nRF9160 CTRL-AP access using J-Link Commander/GDB
I've managed to find some magic numbers/commands for working with nRF5x devices using the CTRL-AP interface, but having no such luck with the commands on an nRF9160. I've tried (using J-Link Commander):
J-Link>connect
Please specify device / core. <Default>: CORTEX-M33
Type '?' for selection dialog
Device>
Please specify target interface:
J) JTAG (Default)
S) SWD
T) cJTAG
TIF>
Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
JTAGConf>
Specify target interface speed [kHz]. <Default>: 4000 kHz
Speed>
Device "CORTEX-M33" selected.
Selected interface (JTAG) is not supported by the connected probe.
J-Link>SWDSelect
Select SWD by sending SWD switching sequence.
Found SWD-DP with ID 0x6BA02477
J-Link>SWDWriteDP 1 0x50000000
Write DP register 1 = 0x50000000
J-Link>SWDWriteDP 2 0x01000000
Write DP register 2 = 0x01000000
J-Link>SWDWriteAP 1 0x00000001
Write AP register 1 = 0x00000001
J-Link>SWDReadAP 2
Read AP register 2 = 0x02000000
J-Link>SWDReadAP 2
Read AP register 2 = 0x00000000
Is there something different to be done on the nRF9160? I would have thought that, after having done the above, the device would have performed a mass erase of its flash.
The nRF9160 has sections on using things like the "mailbox" interface with CTRL-AP, but little to absolutely no examples/documentation on opening a terminal and actually using it (that I've found, anyway).
  • The documented form for selecting the bank seems to be incorrect in the comments in the script.
    It seems that the first byte is the address offset.
    Each bank has 8 entries, from 0 to 7. Reading register 8 will not work, as you'll need to switch bank.
    Here's an example of reading IDR (0x0FC):
    SWDSelect
    SWDWriteDP 2 0x040000f0 // Select the correct bank
    SWDReadAP 3 // Read register offset 3 (0xc)
    SWDReadAP 3 // 0x12880000 should be read back
    So, writing to 0x20 would be like this:
    SWDSelect
    SWDWriteDP 2 0x04000020 // Select the correct bank per the register offset
    SWDWriteAP 0 0x12341234
    SWDReadAP 0 // Read register offset 0 (0x0)
    SWDReadAP 0 // Should now read back what you wrote
    Opened up a gdb session, and read the register from the MCU:
    # addr from MCU: https://infocenter.nordicsemi.com/topic/ps_nrf9160/chapters/dif/ctrl-ap.html?cp=2_0_0_8_1_5#unique_1026387282
    (gdb) print *0x50006400
    $2 = 0x12341234
    Could you see if this works?
    Cheers,
    Håkon
  • Perfect! I was able to successfully use ERASEPROTECT.DISABLE to recover a completely locked-down device, and I am able to read and write from the mailbox interface successfully.
    Thanks a ton for the help with this!
