 placed in flash region 2 with size 32.
SRAM region                      Domain                 Permissions
00 0x00000 0x02000       Secure                  rwxl
01 0x02000 0x04000       Secure                  rwxl
02 0x04000 0x06000       Secure                  rwxl
03 0x06000 0x08000       Secure                  rwxl
04 0x08000 0x0a000       Secure                  rwxl
05 0x0a000 0x0c000       Secure                  rwxl
06 0x0c000 0x0e000        Secure                  rwxl
07 0x0e000 0x10000       Secure                  rwxl
08 0x10000 0x12000       Non-Secure         rwxl
09 0x12000 0x14000       Non-Secure         rwxl
10 0x14000 0x16000       Non-Secure         rwxl
11 0x16000 0x18000       Non-Secure         rwxl
12 0x18000 0x1a000       Non-Secure         rwxl
13 0x1a000 0x1c000       Non-Secure         rwxl
14 0x1c000 0x1e000        Non-Secure         rwxl
15 0x1e000 0x20000       Non-Secure         rwxl
16 0x20000 0x22000       Non-Secure         rwxl
17 0x22000 0x24000       Non-Secure         rwxl
18 0x24000 0x26000       Non-Secure         rwxl
19 0x26000 0x28000       Non-Secure         rwxl
20 0x28000 0x2a000       Non-Secure         rwxl
21 0x2a000 0x2c000       Non-Secure         rwxl
22 0x2c000 0x2e000        Non-Secure         rwxl
23 0x2e000 0x30000       Non-Secure         rwxl
24 0x30000 0x32000       Non-Secure         rwxl
25 0x32000 0x34000       Non-Secure         rwxl
26 0x34000 0x36000       Non-Secure         rwxl
27 0x36000 0x38000       Non-Secure         rwxl
28 0x38000 0x3a000       Non-Secure         rwxl
29 0x3a000 0x3c000       Non-Secure         rwxl
30 0x3c000 0x3e000        Non-Secure         rwxl
31 0x3e000 0x40000       Non-Secure         rwxl
Peripheral                             Domain                 Status
00 NRF_P0               Non-Secure                 OK
01 NRF_CLOCK            Non-Secure          OK
02 NRF_RTC0             Non-Secure             OK
03 NRF_RTC1             Non-Secure             OK
04 NRF_NVMC             Non-Secure           OK
05 NRF_UARTE1           Non-Secure         OK
06 NRF_UARTE2           Non-Secure         OK
07 NRF_TWIM2            Non-Secure           OK
08 NRF_SPIM3            Non-Secure            OK
09 NRF_TIMER0           Non-Secure          OK
10 NRF_TIMER1           Non-Secure          OK
11 NRF_TIMER2           Non-Secure          OK
12 NRF_SAADC            Non-Secure          OK
13 NRF_PWM0             Non-Secure           OK
14 NRF_PWM1             Non-Secure           OK
15 NRF_PWM2             Non-Secure           OK
16 NRF_PWM3             Non-Secure           OK
17 NRF_WDT              Non-Secure             OK
18 NRF_IPC              Non-Secure                OK
19 NRF_VMC              Non-Secure             OK
20 NRF_FPU              Non-Secure              OK
21 NRF_EGU1             Non-Secure            OK
22 NRF_EGU2             Non-Secure            OK
23 NRF_DPPIC            Non-Secure            OK
24 NRF_GPIOTE1          Non-Secure         OK
25 NRF_REGULATORS       Non-Secure                 OK
SPM: NS image at 0x18200
SPM: NS MSP at 0x2002e520
SPM: NS reset vector at 0x1e1cd
SPM: prepare to jump to Non-Secure image.
Application started:9004
GPS:
client_id = ogw-352656100322588
nRF Cloud library initialized. 0
Establishing LTE link (this may take some time) ...
[00:00:01.764,984] [1B][0m<inf> lte_lc: PDP Context: AT+CGDCONT=0,"IP","m2m"[1B][0m
[00:00:01.772,033] [1B][0m<dbg> lte_lc.w_lte_lc_connect: Network mode: AT%XSYSTEMMODE=1,0,1,0[1B][0m
+CEREG: 2,"46C9","0006906F",7,0,0,"11100000","11100000"
[00:00:02.799,194] [1B][0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 2[1B][0m
+CEREG: 1,"46C9","0006906F",7,,,"00000001","10000100"
[00:00:04.981,964] [1B][0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 1[1B][0m
Connected to CAT M1 now:, err code: 0
Initialising GPS...
GPS initialized
AWS connection (connected: 0, in progress: 0)
Not connected to AWS, trying to connect
[00:00:09.224,517] [1B][0m<inf> aws_jobs: Subscribe: $aws/things/ogw-352656100322588/jobs/notify-next[1B][0m
[00:00:09.235,046] [1B][0m<inf> aws_jobs: Subscribe: $aws/things/ogw-352656100322588/jobs/$next/get/#[1B][0m
OZARK_CLOUD_EVT_TRANSPORT_CONNECTED
PSM enabled
[00:00:09.414,459] [1B][0m<inf> aws_fota: subscribed to notify-next topic[1B][0m
[00:00:09.421,264] [1B][0m<inf> aws_jobs: Publish topic: $aws/things/ogw-352656100322588/jobs/$next/get[1B][0m
[00:00:09.430,664] [1B][0m<inf> aws_jobs: Publish payload {"clientToken": ""}[1B][0m
[00:00:09.651,367] [1B][0m<dbg> aws_fota.on_publish_evt: Received topic: $aws/things/ogw-352656100322588/jobs/$next/get/accepted[1B][0m
[00:00:09.662,933] [1B][0m<inf> aws_fota: Checking for an available job[1B][0m
[00:00:09.670,043] [1B][0m<dbg> aws_fota.get_job_execution: Job ID: 795[1B][0m
[00:00:09.676,605] [1B][0m<dbg> aws_fota.get_job_execution: hostname: ozark-iot-fota.s3-ap-southeast-2.amazonaws.com[1B][0m
[00:00:09.687,133] [1B][0m<dbg> aws_fota.get_job_execution: file_path app_update.bin[1B][0m
[00:00:09.694,824] [1B][0m<dbg> aws_fota.get_job_execution: execution_version_number: 2 [1B][0m
[00:00:09.703,033] [1B][0m<inf> aws_jobs: Subscribe: $aws/things/ogw-352656100322588/jobs/795/update/#[1B][0m
[00:00:10.195,739] [1B][0m<dbg> aws_fota.update_job_execution: update_job_execution, state: 1, status: 1, version_number: 2[1B][0m
[00:00:10.207,061] [1B][0m<inf> aws_jobs: Publish topic: $aws/things/ogw-352656100322588/jobs/795/update[1B][0m
  • I tried to repeat the process, and I did not see the behavior. I might have misunderstood what you meant. I did the following:
    • Modified the aws_fota example as described in my last answer, with CONFIG_MQTT_KEEPALIVE=930
    • Uploaded the sample to a bucket and programmed the same aws_fota example onto the nrf9160
    1. Then I uploaded a job which contained the job file pointing to the uploaded aws_fota example
    2. Saw that the aws_fota sample recognized the job and started downloading the image. After the DFU was finished it would reset the chip automatically and run the newly updated aws_fota sample
    3. repeat step 1-3
    I ended 1,2,3 step-loop above after about 5-6 iterations and did not see the behavior you explained. Have I misunderstood? Should I repeat the process more? Could you provide a detailed step-by-step method of reproducing it?
    You said, "without powering off the target board please". Did that include not resetting it? However, it will do that automatically when the download is completed.
    Simon
